Go to Post FIRST isn't about building robots. I know. But I also know that Inspiration comes in a lot of flavors and I, for one, believe it is a lot easier to inspire my kids when we set "playing after lunch on Saturday" as a worthy team goal. - Joe Johnson [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 06-03-2013, 18:23
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Re: pynetworktables: python wrappers for NetworkTables
Mandatory update March 4, 2013
This is a mandatory update for C++ teams and MUST be installed before competing. Install this build on your development system and rebuild your program. Then deploy the new resultant .OUT file to the robot. The fixed issues are:
1. Adjusted the packet size of data transmitted with NetworkTables (and SmartDashboard) to avoid excessive number of TCP/IP packets.
2. Updated minimum CAN Jaguar version to 101 as per rule 61-4.
3. Added a fix to the Preference class to make it more robust.
4. Subsystems now only report changes in Test mode (LiveWindow updates)
5. Removed some unnecessary initialization of some variables.
6. Added code to make the Scheduler class sendable so that it can be written to the SmartDashboard.
7. Fixed an issue with numeric arrays in NetworkTables.
8. Fixed an issue with invalid and/or null pointers in LiveWindow code causing crashes in threaded robot code.
The update can be found here: http://firstforge.wpi.edu/sf/frs/do/...ate_rev_362 2
Are you going to update your forked Github to take this in to account?
Unread 06-03-2013, 18:56
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
The RobotPy WPILib repository (which is what pynetworktables uses) has already been updated with the latest updates.
Unread 10-03-2013, 14:17
djdaugherty djdaugherty is offline
Mrs. D.
djdaugherty is on a distinguished road
We are using an Odroid running Ubuntu and we have a script to start up automatically. The Odroid is booting before the cRio and trying to connect with the Networktables. This is causing the cRio to not boot at all. Is there a way to check if the network tables are running? Or is there some other way to interface the Odriod to the cRio?
Thank you
Unread 11-03-2013, 13:24
virtuald's Avatar
RobotPy Guy
What do you mean by this, and what language are you using on the cRio? Is it your program that's crashing? What happens when you don't have the odroid running? If your program is running on the cRio and then the odroid starts, does it crash immediately? More details needed.
Unread 01-04-2013, 14:24
virtuald's Avatar
RobotPy Guy
FYI, if you were using pynetworktables, update to the latest version of it/RobotPy. There were a number of stupid bugs that would cause crashes and data inconsistencies. The issues should be fixed now.
Unread 02-04-2013, 13:47
virtuald's Avatar
RobotPy Guy
Binary versions of pynetworktables for Windows are posted on the FirstForge project page for RobotPy. http://firstforge.wpi.edu/sf/go/proj...ynetworktables
