Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
  #76   Spotlight this post!
Unread 27-03-2013, 15:41
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Re: 7-Shot Autonomous Club
Originally Posted by Alpha Beta View Post
Which defender is attempting this block? I assume the center guy is busy doing a 7 shot autonomous, and not available for the block. That means one of the wing guys needs to attempt it after getting their 3 shots off. Sounds like a nearly equal race to me. I bet 987 wins that race against most bots.
Of course if the center guy is not doing the 7 then even if they block the center line they are still down quite a bit after auto.
If you watch 987's midfield pick up though you notice that drive relatively slowly while picking up the firsbees and have to make several turns and get back into position. Aside from just getting there and blocking the pick up, the only thing the defensive bot has to do is bump 987 just hard enough that they don't perfectly line up when they get back to the pyramid and they won't make the shots. After watching their video their routine is incredibly fast thought so I doubt many teams will be able to stop them, possibly only a couple during eliminations.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
  #77   Spotlight this post!
Unread 27-03-2013, 16:38
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by AllenGregoryIV View Post
Most teams should have it on anyway. The only reason to not go back after your shots is if your with a someone that can center line. Going back helps get you ready for telop anyway in most cases. It makes sense to add it for all matches not just ones against a center line auto. Our default auto does this, currently from the back of the pyramid, we don't play in places with too many good floor loaders yet.
In a vacuum, sure. In a 3v3 match, it's not always best to be the first robot off of the pyramid. It really depends on how your alliance wants/needs to break the starting formation. There are plenty of scenarios where you don't want a robot to be the closest to the opponent at the start of tele-op. For reasons I can't quite figure out, the transition between autonomous and tele-op is one of the most overlooked portions of a match by many teams.
That might be true if it weren't for the fact that 987 has a vision-guided turret that locks onto the goals during autonomous.
  #78   Spotlight this post!
Unread 27-03-2013, 17:01
registered lurker
AKA: Jake McCann
FRC #3501
Nevermind, I guess 987 is pretty much unstoppable
2011-2015: 1678
2016: 846
  #79   Spotlight this post!
Unread 31-03-2013, 10:06
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Add 469, 2337 and 3539 to the list.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #80   Spotlight this post!
Unread 31-03-2013, 11:20
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Add 2415 as well.
  #81   Spotlight this post!
Unread 31-03-2013, 11:30
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Add 624 and 1477 too.
2012 - 2015 : 624 CRyptonite
Team Website
  #82   Spotlight this post!
Unread 31-03-2013, 11:31
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
1477 also had a midline auto.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #83   Spotlight this post!
Unread 31-03-2013, 19:10
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
I'll add 1311 to the list of hopefuls for the 7 frisbee. Got the pick up system working halfway through Smoky Mountains, just didn't have enough time while there to get the tweaks done in programming.
We watched it run on the practice field with the arm to pick the frisbees up about a half inch too high. Software team promised to have that fixed by St Louis, so watch for it there.
2011 Peachtree Regional Dean's List Recipient
2011 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2011 Lemelson/MIT InvenTeams Grant
2010 North Carolina Regional Chairmans Award
2010 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2010 SeaWorld Busch Gardens Environmental Excellence Award
2009 Peachtree Regional Chairmans Award
2008 Peachtree Regional Judges Award
  #84   Spotlight this post!
Unread 01-04-2013, 08:29
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
2415 implimented the 7 disk auto in the eliminations at DC.....and it worked Will need to fine tune it a bit more but we are working hard to improve it.
  #85   Spotlight this post!
Unread 01-04-2013, 08:48
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Updated for all the new additions, let me know if I've missed any. The list is getting quite large, it's awesome to see this many teams accomplishing something awesome like this. Go programmers!
7-diskers:
33
70
118
341
469
624
987
1310
1477
1986
2054
2056
2415
2337
2474
2590
3539
3928
Hopefuls:
1241
1311
1678
3310
  #86   Spotlight this post!
Unread 01-04-2013, 10:17
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
1540 was close to a 7-disk. They hit 6 multiple times in OK City.
It looks like 624, 1477, and 3928 from this list will not be attending champs.
7-disk auto not a guaranteed win, but it has a high correlation. Still expecting it to be a highly valued commodity at champs.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
  #87   Spotlight this post!
Unread 01-04-2013, 10:42
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Put 2175 down for hopefuls we managed to get our 5 working at north star but didnt have time to work out all the kinks for our 7 disk routine. By St. Louis it should (hopefully) be ready.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
  #88   Spotlight this post!
Unread 01-04-2013, 11:35
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Our seven disk auton would have led us to a win if we would have had pneumatics the last match. Unfortunately we used our timeout before the first finals match to allow the other alliance to re-image a crio and our finals luck continued from KC into North Star when we lost pneumatics at the end of the second finals match and didn't have any pneumatics at all in the third finals match.
We found the 7 disk auton to be a highly valuable asset that led us to be selected by the second seeded team in KC and to be seeded first at North Star. I personally expect some of the top seeded teams/alliances at champs to have a seven+ disk auton & can shoot 3's extremely well.
Good luck to all the other teams out there going to champs!
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
  #89   Spotlight this post!
Unread 01-04-2013, 11:59
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We feel like our software is working pretty well at this point for getting from 6 to 7. Our big challenge is discs bouncing out of the goal. We suspect that is because we are shooting in such a fast burst and with such high velocity that the chain in the goal doesn't have time to stabilize before the next disc slams into it. Anyone else had that problem?
  #90   Spotlight this post!
Unread 01-04-2013, 13:29
rlowe61's Avatar
rlowe61 rlowe61 is offline
AKA: Roger
FRC #0624 (CRyptonite)
rlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant future
624 had this issue in their last Semi Final at Alamo. We lost that match by 4 points. Not just our rate of fire of one robot, but the combined rate of the alliance at which the disk hit the chain, and some being deflected out instead of dropping in. I did see one case on the opposite where a disk would have come out, but a follow-on disk pushed it back in.
As stated earlier (by 1986) the 7 point auto may not guarantee a winner, it does make a huge difference in the outcome. Do the math....2 hi goal disk in auto = a full run in tele.....we all have known that since January 5th though.
Roger
1986, Team Titanium, 2011 - 2012
624, CRyptonite, 2013 - ????
