Go to Post That's not duct tape as adhesive, it's duct tape as decoration! :p - Don Knight [more]
Unread 01-04-2013, 23:02
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Sheet Metal Chassis
I am currently designing a sheet metal chassis for next years competition, and would like some help. I have a couple of questions:
1: What thickness of sheet metal should i use? I currently have .060", but I am not sure what thickness would be the optimum balance between lightness and strength.
2: Should I use a round or cross hatch style lightening pattern?
Thanks so much
http://https://m.facebook.com/?refsrc=http%3A%2F%2Fwww.facebook.com%2F&_rdr#!/photo.php?fbid=537651836285195&id=100001211502651& set=o.141923939241066&relevant_count=1&ref=bookmar k&__user=100001211502651<<that is a photo of my current iteration
Unread 01-04-2013, 23:12
2789_B_Garcia's Avatar
2789_B_Garcia 2789_B_Garcia is offline
AKA: Bobby Garcia, AKA: #Catalyst
FRC #2789 (TEXplosion)
2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future2789_B_Garcia has a brilliant future
Re: Sheet Metal Chassis
We originally designed a 3/32" sheet metal frame with the intention of holding it together with holes tapped for 10-32's but then our sheet metal fab backed out on us...we scrambled to re-design for something we could build in-house with the tools and machines we had and settled on 1/16th" aluminum supported by 1/8" & 1/16" sq tubing, and it has worked out rather nicely for us...we play primarily defense and our robot has gotten and given quite a bit of punishment this year, and is still holding strong.
For the 3/32" design, I think we had triangles for the lightening pattern, if you'd like to see the design, let me know, and I'll get a screenshot from the kid that designed it. We actually had two designs...one for a 6-wheel belt drivetrain and one for a four wheel drivetrain.
I saw someone's signature on here say: "A good driver always beats a good robot," and I thought that was rather clever, so I'm using it as my signature.
2014 Texas Robot Roundup Winners (with 624, 118 & Pearland Robotics Pre-Rookie Team)
2014 Texas Robotics Invitational Finalists (with 148, 3735 & 3999)
2014 Dallas Regional Quarterfinalists (with 2587 & 5057)
2014 Alamo Regional Finalists (With 2468 & 148)
Unread 01-04-2013, 23:13
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Hey there,
33 used .050 this year. Your 0.060 should work fine so long as its properly designed. Lightning pattern is up to you; I like circles. My only recomendation is that you leave some holes large enough to get a hand through. You'll thank yourself later when you have to fix something.
Good Luck!
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 01-04-2013, 23:21
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
I prefer .090, but .060 should serve you well. I'm 99% sure that 67 uses that thickness of sheet on all of their bases, and 33 uses even thinner sheet on theirs (.050). Much of the strength of a bent sheet metal part comes from the amount and location of bends made. If necessary, extra structural members run through the middle of the base can make the frame even more rigid.
The lightening pattern is a matter of personal preference. I have seen both triangle based and circle based patterns done effectively; however, with .060 I don't see it necessary to do much lightening.
Also, I recommend using 3/16" rivets throughout the drivetrain, as they can be swapped with a 10-32 screw if you ever deem that necessary. 1/4" rivets are a bit overkill.
@others, If i'm wrong about anything I've posted here, please let me know
Unread 02-04-2013, 00:03
Gregor's Avatar
Happy Birthday! Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
We used 0.063 sheet with 3/16 pop rivets. We had conservative lightening on the side rails, and no lightning on the bellypan, and the bare frame weighed 9lbs.
Love it, and would do it again.
If you plan on using sheet, do yourself a favour and get a pneumatic riviter, it will save you a lot of time and effort.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 02-04-2013, 00:33
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
What are you using to make your lightening holes? Do those flanges around the holes add any rigidity to the chassis?
Thanks
Unread 02-04-2013, 06:08
FRC #1836 (MilkenKnights)
I know a lot of experienced sheet metal teams use very thin sheet(.060" thick) for their drives. However, if this is your first experience with sheet I would recommend using something thicker(like .090" sheet). A pocketed sheet drive is going to be plenty light already, and you don't want to risk a drive breaking in the middle of competition. Once you have more experience you can use thinner sheet. If you have a sponsor with a punch making the parts a circle lightening pattern is going to be preferable. It will make for less time machining and happier sponsors.
Unread 02-04-2013, 08:57
scott scott is offline
Free Agent
AKA: Scott Ray
scott has a spectacular aura aboutscott has a spectacular aura about
We have typically used .090" with a circle based pattern to help decrease the time spent from our sheet metal sponsor. With this age of bumpers I'm sure you could get away with using a thinner material, but nightmares of straightening frames from 2003 still haunt me...
2015 INDY DISTRICT CHAMPIONS (1501 & 829)|2015 PURDUE DISTRICT FINALIST (1747 & 5402)|2015 IN STATE QUARTER-FINALIST (3484 & 461)|2014 IRI QUARTER-FINALIST (624, 33 & 2481)|2014 CORI CHAMPIONS|2014 QUEEN CITY REGIONAL CHAMPIONS (16 & 2665)| 2014 QUEEN CITY XEROX CREATIVITY IN DESIGN|2014 CROSSROADS QUARTER-FINALIST (3494 & 3940)|2013 CROSSROADS FINALIST (1288 & 1756)|2013 QUEEN CITY REGIONAL CHAMPIONS (379 & 1985)|2013 QUEEN CITY EXCELLENCE IN ENGINEERING AWARD|2012 QUEEN CITY QUARTER-FINALIST (379 & 1706)|2012 SMOKY MOUNTAINS QUARTER-FINALIST (1501 & 1261)|2012 SMOKY MOUNTAINS XEROX CREATIVITY IN DESIGN|2011 CAGE Match FINALIST (461 & 1760)|2009 WISCONSIN QUARTER-FINALIST (1024 & 2826)2008 BOILERMAKER QUARTER-FINALIST (1000 & 201)|2007 MIDWEST FINALIST(1000 & 648)|2007 MIDWEST XEROX CREATIVITY AWARD|2006 BOILERMAKER ENGINEERING INSPIRATION|2005 Creator of IRI Vex, "Enter-Action"|2005 CHAMPIONSHIP RADIOSHACK INNOVATION IN CONTROLS|2005 CHAMPIONSHIP GALILEO FINALIST(1108 & 492)
Unread 02-04-2013, 10:02
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
What alloy do you all use and what radius do you bend the angles? Looks like a large radius in the pic.
Thanks
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 02-04-2013, 11:46
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Glenn,
.090" 5052 is a good place to start. .060" thick works also if designed properly with folds and gussets to strengthen the part.
.125" thk works good if you want weight down low to keep a low COG.
So it all depends on what you are trying to accomplish with your design. Pick the material that will compliment your design.
For your lightening pattern I would ask what the sponsor has in terms of equipment.
NC punching the parts I would stick to a round staggered perf pattern
NC Laser or Water Jett go with the diamond or round
NC router I would go with a light guage material and skip the lightening.
Keep costs in mind. Make it simple and clean. That is what I always tell my kids. Try to keep the part count down. It makes them think of better ways to design if they have a limited of the number of parts/time they can use to build a robot.
Here is a tip to help you get the correct flat pattern out of Solidworks
Use:
.100 for your bend deduction BD for .060 " material
.195 for .125"
.145 for .090"
use .035 for the bend radius on 5052
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 02-04-2013, 12:20
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
<3 Sheet Metal Chassis <3
Well I prefer to use 1/8" aluminum for the bigger, longer outside frames. Reason is that these are your main frames for your chassis, you don't want to lack of any strength in it.
I used 1/16 for smaller parts in my chassis that weren't going to be big enough to worry about too much strength, so you can feel free to use a mixture of any sizes.
I prefer to use Triangles as lightening patterns. They keep your chassis strong while easily
Here are two examples of my chassis' using 1/8th material and triangles. The first chassis was actually built as an of season project, and was a very good and strong chassis.
Something additional that we did to that chassis was get the corners of each flange welded shut, that way it was harder for them to come apart and they were very strong.
Also another thing I have learned is that reversing the outside plates flanges, to go outwards rather then inwards. It makes it easier to assemble (because you don't add flanges on the side of the front/back plates), and becomes slightly lighter (again because of the flanges you remove).
Here is an example of that
Have fun with your chassis design and make sure to post your results!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 02-04-2013, 14:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Somewhat on topic-ish.
Did you guys buy your own dimple die set or did a sponsor do them?
Unread 02-04-2013, 18:15
Gregor's Avatar
Thanks
The sheet metal is all cut on a laser cutter. The "flanges" are dimples made from a dimple die. They add enormous strength to the overall chassis.
Thanks
The metal is all 2024 T-3 aluminium. Our sponsor said that a 0.25 bend radius should be used for that alloy and thickness. We would stick to 5052 in the future, there were cracks at almost every bend point. The metal was very brittle.
Everything was done at the sponsor's shop, laser cutting, bending, and dimpling.
<Since 2011
Unread 02-04-2013, 18:17
mman1506's Avatar
no team (WARP7)
Could you do all this with a normal sheet metal brake or do you need a press brake?
Unread 02-04-2013, 18:21
Gregor's Avatar
Not sure what you mean, but ours was done on a CNC break.
<Since 2011
