Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 28-03-2013, 21:11
meibnotu's Avatar
meibnotu meibnotu is offline
AKA: Mei-Jing Bernard
FRC #5332 (Toaster Tech)
meibnotu is an unknown quantity at this point
Remedy a too dropped center?
Our robot features drop center for various reasons and it has been very advantageous, but the team has come to the conclusion that the drop center might be too dropped. During Peachtree Regional we duct taped on 4 boxes of roller chain, an extra sim, and an air tank. The ballast was very effective but we noticed that it was effecting our ability to move quickly across the field so all of the ballast got removed. Suggestions to adjust the drop center slightly with less janky solutions?
Unread 28-03-2013, 21:16
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Remedy a too dropped center?
Depending on what wheels you use:
Just turn down the OD of the center wheels.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 28-03-2013, 21:21
I don't have a suggestion on the wheels but I most certainly have one for ballast. Duct tape is not a fastener! In the future, ballast must be attached with standard fasteners and be inspected prior to match play in which it is used.
Unread 28-03-2013, 21:22
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Are you using the kitbot frame? If not, how much is your center wheel dropped?
Unread 28-03-2013, 21:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What wheels are you using?
You may be able to reduce the OD a little bit on the center wheel or increase the OD on the outer wheels.
How are your axles mounted to your frame?
If you are using pillow block bearings, the answer is pretty simple. Add a shim underneath the bearings of whichever wheels you want to raise.
How close is your CG to center?
You could move your CG towards one end of the robot so that it always (or almost always) "sits" on one set of four wheels.
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
Again, depending on wheels, you could use a larger tread (if you are using tread wheels) on the outside, or smaller on the center wheels, or both!
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 28-03-2013, 21:29
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Can we get a picture to help us help you out?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 28-03-2013, 22:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We fixed a not-dropped enough center this morning. VexPro traction wheels. We pulled the old tread and put on new tread, but with a strip of 3/4" wide urethane belting under it to increase the diameter by 1/8" or so. That plus the newer, stiffer nitrile tread got us enough rock that we're turning smoothly. You could do the same on your outside wheels to increase their diameter a bit.
Unread 28-03-2013, 22:11
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
How are a ballast and the center drop related?
It would be helpful if you could describe what you didn't like about the movement of the robot with the ballast compared to before it was added.
We ran a 5/16" drop this year, which is one of the larger drops I have ever seen, and have no issues @114 pounds + battery and bumpers.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 28-03-2013, 22:25
Nate Laverdure's Avatar
FRC #2363
Add a bunch of zip ties in loops around the treads of the four outer wheels. This will do two things: increase the OD and decrease the side-to-side traction. I like to call these "poor man's omniwheels".
Unread 28-03-2013, 23:05
meibnotu's Avatar
In our defense it was one of our quick fixes between matches. But yes 4080 uses way too much duct tape!
Unread 28-03-2013, 23:50
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
vikesrock777 will become famous soon enough
To answer some of the questions asked so far in this thread:
wheels- http://www.vexrobotics.com/217-2903.html
Al- we did get it cleared by an inspector before going into our next match. Where it was located it was set on a frame member and had a secure frame member both on the back and a side. Regardless, point received and understood, we will be sure to use a more solid fastening system next time, thanks for your concern.
I could be wrong but I'm pretty sure it's a 1/8" drop right now.
As to how the wheels are currently mounted, it's a similar setup to the way the kitbot wheels are mounted (dead axle through holes in our c-channel frame.)
Lil' Lavery- I couldn't give you an exact location but it is close to the center of our robot, so moving the CG forward or backward slightly is something we can look into. Our CG vertically is another point of concern (hence the discussion of ballast) as our robot is underweight, about 95 pounds without battery and bumpers. The majority of that weight is very low, but the shooter assembly (25lbs of weight centered around 40") as well as our hanging system (simple pneumatic cylinder with hooks) and the supporting structure all may be contributing to the tipsiness by raising our cg.
As for a picture, I don't have one on hand that clearly shows our wheel setup and our robot is in a crate currently.
Unread 28-03-2013, 23:55
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
1/8" isn't a whole lot of drop, though it depends on the layout of the chassis. What is the wheelbase (distance from front axle to back axle)? Is the dropped wheel perfectly centered?
Having 25 pounds 40" off the ground will certainly contribute to tippiness, and would be very difficult to offset by changing the center drop or other drivetrain geometry.
Unread 29-03-2013, 00:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Normally I'd ask for a picture, but in this case I'll ask for video, with narration describing what it is you are attempting to cure.
Unread 29-03-2013, 00:26
meibnotu's Avatar
Here is a link to us (4080). The rocking occurs a lot throughout the match, but it you can get a good gist of the rocking at about the 5:00 min mark.
http://www.youtube.com/watch?v=OMZSp...MtqeKysuNXsV0I
