Go to Post first robotics is a ten - Hiteak [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #91   Spotlight this post!
Unread 18-03-2013, 20:59
robochick1319's Avatar
robochick1319 robochick1319 is offline
Robochick1319
AKA: Catherine
FRC #1319 (Flash)
robochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond reputerobochick1319 has a reputation beyond repute
Re: 2013 Peachtree Regional
Originally Posted by sdcantrell56 View Post
The majority of your post was absolutely spot on, but the ending was quite the bold statement. The vast majority of teams use mentor drive coaches and have since I started in this program 9 years ago. Nothing is inherently wrong with that situation.
I agree. This program is about mentors and students working together. So why in the world would you sever that relationship on the field?
17 x UL Industrial Safety Award Winner (2005 - 2015)
2015 Curie Division Industrial Safety Award sponsored by Underwriters Laboratories
2015 Georgia Southern Classic Champion
2010 Palmetto Regional Engineering Inspiration Award Winner
2008 Peachtree Regional Champion
2007 Galileo Division Champion
2007 Palmetto Regional Champion
2006 Boilermaker Regional Champion
  #92   Spotlight this post!
Unread 18-03-2013, 21:05
Originally Posted by DonShaw View Post
Where the refs went really wrong, is they apparently were not aware of the 'Tournament Rules'
The mentors made a major modification to that other robot that was not part of the T08 inspection. It was not reinspected after the modification. It was allowed on the field and continued modification.
Re-inspection is going back to the inspection area, being weighed, check perimeter, check 54" rule
Re-inspection is whatever the INSPECTORS (not spectators) find is necessary for a robot to comply with the rules. They have the as-weighed weight on hand (I know when I was inspecting, both the inspection and the reinspection weights were written on the inspection sheet). If a device that is added appears to be cutting it close, the device can be re-weighed. Perimeter can be checked on-field, if need be.
FIRST needs to install a rule that mentors are not allowed to be a part of the drive team. The drive team needs to be made up of students that are part of the team. it is bad enough to see some mentors doing all the build work, at least let the kids drive and coach themselves.
FIRST has had mentors and students both on the drive team since 1992--21 years of competition. You'd THINK that if there had been an issue, they would have done something. As for the "mentors doing all the build work"... I'm not going to go into the beating a dead horse other than 1) it doesn't matter and 2) even if it did, there aren't exactly a lot of teams that do that.
  #93   Spotlight this post!
Unread 18-03-2013, 21:14
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
The issues with 832 were multiple. It was the mentors from 4059 doing the addition of the blocker and not the kids from 832 from what several of us saw watching in the stands. It was in my opinion poor judgment of an experienced mentor to place 832 is such a position and I do not hold 832 accountable for the mentors actions.
Here is a list of the infractions as some of us saw:
There are several rules that were broken.
R04
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
**as the match was being counted down, 1-2-3, the head inspector saw the robot fall into a position outside of its perimeter
G07 Teams may not cause significant or repeated delays to the start of a match. Noted D. Installing bumpers, or any robot maintenance or assembly, once on the field
** this was clearly violated as they let the team come back on the field in an attempt to get it into a legal starting configuration and/or delay
G05 Confined to Starting Configuration
T07
Any ROBOT construction technique or element that is not in compliance with the ROBOT Rules must be rectified before a ROBOT will be allowed to compete or continue competing. ROBOTS must fully pass Inspection before they will be allowed to compete in Qualification or Elimination MATCHES.
T08
At the time of Inspection, the ROBOT must be presented with all MECHANISMS (including all COMPONENTS of each MECHANISM), configurations, and decorations that will be used on the ROBOT during the entire competition event. It is acceptable, however, for a ROBOT to play MATCHES with a subset of the MECHANISMS that were present during Inspection. Only MECHANISMS that were present during the Inspection may be added, removed or reconfigured between MATCHES. If MECHANISMS are changed between MATCHES, the reconfigured ROBOT must still meet all Inspection criteria.
T10
If a ROBOT is modified after it has passed Inspection, other than modifications described in T8, that ROBOT must be re-Inspected.
T07, T08, T10 were violated.
Feedback is welcomed.
I'm going to start this off by saying that 832 and 1683 were AMAZING alliance partners. I can say that we all had a great time together, 832 and 4509 were pit-mates to start with, and throughout the regional we were exchanging tools and parts. All 3 teams worked hard together, lending tools, parts, and batteries, to make our way through the eliminations.
While it may have seemed that way from the stands, the mentors from 4509 were NOT the only ones doing the additions. There were multiple students (from both 4509 and 832) working together to modify 832's robot.
And, I might be wrong here, but it seems as if you feel that 4509 bullied or otherwise forced 832 to make the modification. This is not true at all. 832 was enthusiastic to make the change and were extremely helpful, in both finding materials, tools, and labor. (As were the students from 1683)
As for delaying the game: The opposing alliance had not placed a single robot on the field yet. All of us were prepared to go on.
As for inspection: The robot inspectors WERE PRESENT DURING THE ADDITION. We were using a tape measure, and the inspectors asked about the starting configuration, and the students from 832 demonstrated the ability to get everything inside the starting configuration. As was previously stated, the pneumatics slowly caused the robot to possibly exit that configuration (Note: This was NOT the reason they were disabled. They lost power to their radio, they were not disabled by the field crew or referees).
As for no mentors allowed to be on the drive team: That's a different conversation for a different time. I'm sure you can find multiple different threads on this subject if you search on Chief Delphi.
And of course, congratulations to 3489, 4026, and 4080 for the victory. Those were some intense final matches, we were proud to have put up a good fight, and lost, to such a great alliance.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
  #94   Spotlight this post!
Unread 18-03-2013, 21:50
GeorgePBurdell GeorgePBurdell is offline
GeorgePBurdell is a name known to allGeorgePBurdell is a name known to allGeorgePBurdell is a name known to allGeorgePBurdell is a name known to allGeorgePBurdell is a name known to allGeorgePBurdell is a name known to all
As the LRI for the event, perhaps I can offer some additional information and input.
While I agree that it was other than members of 832 who made the modifications, it was 832's robot - and as such, they are responsible for whatever is done in their behalf. If they are not in agreement with what is being done, they shouldn't allow it.
R04
And this is the main issue here - when initially inspected, the robot demonstrated the potential to exceed the established frame perimeter - but also demonstrated a means for constraining itself to a legal configuration. The team was cautioned several times in que as the potential was again noticed by inspectors, but as the team confirmed their intent of using a pre-charged pneumatic system to constrain the system, it was allowed onto the field.
When called to the field for an opinion, I informed 832 that they were outside of the frame perimeter, and as such, were not in a legal configuration. The machine was manually pushed into the elevated configuration and an attempt made to secure it with duct tape. While it was placed in a legal configuration, as noted above, it did sag to a position outside of the frame perimeter just before the match began - and the robot was allowed to operate.
This is a referee call - and while I can't disagree with this opinion, it is a judgement call for the refs. I do know they were ready to pull the team from the field but did make the call to allow the match to proceed. It was a stress situation for all and it is always easy to Monday morning quarterback, they made a tough call - and I must support that call.
T07
T08
T10
The robot was not modified in secret - it was done in full view of all in the stands. The inspector on the field did look at the change and found it within the rules. As the modification was primarily a deflector device, within the height limits of a legal robot, and capable of being positioned inside of the frame perimeter, it was allowed. The issue was the inability of the team to actually get into that configuration. When I saw the modified robot I too agreed that it was a legal modification. Perhaps not as formally as might have been desired, the robot WAS reinspected after the modification. I will concede that T08 was not closely followed - but then, many teams make similar minor modifications to their machines during the event. I personally was consulted on multiple occasions by teams who wanted to make "modifications" to their initial configuration. These were allowed as long as the robot remained within the requirements of the rules.
As noted above, the machine WAS reinspected.
Yes, you could take that position - and if this is the official FIRST decision, I take full responsibility for allowing a less "stringent" re-inspection process. It was my opinion that the full re-inspection was not warranted and that doing so would unduly delay the match - and/or remove a contender from their opportunity to compete. If the decision was wrong, it was mine and I'll take the responsibility for it.
Jeff Rees
LRI Peachtree Regional
FIRST needs to install a rule that mentors are not allowed to be a part of the drive team. The drive team needs to be made up of students that are part of the team. it is bad enough to see some mentors doing all the build work, at least let the kids drive and coach themselves.[/quote]
Jeff Rees
FIRST Ambassador
  #95   Spotlight this post!
Unread 19-03-2013, 07:22
MikeReilly's Avatar
MikeReilly MikeReilly is offline
FRC #4509 (Mechanical Bulls)
MikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud of
Thanks George, and others, for input. As the Teacher-Mentor of 4509 we will certainly listen to the constructive criticisms. I can guarantee that we believe in the principles of FIRST, and we all want to make the best opportunity for our kids and community, including any necessary improvements and changes. It was a fun season, and my students can't wait to meet today to get ready for next year, and that's so cool!
Congrats to all who participated, to all who were inspired!
Mentor for Rookie Team 4509, Formerly with 1771
  #96   Spotlight this post!
Unread 19-03-2013, 09:27
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
As much as I hate to prolong this debate, as one of the mentors that "modified another team's robot", I feel I need to respond.
Team 4509 was the alliance captain for the fifth seed alliance. We chose 832 as our third pick because they could score in autonomous, and because they had a strong drivetrain to play defense. They performed exactly as we wanted them to throughout the elimination matches. Once 4080 started their full court scoring, and won the second finals match, we knew we needed a strategy to stop that scoring if we wanted to win. As alliance captain, our drive team suggested that they add a tall blocking feature to their robot so they could continue their defensive role. The students from 832 came up with the solution and the materials to implement that solution (a piece of 1/4-20 threaded rod, a piece of corplast, and a roll of duct tape). What most people in the stands probably couldn't see was that in that second match, 832's robot was badly damaged. The entire electrical panel was falling out the bottom of their bot (FRC competition is fierce). So while two of the students from 832 held a 150 pound robot 4 feet off the ground for five minutes, two more were seated underneath the bot working to secure the electrical panel. That didn't leave many hands to install the threaded rod and plastic. I and the other mentor that helped only acted as dumb labor. I held the threaded rod, and did turn a wrench, and the other mentor did apply duct tape, all with the help of students from 832. The idea, the materials, and the directions came from 832.
There are those that believe that mentors should have no role in FRC other than to answer questions. While I don't want to flog that deceased equine in this thread, I don't feel that way. I believe that mentors should mentor. I often work with interns at work. If I only answered questions, did not make suggestions or help out at all, I would be failing as a mentor for that intern. The purpose of a mentor is share his or her experience and expertise with someone who doesn't have that experience or expertise. I want the kids to be inspired, and to do their best. If there is a way to do just a little better next match, they should strive their hardest to make that improvement. The strive for excellence is a major part of FIRST, and should not be discouraged.
Having said all of that, I want to re-iterate that our team had a blast at the competition, learned a great deal, and were inspired. We do not regret any of our choices in the selection, and could not have asked for better partners or opponents. Thanks to all that participated, volunteered, and officiated. you were all awesome.
Former Mentor Team 1771
Former mentor Team 4509
  #97   Spotlight this post!
Unread 19-03-2013, 09:35
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This should be spotlighted rather than seen as re-hashing an old debate. Well put.
GitHub
  #98   Spotlight this post!
Unread 24-03-2013, 15:36
sbrierty's Avatar
sbrierty sbrierty is offline
AKA: Steve
FRC #0624 (CRyptonite Robotics)
sbrierty is a splendid one to beholdsbrierty is a splendid one to beholdsbrierty is a splendid one to beholdsbrierty is a splendid one to beholdsbrierty is a splendid one to beholdsbrierty is a splendid one to beholdsbrierty is a splendid one to behold
Team 624 misplaced a large yellow Dewalt bag with game pads, joysticks, and various other cables. We also had a laptop bag with a black dell laptop and power supplies go missing.
We think these were either left behind in the loading dock area or maybe they were mistakenly grabbed by another team.
Does anybody who was at Peachtree happen to have some info on where these ended up or who we could talk to about a "lost and found" from the Gwinnett Center?
Thanks for the help!
1997-2000 - Student: Team 141
2001-2003 - College Mentor: Team 461
2011- Mentor / Coach: Team 624
  #99   Spotlight this post!
Unread 01-04-2013, 11:36
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Hey does anyone any videos of the elimination matches or know where to find them? We were eliminated in the quarter finals but wanted to have some videos to show our school. Thanks!!
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
  #100   Spotlight this post!
Unread 01-04-2013, 12:22
I-DOG's Avatar
I-DOG I-DOG is offline
Texas Tourist
AKA: Austin Vaughn
FRC #0624 (CRyptonite)
I-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to behold
Well 624 has match videos of our robot on our website. If you were in any of our matches you can find them at http://gallery.team624.org/CurrentSe...5566&k=XnGbtgz
Team 624 loans their green capes to their alliance partners during Eliminations.
Are you going green this competition season?
These teams did: 118, 233, 987, 1477, 1902, 3008, 3015, 3476, 3997
CRyptonite 624 - 2008-2011: Student
CRyptonite 624 - 2012-2014: Scouting & Pit Outreach Mentor
RoboRaiders 1817 - 2011-2012, 2014: Strategist & Scouting Mentor
The Outlaws 4717 - 2013-2014: Mentor
  #101   Spotlight this post!
Unread 01-04-2013, 13:12
Rynocorn's Avatar
AKA: Ryan Jacobs
Great thanks! Yeah you guys beat us in the quarters unfortunately. but I was really intrigued by your robot and it remains to be one of the best I have gotten to see up close this year. Hope to see you guys there next year as well!
  #102   Spotlight this post!
Unread 03-04-2013, 14:39
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
We (Category 5) posted a Youtube playlist of our matches, Qualification & Elimination.
  #103   Spotlight this post!
Unread 03-04-2013, 14:43
AKA: Kevin Thorp
Does anyone know the name or number of the FTC team that had their robot set up in the lobby, near the entrance to the Pits?
  #104   Spotlight this post!
Unread 03-04-2013, 17:07
meibnotu's Avatar
meibnotu meibnotu is offline
AKA: Mei-Jing Bernard
FRC #5332 (Toaster Tech)
meibnotu is an unknown quantity at this point
I believe you are thinking of the Robobugs, though I could be wrong. They were the ones wearing the bright green shirts.
  #105   Spotlight this post!
Unread 03-04-2013, 18:12
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
Circuit Runners.
John Fogarty
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
