Climbing Speed Ranking
Hey I was wondering if anyone has keep a record of the times it takes for each of the three level climber s to reach the top. Please post them here so we can see the ranking based on times. Thanks
Re: Climbing Speed Ranking
1114 - 8 |
We have 24 seconds team 842
So 1st is 254 at 6.4 2nd is 1114 at 8.0 3rd is 842 at 24 so far Last edited by falconmaster : 29-03-2013 at 18:06. |
1114 has not done less than 10, that I have seen. Technically we have not done it in competition yet either.
A good definition of when a climb starts will certainly be needed for an accurate comparison. In 254's video, they start it the first time the bot moves above the ground, but it takes them time to first get under the pyramid, line up, and deploy the hooks upwards before the climb starts. Similar scenarios happen on other bots, some line up faster than others.
Sort of sounds like minibot climb time vs deployment + climb. |
Team 2481 takes 23 seconds to climb for 30 points.
See Wisconsin Finals match 2: https://www.youtube.com/watch?v=KGFBbYsgGlU Last edited by ruacubfan2 : 29-03-2013 at 19:25. Reason: Clarification of regional |
#7
Fastest I've seen 1114 go is around 12s
#8
At Chestnut Hill, we (1640) took 24 seconds from first changing orientation to exiting Level 2. We're ready to be faster, including alignment, at MAR.
#9
Team 1421 is at about 23 seconds here, (http://www.youtube.com/watch?v=OUQGw...gV4UN&index=86) but I know this is not their fastest. In Bayou Final 2 they were able to climb and dump in the last 30 seconds. Most exciting match I have seen this year.
#10
Why is 1986 forgotten? I am pretty sure their climb was close to 12 seconds...
#11
Have they done a 30pt yet? (I was not watching GKC, but I know they did not hang for 30 at Hub.)
#12
1986 never climbed to 30 at GKC, however, they were very fast climbing to 20.
#13
You could start the clock when the robot leaves level zero and stop it when the robot exits level 2. That is an "objective" definition, but it doesn't really tell the whole story. There are no extra points for getting to the top first (like minibots), but if a fast climb means you can run one or two more cycles, then that matters. What really defines the start of the climb is when you stop playing "the rest of the game" and devote yourself to climbing. The climb clock stops when the match ends. You could go from level 0 to 3 in two seconds, but if you quit shooting discs at 60 seconds, spend 20 seconds lining up, and then sit at the top for 28 seconds, you are no better off than somebody who quit shooting at 60, lined up in 5, climbed in 50, and sat for 5. What is important is that you know how much time you need (less is better), and you make the most of the remaining time. It also matters whether or not you are carrying discs to the top. That adds the transit & loading time to your cycle, but the payoff is pretty good. How long does it take to unload the discs at the top (1334 beats 1114 on this one)? How many "cycles" can you turn before you need to load the colored discs? As for our robot, it takes about 25 seconds from when we exit level 0 until we exit level 2. However, our true "climb cycle" starts at the pyramid when we unload white discs and decide what to do next. We need about 65 seconds to go get the colored discs, line up, climb, & dump. Last edited by Wayne TenBrink : 31-03-2013 at 13:24. Reason: 1334 was who I was thinking, not 1332 |
#14
The Cyber Gnomes, Team 2013, after fixing a few things - we're able to consistently cycle twice and 30pt climb at the 45 second mark during GTRW. I would say that after lining up for the climb it takes them 10 seconds per level.
This consistency, mixed with an okay schedule, landed them 4th place before alliance selections. They teamed up with 1241 and 1325 to make for a killer combo to take them to the semi finals where they met their demise to the hands of 1310 (finalists at Waterloo), Peacock, and of course the "Smoothest Climber", 1334. We're going to see a lot of 30pt and even 50pt climbers in the finals matches of each division at champs. |
#15
I think 453 can do it in roughly 15seconds
