Go to Post The highest seeded alliance is always placed in the red zone by the computer. In fact, its a great communist conspiracy to mold the mind of teenagers into equating Reds with winners. - Btower [more]
Unread 01-04-2013, 13:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Battery failures?
At the CT regional team 95 experienced two battery failures. The first was a total dead short or broken tab. The battery failed a load test and measured around 0.001-0.005V with a multi-meter. No chargers or connectors were wired backwards and there was no obvious issue with any of the charging ports. After our final match the battery came out with acid slowly spraying out of the cap/seal on the top of the battery.
Thanks a million to 195 for giving every team a spill kit with a box, gloves, and baking soda. We used ours to keep a potentially dangerous situation contained.
Now, both of these batteries were new in 2013, and are the only two battery failures I've experienced first-hand. It was also the first time we used these chargers from AM.
Have any other teams seen failures like this? Related to 2013 batteries or those chargers? Could there be another cause?
Thanks in advance.
Unread 01-04-2013, 13:23
Racer26 Racer26 is offline
Re: Battery failures?
I've seen many teams over the years pick their batteries up by the leads. This is a dangerous practice. It causes internal stress on the tabs and can lead to failures like this. Any chance that happened here?
Unread 01-04-2013, 13:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'd like to think not. We teach our students that batteries are to be picked up by the case, not the leads.
Neither of the terminals on the dead battery were visibly loose or cracked, FWIW.
Unread 01-04-2013, 14:11
Do you provide a handle on each battery to remove the temptation?
Unread 01-04-2013, 14:12
Gregor's Avatar
Happy Birthday! Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Do you have an example of even one team who does this?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 01-04-2013, 14:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
No, we do not. I watched our student who was in charge of batteries handle many swaps without once using the cables as a handle. I have a high confidence that this was not the issue.
Unread 01-04-2013, 14:20
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Would it even be legal to have something other than the leads and Anderson Connector attached to the battery? I think not.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 01-04-2013, 14:33
AdamHeard's Avatar
Lead Mentor
On the connector side we use the Anderson Handle meant to bolt to the battery for a few seasons now. They're really convenient.
Unread 01-04-2013, 14:36
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Do you have a link or PN for those?
Unread 01-04-2013, 14:45
We have a couple of battery carrying handles that see occasional use, but not as a regular practice.
Unread 01-04-2013, 17:03
There are two consistent failures that I have seen over the years. A quick inspection of the case will usually show some evidence of being dropped. This is easy to pick out if it occurs on a corner. When a battery is dropped the internal plates of the battery can shift within the cell. With the use of absorbed glass mat, I believe this might lead to a shorted cell. Once the cell shorts, significant heat builds up withing the cell causing the leaking acid and bubbles you experienced. I also have a theory that in the event of a either a failure for a normal charger, or the use of a high current charger, the plates will deform under the high current and also cause an internal short. To achieve a zero volt output, the battery would have to electrically open. This can occur if the connector plates between cells should break or melt open or the terminals become dislodged internal to the battery. The battery is manufactured with round terminals. Depending on the external terminal type ordered (there are several), the terminal is placed down on the round terminal internal to the battery and then it is flow soldered. To finish, a red or black epoxy is then added to seal the top of the battery. It is possible to break the solder joint (usually by lifting by the cables) and still not find any movement in the terminal.
Unread 01-04-2013, 17:15
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
At the CT regional team 95 experienced two battery failures. ...
I'm curious as to whether the batteries were both EnerSys batteries, or both MK batteries, or one of each?
PS: Congrats on a great performance at the CT regional! At the end of GSR, I thought it would just be a matter of time before The Grasshoppers would be making the 30-point climb regularly!
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 01-04-2013, 17:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
They were both from FIRST Choice IIRC, though the totally dead battery has already been disposed of, so I can't confirm brands.
Thanks! It was a rough road, but we got there in the end.
Unread 01-04-2013, 17:33
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Team 1806 has done so for years now.
Our original handles were 2 zip ties that wrapped around the casing that linked together a cable covered in plastic tubing.
This year our battery handles are a strong blue woven material attached to the battery top by a mounting plate that bends into the normal handhold for the battery. The mounting plate also contains battery identification information, as well as a QR code that links to the material information and proper disposal information for the battery.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 01-04-2013, 17:58
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
1983 has fabric pouches for each battery with a handle.
