Re: Blockading
From my perspective, at the point when the game announcer called the blockading, I had only seen good, clean, 2-on-1 defense that didn't seem to me to be an "attempt to stop the flow of the MATCH." There was at least a 10' path around the two robots on either side, as the "blockade" was right in the middle of the field at the center line. A few seconds later, there is a moment when 610 drove up against the side wall that might be interpreted as a blockade if it persisted, but even then, the 2nd robot immediately backed away. In any case, from the matches I watched at Waterloo, it seemed that almost any 2-on-1 defense was being called as a blockade. Even though our team's robot is primarily offensive, so such a call would typically work in our favor, I don't think forbidding of any 2-on-1 defense is the intent of G25, but maybe that's just my "New England Defense" view. I sure know we had to struggle against 2-on-1 defense at plenty of tournaments each of the past two years! |
Re: Blockading
Re: Blockading
According to the Q and A, two on one defense generally is not to be regarded as a blockade:
Game - The Game » ROBOT Actions » G25 Q577 Q. Does G25 have the potential to apply (at the referees' discretion) to all types of 2-on-1 defense, or is the intent limited to field-centric blocks? Could intentionally impeding 1 robot with 2 defenders qualify as blockading if no other match flow is stopped? FRC1640 on 2013-03-13 | 3 Followers A. We cannot comment absolutely on hypothetical situations. Generally, impeding a single ROBOT without blocking all traffic across the FIELD is not considered a violation of [G25]. Your mileage may vary depending on the regional you are attending of course ![]() |
Re: Blockading
Grand scheme of things, its too late to change now, and I don't recall any matches that were decided by a G25 (typically, the ones they were called in were blowouts anyway), but the point is that all calls should be consistent from event to event, and it should be consistent with the interpretation provided from Q&A/The Manual, if one exists. |
Re: Blockading
I agree that mileage shouldn't vary...but it often does so all teams should at least be prepared to get the head ref to clearly define what he will call as a blockade during the drivers meeting.
Re: Blockading
I do think that just because no matches were decided by G25's doesn't mean it didn't affect the outcome of matches... Teams that had a G25 called on them for open-field 2v1 defense would probably avoid it in the future (20pt penalty is 1.75 cycles!). So, I'm guessing that more teams would've played effective 2v1 defense later in the event if they hadn't learned earlier in the event that it was likely to incur a G25. At any rate, it was called as it was at Waterloo (they did at least seem pretty consistent about it calling it on 2v1 at Waterloo), the best that can be done is just using it as an opportunity to help improve continuity across events. Perhaps this is a case for particular training/clarification to the Head Refs from FIRST HQ? As has already been said... if nothing else, teams should ask in the drivers' meetings about how the refs intend to call G25's. |
#7
Re: Blockading
Blockading has definitely been an interesting one this year. It's a 20pt call that could definitely change the outcome of a match. I don't it has in any of ours yet this year, but it's a huge points swing.
The way it was called between BAE and Waterloo was indeed very different - and I don't think I could call either way explicitly "right" or "wrong." We saw lots of 2 on 1 defense at both events, and one consistent thing when blockading calls were made were two robots, lined up one in front of the other, driving sideways across the field. This is about the only arrangement I've seen where blockading calls were made *consistently*. The video referenced above shows that arrangement from about 28s to 20s left: http://watchfirstnow.com/archive3.php?id=62472516 There's been plenty of 2 on 1 defense where that arrangement never happens, and no blockading call is made: http://www.youtube.com/watch?v=X3FMK...YdSlRb_rLXUTtM It would be nice it we could define blockading a bit more concisely, but honestly, I'm not sure how. |
#8
Re: Blockading
I'd much rather the GDC just abandon the concept entirely.
