Go to Post Andy sent me this message last year: "you go, Jenny." I'm still waiting for him to say it's ok to stop. - RoboMom [more]
  #31   Spotlight this post!
Unread 29-03-2013, 16:10
Re: Are we allowed to use helium?
Helium is mined.
  #32   Spotlight this post!
Unread 29-03-2013, 18:02
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Originally Posted by Whippet View Post
If I remember correctly, it comes from the radioactive decay of Uranium.
That's the most correct answer so far (Plutonium also releases alpha particles). Then it gets trapped in the ground and can be mined. Nice!
Maybe one day we'll be able to harvest it from fusion reactors as well (or the sun).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
  #33   Spotlight this post!
Unread 29-03-2013, 18:34
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
which brings us to...
do you REALLY need to use that helium??
SAVE THE HELIUM!!!
  #34   Spotlight this post!
Unread 29-03-2013, 20:46
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Todd, I submit that the filled balloon (from a flat, no volume state) is not at 1 atmosphere. If it were it would not change dimension. There would be no force pushing out on the envelope.
http://faculty.piercecollege.edu/yam...0Expanding.pdf
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #35   Spotlight this post!
Unread 29-03-2013, 20:48
Racer26 Racer26 is offline
...Now i'm wondering if I could put enough helium in a pneumatic tire to make it float. R78 doesn't say the pneumatic wheel has to be serving a 'wheel' purpose, and a floating pneumatic wheel would be just as effective as a balloon at getting in the way.
  #36   Spotlight this post!
Unread 29-03-2013, 20:50
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Even if there isn't a rule about it, I don't see a point in it. If you're over on weight, start making swiss cheese.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
  #37   Spotlight this post!
Unread 29-03-2013, 21:00
The short answer is "No".
It would take ~46 cubic feet of Helium at NTP to raise a 3 lbm wheel.
  #38   Spotlight this post!
Unread 29-03-2013, 21:07
Well, that would depend on what constitutes an "air filled (pneumatic) wheel". Do I require the hub? Does the inner tube alone count?
I realize I'm lawyering, but that's kind of the point of this discussion, no?
I would tend to agree with Tristan's view that using a balloon *may* not constitute a violation of the pneumatics rules, but its certainly a grey area.
For years, the pneumatics rules forbade pneumatic wheels without specifically calling out an exception, but teams USED pneumatic wheels. Nobody noticed that the way the rules were written forbade them, because nobody thought of a pneumatic tire as being a pneumatic device.
  #39   Spotlight this post!
Unread 29-03-2013, 21:09
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Interestingly, adding helium to a fixed volume will make it LESS likely to float. In the case of a mylar bag, the maximum lift potential happens when the bag volume just reaches its maximum. If you keep pressurizing the bag, you are adding more gas mass, but keeping the volume fixed. Density increases, causing a loss of lift. If the bag were strong enough, it would be possible to pressurize the bag to the point where the mass of helium in the bag would be greater than the air it displaced, actually making the bag sink, rather than rise.
Todd F.
Photo gallery
video channel
Triple Helix mobile
  #40   Spotlight this post!
Unread 29-03-2013, 21:33
Not true. Prior to specific rules, the flow chart for checking the legality of parts would allow pneumatic tires.
  #41   Spotlight this post!
Unread 29-03-2013, 21:42
Was there ever a year when the flow chart was considered to have the status of an actual rule, rather than being a (possibly incomplete) summary of the rules?
  #42   Spotlight this post!
Unread 30-03-2013, 02:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You know all the answers to your questions. There are specific exclusions to air storage as you have pointed out. Everything else is subject to the rules.
The fundamental question concerns the meaning of "pneumatic" in the rules. If they mean to restrict all pressurized gases with it, then this is relatively clear-cut. If they mean to restrict air only, the existing rules on safety, energy storage and parts utilization could be applied to helium, without posing undue risk. An appropriate level of regulation can be achieved in at least two substantially different ways—so why presuppose that FIRST intends one and not the other? (I also eagerly await FIRST's response, if anyone chooses to ask the Q&A for it.)
Also, the 1 atm specification you mention—although reasonable—is not stated in the rules, and to my knowledge has never been articulated by FIRST. As a result, teams may wonder why other indications of FIRST's intent aren't really in harmony with that specification:
  • Is the nitrogen in a gas shock above 1 atm? (Probably—so why does FIRST explicitly exempt it?)
  • What if I had a small, sealed, air-filled container at 1 atm, inserted it into a vessel and used a legal vacuum pump to evacuate the vessel to 0.8 atm? Is the container now subject to the pneumatics rules? (In other words, is the 1 atm gauge or absolute?)
  • Is a nitrogen-filled tire tube an "air-filled (pneumatic) wheel" for the purposes of the rule? (And is that because commercial nitrogen is "air", or because all compressed gases should be subject to the pneumatics rules?)
By the way, since I didn't really explain my rationale earlier: the energy source rule covers forms of energy that are "used" (I presume this means intentional energy release during a match). Every robot can catch fire: that doesn't mean we prohibit every single robot because it's a source of (chemical potential) energy not enumerated in the rules. By the same token, if popping a balloon is an unintended failure mode, there's an equally good case that that energy release is not use, and thus not subject to the energy storage rule. The safety rule covers it adequately.
With regard to the compressed air source rule, it uses the word "air", and so I have a hard time accepting that it covers gases that are not (in any conventional sense) air. As others have noted, calling commercial-grade helium air is as bad as calling it natural gas, uranium or starstuff.
The 1999 rules contained (and possibly introduced) many of the pneumatic system principles we use to this day. I'm certain that the use of pneumatic wheels in FRC predates the advent of the parts usage flowchart several years later (unless there was another flowchart prior to 1999).
I distinctly remember a team using the Skyway Ø8 in pneumatic wheelchair wheels in 2001, and many teams using them thereafter. (I suppose they could have been filled with something else, but I kind of doubt it.)
I think the flowchart was called out as enforceable by a numbered rule in some years, but in others it was merely appended to the manual and was ruled advisory (like a Q&A response).
  #43   Spotlight this post!
Unread 30-03-2013, 09:04
Alan,
Whenever a team used a part that was not covered by the rules, the inspectors used the flow chart to determine it's legality. Remember that materials were far more restricted in the past than they are today. Teams actually used packing material in the KOP because anything in the kit was legal.
Tristan, how can you make a distinction between air and other gases when the rules do not. The rules speak to "air pressure" which is by definition a mixture of gases. Gas shocks are specifically excluded, other devices that contain pressurized gas are not excluded and therefore not legal for use on the robot. As to robot rules, I have electronic copies back to 2001 and in that year materials you could use on the robot were limited...
The materials that you are allowed to use to build the robot are limited. There are three sources of
materials:
Sources of Robot Materials Location
1. Parts found in the Kit of Parts Appendix B, Inventory list
2. Parts from SMALL PARTS, INC. SMALL PARTS, INC. Catalog
Appendix D, Ordering information
3. Parts from Additional Hardware List Appendix C
Now I don't have a Small Parts Catalog from that time but I don't remember them selling pneumatic tires. Wheels provided in the kit (and listed in Appendix C) were specifically "5"-8" Ø, Up to 6 non-pneumatic".
As to the 1 atm, will someone please explain how a deflated mylar balloon would magically fill up if the pressure inside and outside the balloon are the same? Assuming that gravity and temperature are ignored, convince me that helium gas would magically move to the interior of the balloon and fill it with no other force acting on it. And if that is the case, why would the balloon deflate when it is opened? (Ignoring of course the lighter than air helium gas)
  #44   Spotlight this post!
Unread 30-03-2013, 10:36
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I'll try
Pressure is the sum of the forces from all gas molecules hitting the container walls, divided by the walls' area. Thus, it is proportional to the number of collisions per unit area, and the velocity of the particles. The latter is temperature, which we're ignoring. The former is based on the container surface and the number of gas molecules. In elastic balloons, these two do not rise proportionally, because the internal pressure is balancing not just the external pressure, but also the the elastic potential energy of the balloon. In a mylar balloon (not overly inflated), the internal pressure is not compensating for elasticity, so the two pressures are in fact equal--the increasing volume exactly compensates for the increasing number of gas molecules. So it's not that there's no force acting on it, it's that the force in P=F/A is increasing exactly proportionally to A.
...Maybe.
<Is about to be killed by Ether>
EDIT: Hey, hey! It's seems that someone actually did this experiment. See page 3, it is indeed constant at 1atm. Who'da thunk? I was not expecting to get that right.
  #45   Spotlight this post!
Unread 30-03-2013, 11:01
Siri,
Thanks for trying. What I am trying to understand is this. You have a volume of gas at 1 atm. You have a deflated balloon, flat, no internal volume. The inside and the outside of the balloon are also at 1 atm. The volume of gas is connected to the balloon with a hose or tube. Explain how the volume of gas will somehow expand the balloon and fill it if all pressures are equal. This is what was proposed earlier in the thread. I see no force that will impel the balloon to inflate and for the gas to pass from one volume to the other.
