Go to Post since when do we programmers start begging to get off easy? - Kevin Sevcik [more]
Unread 29-03-2013, 19:57
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Shooter Help for 2nd Year Team
Compression, although not as drastic as last year, is quite important.
Take a shot at mounting the other side of the shooter (side without wheels) on 80/20 sliders so you can easily adjust the compression to find the sweet spot.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 29-03-2013, 22:08
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Looks to me like your wheel isn't exposed enough to your frisbee. Try exposing them a bit more, and stack another wheel on top so the frisbee has no chance of skipping up over the wheel. I know quite a few teams had success with these wheels and motors, once you expose the wheel a bit more you just need to play with the compression. You should also be able to lose the 3rd wheel/motor.
Unread 29-03-2013, 22:29
Why does it matter how much it's "exposed", as long as it sticks out far enough to produce the required compression without requiring the width of the chute to be less than the frisbee diameter?
Unread 29-03-2013, 23:03
Thorne Thorne is offline
Team Captain turned Mentor
AKA: Mercedes Thorne
FRC #4186 (The Aztechs)
Thorne is an unknown quantity at this point
We've worked it out, thanks to all of you! We now have a two-motor shooter that shoots frisbees 20-30ft (depending upon how much juice the battery has) and we can hit the 2pt goal. I'll post video and specs ASAP.
Thanks so very much!
Unread 30-03-2013, 01:55
Ta-Da! We have a functioning shooter!
Video: http://youtu.be/DASvBTc78GM
We're getting 20-30 feet from it with stacked wheels (as you suggested), two different CIM motors, a big one and a smaller one, the smaller one spins faster than the big motor, which apparently gave us the variance we needed. However, it was a little bit accidental, we put it all together and said "Let's see if it works!" and it worked fantastically! We also increased our compression and added some foam insulation tape for friction, which helped a lot.
Thanks again from the entire team, we look forward to the Silicon Valley Regional next week!
Unread 30-03-2013, 02:24
Here's some photos of the final shooter, it was getting dark so the lighting's not great...
last one's a little blurry, but you get the idea :)
Unread 30-03-2013, 06:47
Michael Hill's Avatar
Just curious...why two different sizes of wheels?
Unread 30-03-2013, 12:16
Smaller wheel reduces tangential speed for entry. They don't have a speed controller.
Unread 30-03-2013, 12:17
Is it just my imagination, or is the CIM not mounted perpendicular to the plywood?
Unread 30-03-2013, 12:29
savagecreature savagecreature is offline
AKA: Clint and/or Maria
FRC #4186 (Alameda Aztechs)
savagecreature is an unknown quantity at this point
What Ether said.
We only have one cRIO and it is on the bagged robot. That is the first thing we will be remedying for next year. This was the best method we could come up with to vary the speed between the two sets of wheels. We have had a really steep learning curve and a really small team. It has been a very educational experience in so many ways.
Unread 30-03-2013, 12:39
They are supposed to be perpendicular, but one of the motors is indeed a little bit out of alignment. We will be replacing the plywood today since it got pretty chewed up while things were getting moved around yesterday. Today will be dedicated to cleaning up the design, adding the bucket frisbee hopper, and adding a pneumatic "pusher" that will feed the frisbees in to the wheels unless there is a way we can get it to just gravity feed.
Thank you (and everyone) for your patience and help. The team went from totally discouraged and not wanting to even go to regionals for fear that we would be the lamest team there again, to having a bit of hope that we can make a better showing than last year.
We did place 47th out of 50 last year, but that was primarily due to good alliances. We also received the Rookie Inspiration Award last year so the team wanted to show that we were taking that to heart and making progress.
Unread 30-03-2013, 14:01
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Glad to hear your shooter is working well.
One thing I noticed was that you had to push the disc into the wheels. Make sure the disc isn't dragging between the walls after the first set of wheels (i.e. the walls should be >11" apart). This would require moving the left wall to the left a little bit; it looks like the distance between the right wall and the wheels is good.
As far as local teams, usfirst.org has a search tool for finding teams in your area. Here are all the teams within 25 miles of Alameda: http://tinyurl.com/c9f5cw2
Unread 03-04-2013, 13:09
Thank you! We have a pneumatic push rod to shove the discs, but I will be sure to share your comments with the team. The push rod has not been fully tested yet so your suggestion may be a good solution if we run in to trouble with it tomorrow at pit day. I will also make sure some of the team members reach out to the list of teams that you provided after we are done with the SVC Regional.
Unread 03-04-2013, 13:31
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Good luck at SVR, if there is a webcast I will watch you guys!
Try not to get too discouraged, being a 2nd year team is often world's better than a rookie but there is still a lot to learn. Know what your strengths are and what you can do to help the alliance. While you are at SVR, there will be a ton of great teams there. Try and make time to go talk to 254, 233, 118, 148, 846, or 973 (sorry if I forgot anyone, put yourself down if you want to be on the list!) they will definitely be able to help you guys develop as a program.
Good luck!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 03-04-2013, 13:54
philso philso is offline
FRC #2587
You may want to have a look at the following thread started by my good friend Allen Gregory of Team 3847, especially post #16 where he describes how to make a 1:1 VersaPlanetary gearbox.
www.chiefdelphi.com/forums/showthread.php?t=111360&highlight=small+wheel+shoo ter
The gearbox will take the side loads off the motor shaft preventing premature wear/failure. We originally had a single wheel mounted directly on the shaft of a Mini-CIM. After about 20-30 shots (some with extreme compression), the rear bearing of the motor was worn into an oval and the motor armature dragged on the inside of the magnets. Since we did not want to wait for another motor, we ended up changing to RS550's with a CIM-ULATOR gearbox that I had left over from the previous year. The CIM-ULATOR also took the side loads off the motors.
