Go to Post I admit that it isn't practical...but it sure is fun. - Crebb [more]
Unread 22-03-2013, 21:51
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Anonymous functions
I want to do something like this
private ExtendedBoolean b = new ExtendedBoolean(){return m_pressed};
private void run()
    if(b){
        motor.set(1);
but the only way i can do it now is
private ExtendedBoolean b = new ExtendedBoolean(){private boolean get() return m_pressed;};
private void run()
    if(b.get()){
        motor.set(1);
which just looks ugly in my opinion. Is there a good way to do it?
Unread 31-03-2013, 20:24
armgeek's Avatar
armgeek armgeek is offline
Raspberry Pi Enthusiast
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
armgeek is an unknown quantity at this point
Re: Anonymous functions
This is a "good" way to do it.
However, you could make it look a lot "neater" if you changed the "get" method's name to "pressed". That way the if statement would read more like English would.
I enjoy ARM processors.
Looking to earn rewards for working on Open-Source projects that help FIRST? You may be interested in the Summer of FIRST 2013 project. More info: 2013.summeroffirst.org
Also, visit my (sparse) blog: rainingbitsandbytes.blogspot.com
Unread 31-03-2013, 21:06
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
I'm generally of the opinion that little bits of ugliness like that are necessary evils in programming. While I'd love it if everything could be simply and elegantly expressed, reality tends to disregard my desires. However, the example you gave was such that the only non-"ugly" solution was what you suggested, which isn't possible in Java. Depending on what you're trying to do (as opposed to how you're trying to make it look), there might actually be an elegant solution.
I code stuff.
