Go to Post Someday, when I grow up, I want to join the GDC so I can make people go crazy, and then release hints that get people even crazier. - unionylibertad [more]
Unread 28-03-2013, 10:05
Re: Are we allowed to use helium?
Originally Posted by Grim Tuesday View Post
However, it wouldn't help as the dictionary definition of weight "A body's relative mass or the quantity of matter contained by it, giving rise to a downward force; the heaviness of a person or thing." would not change no matter how much buoyant force you had lifting it. The apparent weight would; the actual weight wouldn't.
The robot's true mass is not measured during inspection. The official method of weighing an FRC robot uses a force-sensing scale, so the property that matters is what you're calling the "apparent weight".
Originally Posted by EricLeifermann View Post
Best place to get an official answer is the Q&A. Any answer you get here means absolutely nothing.
The answer to such a general question is likely to be something like this:
There are no rules specifically prohibiting helium or other nontoxic gases. However, the robot must still obey all rules.
