Go to Post The proper way to advance forward is by bringing the bottom up, not by limiting how high the top can fly. - artdutra04 [more]
Unread 22-01-2003, 18:05
tareyton
Posts: n/a
Locking Drill Motors
Has anyone looked into locking drill motor gear boxes into gear. Is it the same as last years models?
Unread 27-01-2003, 23:06
Norm M.'s Avatar
Norm M. Norm M. is offline
Norm M. will become famous soon enough
#6 x 0.25
We simply drilled a hole right behind the ring, and screwed in a #6 socket head cap screw. The threads just touch the ring, and hold it in the low speed position. Didn't even open up the second gearbox, just drilled it.
You don't want to be any longer than the 1/4 inch screw, or it will touch some of the rotating elements in the transmission.
Unread 28-01-2003, 02:45
Neill Neill is offline
#0933 (Sallgood)
Neill is an unknown quantity at this point
Simple, Simple solution
To lock the gearbox in gear:
The black plastic piece that holds the drill motor in alignment. This is the flimsy black plastic piece that actually cover the drill motor. Carefully take it off and rotate it 180 degrees. If it was a clock and up was 12 oclock, rotate it to 6 oclock and snap it back onto the gearbox.
When the motor mount is put in 180 degrees backward, it will have a tab that will keep the motor in gear. This tab physically pushes on the white plastic shifter.
No screws necessary!
Neill
Unread 28-01-2003, 06:39
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
We are machining custom aluminum rings to lock it. Once we machine the part and makes sure that it fits, I'll post the dimensions.
-=- Terence
Unread 29-01-2003, 11:58
kyo11103 kyo11103 is offline
#0919 (Not decided)
kyo11103 is an unknown quantity at this point
Send a message via ICQ to kyo11103
is it basically keeping the movable white piece that's on the motor from moving up and down?
Unread 29-01-2003, 12:16
Parks Parks is offline
Parks is an unknown quantity at this point
Rings
We machined rings to lock the drills in high speed. They work really well and so far we have had no problems.
We also machined parts to lock out the clutch mechanisms too. I would not recommend the latter as it is quite difficult to put them back together without causing permanent damage. But it still works fine.
I highly suggest that all teams lock at least their transmission into gear. The shifters slide very easily and can cause much grief.
Andrew Parks
CrescentSchool Robotics
Co-Construction Head and Driver
Team 610
2002 Regional Champs
2002 Engineering Inspiration
2003 Regional Chairman's Award
Unread 02-02-2003, 22:36
Jim Smith Jim Smith is offline
#0279 (Tech Fusion)
Jim Smith is an unknown quantity at this point
We are just using a tie wrap around the drill gearbox body to keep the slider in low. Although as I think about it, there may be some "tie wrap use" rule that I need to go back and check.
Unread 03-02-2003, 04:58
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
We are using a tie wrap also. It seems to be a very good fit just below the gear shift. As for a "tie wrap use rule", we used a mass of them last year, and I haven't run across any rule against them so far in this year's manual.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 03-02-2003, 09:53
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Be careful using just tie wraps to hold the gear shifter in place. In the past (meaning with a different motor and gear box), tie wraps have broken off the shifter causing the gear box to shift out of gear. When the gear box is out of gear, there is no power to the drive wheels. This has a tendency to happen at the worst possible times.
Matt
Unread 03-02-2003, 15:54
Robot-A-Holic
Matt
Thanks for the forewarning, Matt.
Last year we had a ball roller (for picking up soccer balls) covered with conveyor belt material that was stitched together with tie wraps. Normal tie wraps sometimes broke due to the high rpm's of the baller roller and impact of the tie wraps with the soccer balls. However, we found some "premium" tie wraps at Home Depot that had metal locking teeth instead of the usual plastic ones. We never had one of those give way, so teams using tie wraps on their drill motors might want to look for some "premium" tie wraps. (Look inside the hole that the end of the tie wrap is being pulled through, and you will see a little piece of metal that is preventing the end from coming back out.)
Unread 03-02-2003, 16:55
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
If you do not use a disk to lock out the high/low you will run into problems if you go under high loads.
We know this from many hours on using these drills motors. Under high load the gear will run into neutral you will not have a high or a low and your gears will strip.
There is a thread that will tell you the size of the disk you need.
I highly recommend to do this if you are not shifting.
Unread 04-02-2003, 18:52
Dick Linn's Avatar
no team (Synergy)
tie wraps
The high-strength tie wraps are no doubt the Thomas & Betts parts. Good outfit with good quality electrical connectors and related stuff. T & B has been around a long while.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 04-02-2003, 20:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you look at the black piece that has 4 tabs on it and the motor goes through, and then connects to the tranny, you will see that if you rotate that piece, the tabs will keep the shifter from moving. This may not be as permanent a fix as youd like, but it would work.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 12-02-2003, 23:46
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Can someone post a picture of how to lock it by rotating the piece? We are beginning to have the same problem.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
