Go to Post You need a good BAD (*BAD = Ball Acquisition Device) - DonRotolo [more]
Unread 28-03-2013, 21:11
meibnotu's Avatar
meibnotu meibnotu is offline
AKA: Mei-Jing Bernard
FRC #5332 (Toaster Tech)
meibnotu is an unknown quantity at this point
Remedy a too dropped center?
Our robot features drop center for various reasons and it has been very advantageous, but the team has come to the conclusion that the drop center might be too dropped. During Peachtree Regional we duct taped on 4 boxes of roller chain, an extra sim, and an air tank. The ballast was very effective but we noticed that it was effecting our ability to move quickly across the field so all of the ballast got removed. Suggestions to adjust the drop center slightly with less janky solutions?
Unread 28-03-2013, 21:16
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Remedy a too dropped center?
Depending on what wheels you use:
Just turn down the OD of the center wheels.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 28-03-2013, 21:21
I don't have a suggestion on the wheels but I most certainly have one for ballast. Duct tape is not a fastener! In the future, ballast must be attached with standard fasteners and be inspected prior to match play in which it is used.
Unread 28-03-2013, 21:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What wheels are you using?
You may be able to reduce the OD a little bit on the center wheel or increase the OD on the outer wheels.
How are your axles mounted to your frame?
If you are using pillow block bearings, the answer is pretty simple. Add a shim underneath the bearings of whichever wheels you want to raise.
How close is your CG to center?
You could move your CG towards one end of the robot so that it always (or almost always) "sits" on one set of four wheels.
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
Again, depending on wheels, you could use a larger tread (if you are using tread wheels) on the outside, or smaller on the center wheels, or both!
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 28-03-2013, 21:29
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Can we get a picture to help us help you out?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 28-03-2013, 22:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We fixed a not-dropped enough center this morning. VexPro traction wheels. We pulled the old tread and put on new tread, but with a strip of 3/4" wide urethane belting under it to increase the diameter by 1/8" or so. That plus the newer, stiffer nitrile tread got us enough rock that we're turning smoothly. You could do the same on your outside wheels to increase their diameter a bit.
Unread 28-03-2013, 23:05
meibnotu's Avatar
In our defense it was one of our quick fixes between matches. But yes 4080 uses way too much duct tape!
Unread 28-03-2013, 23:50
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
vikesrock777 will become famous soon enough
To answer some of the questions asked so far in this thread:
wheels- http://www.vexrobotics.com/217-2903.html
Al- we did get it cleared by an inspector before going into our next match. Where it was located it was set on a frame member and had a secure frame member both on the back and a side. Regardless, point received and understood, we will be sure to use a more solid fastening system next time, thanks for your concern.
I could be wrong but I'm pretty sure it's a 1/8" drop right now.
As to how the wheels are currently mounted, it's a similar setup to the way the kitbot wheels are mounted (dead axle through holes in our c-channel frame.)
Lil' Lavery- I couldn't give you an exact location but it is close to the center of our robot, so moving the CG forward or backward slightly is something we can look into. Our CG vertically is another point of concern (hence the discussion of ballast) as our robot is underweight, about 95 pounds without battery and bumpers. The majority of that weight is very low, but the shooter assembly (25lbs of weight centered around 40") as well as our hanging system (simple pneumatic cylinder with hooks) and the supporting structure all may be contributing to the tipsiness by raising our cg.
As for a picture, I don't have one on hand that clearly shows our wheel setup and our robot is in a crate currently.
Unread 28-03-2013, 23:55
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
1/8" isn't a whole lot of drop, though it depends on the layout of the chassis. What is the wheelbase (distance from front axle to back axle)? Is the dropped wheel perfectly centered?
Having 25 pounds 40" off the ground will certainly contribute to tippiness, and would be very difficult to offset by changing the center drop or other drivetrain geometry.
Unread 29-03-2013, 00:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Normally I'd ask for a picture, but in this case I'll ask for video, with narration describing what it is you are attempting to cure.
Unread 29-03-2013, 00:26
meibnotu's Avatar
Here is a link to us (4080). The rocking occurs a lot throughout the match, but it you can get a good gist of the rocking at about the 5:00 min mark.
http://www.youtube.com/watch?v=OMZSp...MtqeKysuNXsV0I
Unread 29-03-2013, 07:12
Casey,
Future inspectors should point at duct tape and make the same warning. What we are most fearful of is a hard crash launching ballast at people along the side of the field and if you climb, we don't want ballast falling on someone that does not have a hard hat. Since I have seen some incredibly hard hits this year, (enough to tip robots) launching is a big concern.
Unread 29-03-2013, 14:37
AKA: Casey O'Connor
Looking through the videos available, these are the best I could find.
https://www.youtube.com/watch?v=OMZSpcRabzE
If you look from ~4:50-5:00 you can see quite a bit of mild rocking.
https://www.youtube.com/watch?v=6ezIW5mEOdA
From ~1:15-1:40 and then again a little bit as the robot leaves the feeder station around 2:45.
In both of these examples the severity of the tip is somewhat mitigated as by this point the driver was reluctant to switch to high gear as much because of the rocking.
@GUI- yes, it is an unfortunate amount of weight up there. We are also looking into ways to reduce the weight of our shooter assembly (our withholding allowance) but hemorrhaging it entirely for the sake of maneuverability doesn't seem like an optimal tradeoff unfortunately.
Unread 29-03-2013, 14:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
A powerful drivetrain, grippy wheels, an 1/8" drop, and a heavy shooter up very high can produce those same results. With short wheelbases, I would probably drop less than 1/8", or may not even drop at all (depending on the exact wheelbase configuration).
Since you are only 95 lbs, add weight as low as you can and as centered as you can in the robot. A massive steel part an inch above the ground in the middle of the robot would be ideal.
Another potential cause is to check your drivetrain speed controllers, and move the brake/coast jumpers to coast mode. Also, check your driver to make sure they are not slamming the joysticks to full forward and reverse, you want to smoothly ease into all movements.
Art Dutra IV
世上无难事,只怕有心人.
