Go to Post Wow! Shipping to Israel?!? It's exciting to have a fan from so far away :D - stens987 [more]
Unread 29-03-2013, 07:12
Re: Remedy a too dropped center?
Casey,
Future inspectors should point at duct tape and make the same warning. What we are most fearful of is a hard crash launching ballast at people along the side of the field and if you climb, we don't want ballast falling on someone that does not have a hard hat. Since I have seen some incredibly hard hits this year, (enough to tip robots) launching is a big concern.
Unread 29-03-2013, 14:37
vikesrock777 vikesrock777 is offline
Georgia Tech RoboJacket
AKA: Casey O'Connor
FRC #5332 (Toaster Tech)
vikesrock777 will become famous soon enough
Originally Posted by MrForbes View Post
Normally I'd ask for a picture, but in this case I'll ask for video, with narration describing what it is you are attempting to cure.
Looking through the videos available, these are the best I could find.
https://www.youtube.com/watch?v=OMZSpcRabzE
If you look from ~4:50-5:00 you can see quite a bit of mild rocking.
https://www.youtube.com/watch?v=6ezIW5mEOdA
From ~1:15-1:40 and then again a little bit as the robot leaves the feeder station around 2:45.
In both of these examples the severity of the tip is somewhat mitigated as by this point the driver was reluctant to switch to high gear as much because of the rocking.
@GUI- yes, it is an unfortunate amount of weight up there. We are also looking into ways to reduce the weight of our shooter assembly (our withholding allowance) but hemorrhaging it entirely for the sake of maneuverability doesn't seem like an optimal tradeoff unfortunately.
Unread 29-03-2013, 14:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
A powerful drivetrain, grippy wheels, an 1/8" drop, and a heavy shooter up very high can produce those same results. With short wheelbases, I would probably drop less than 1/8", or may not even drop at all (depending on the exact wheelbase configuration).
Since you are only 95 lbs, add weight as low as you can and as centered as you can in the robot. A massive steel part an inch above the ground in the middle of the robot would be ideal.
Another potential cause is to check your drivetrain speed controllers, and move the brake/coast jumpers to coast mode. Also, check your driver to make sure they are not slamming the joysticks to full forward and reverse, you want to smoothly ease into all movements.
Art Dutra IV
世上无难事,只怕有心人.
Unread 29-03-2013, 15:15
meibnotu's Avatar
meibnotu meibnotu is offline
AKA: Mei-Jing Bernard
meibnotu is an unknown quantity at this point
Another potential cause is to check your drive train speed controllers, and move the brake/coast jumpers to coast mode. Also, check your driver to make sure they are not slamming the joysticks to full forward and reverse, you want to smoothly ease into all movements.
@artdutra04 In at least one of the videos we were definitely doing that, but that was to resolve an jamming problem so that accentuated the rocking. Typically the joystick motions are much smoother, but it still resulting in tipping. Hence the thread
Unread 29-03-2013, 15:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It looks like you have a wide, tall robot, which is pretty much gonna be a tippy robot, no matter what you do with the center drop. Most wide robots have only 4 wheels, since you don't really need dropped center wheels to make them turn reasonably well.
If I'm mistaken about the design of your robot, please describe it better (including dimensions for wheelbase, track width, etc), post some pictures, or something....it's hard to see it in the videos, I had to watch them a few times just to find a robot that looks like it might say 4080 on the bumpers.
