Go to Post Chief Delphi's Greatest Hits vol. 47: Overreactions to Q&A responses - Lil' Lavery [more]
Unread 01-04-2013, 23:17
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Supershifters and Mechanum wheels
the team I was on had some trouble with driving this year (it wasn't great but it did the job). Having mecanum wheels would have helped greatly in lining up our robot to grab/shoot frisbees and we also had some trouble with speed and getting blocked.
How well does a set of four mecanum wheels deal against being blocked? and how fast could a set of mecanum wheels get a robot up to compared to standard wheels?
Are supershifters worth it? and how would a supershifter on each mecanum wheel do (assuming the money didn't matter)?
thanks! -3734
Unread 01-04-2013, 23:23
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Supershifters and Mechanum wheels
What were the details of your team's drive train this year? Also, what are the details of where you had trouble lining up? If you had trouble lining up with the feeder station slots, it could be that having a wider target for your human players to feed the discs into would be the solution rather than altering your drive system, for example.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 01-04-2013, 23:25
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Before you pursue an entirely new drivetrain, let's break down your current one. What setup were you using? (Gearboxes, number of wheels, which wheels, wide configuration or long configuration, etc). Could you also provide us some video of the robot driving? There's more you need to look at before making a decision such as moving towards an omnidirectional drivetrain. The kit drivetrain is one of the easiest and most powerful drivetrains out there.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 01-04-2013, 23:52
FRC #3734
Please keep into consideration that our season is over (we had a good run, first time getting picked) and we are currently working on a new frame from scratch (preserving this years bot) in order to test drive trains. We also have a good amount of money left in this years budget that we can most likely buy the gear boxes (we already had the wheels) especially considering that they are reusable.
This years drivetrain was a 6 wheel tank drive on the andy park standard KOP frame using the long formation with omni wheels in the front and back of the bot, and kit standard wheels from andymark (highgrip) in the middle, all 6 inch. we had 4 cim motors on two cimple boxes. We added the omni wheels because it could not turn for its life on carpet. It worked well in competition, as it could run very well when it was just going back and forth collecting and shooting frisbees. I was pleased with it because last year we were basically a sitting duck with our 6 highgrip wheels powered by 2 cims.
The problems came up when we had two line up our bot to shoot/load frisbees. Unfortunately our bot could not change the firing angle at all, and had no sensor, so the shooting had to be lined up by shooting very specifically at the bottom of the pyramid. It worked great in auto mode, but telop was tricky because with tank drive it was impossible to make slight adjustments to alignment. Especially with lateral movement.
The feeding was the same thing, but easier because we could communicate, still took way too long. I will admit our feeder could have been much better designed. On the optimistic side, lining up on the pyramid was easy and took no moving parts at all for climbing.
I don't have any great videos, but we have some O.K. ones on our website with more elsewhere that need to be uploaded. there really are not any obvious problems at first glance, but it is defiantly not fast, and it does not block/handle blocking well.
Unread 01-04-2013, 23:58
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Shifters are great, but I'd have to recommend against Mecanum wheels for the usual reasons. You can find many threads on the subject. Many of the top teams use 6 or 8 performance wheels. I know 254 almost always uses the same drive train with eight 4" wheels (this year maybe six because of reduced size). Many other teams have the same setup too, unless they have a good swerve drive like 1717 last year.
Unread 02-04-2013, 00:03
JohnFogarty's Avatar
AKA: @doctorfogarty
We used 4 AM SuperShifters on our Mecanum prototype base, but we decided it wasn't something we'd ever use in competition unless another game like LogoMotion came about.
John Fogarty
Unread 02-04-2013, 00:11
http://youtu.be/LlSoEfAW47I?t=3m33s
Unread 02-04-2013, 00:25
AKA: noops
Rather than looking at a new drivetrain, let's analyze what was going on with your setup. You said the standard kitbot drivetrain was not turning on carpet. Where was your center of gravity in this setup, and are you sure you dropped the center wheels in the 6 wheel drive by 1/8"? Make sure your center of mass is low and over the center two wheels. If this still does not remedy your issues, look into going to Toughbox gearboxes, or something with a higher ratio. I think the CIMple boxes house a 4.3:1. This ratio is meant to give you a lot of speed, but not much torque. You might need to drop down to 8 or 9:1 in your gearboxes. The toughboxes should be enough, even with high traction wheels, to allow your robot to turn smoothly, given that the center wheels are dropped 1/8" and the center of mass is low and over the center wheels. This is in fact what the kitbot on steroids project by Team 1114 is based on.
Alignment issues are a pure driver practice thing. It's much easier to get your driver to practice lining up in one sweet spot (and with the goal this year being so wide, you don't need to exactly have only one sweet spot) than it is to invest time and resources into an omnidirectional drive, only to use it just to strafe a couple of inches every match. Try expanding your feeding are on the robot. My team's loading mechanism on the robot is the length of 2 frisbees. We had very rare issues with lining up to the feeder slot, and we ran a standard 4 wheel wide drivebase.
Unread 02-04-2013, 00:26
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Building a competitive drive train is about building an efficient, stiff and robust base with the correct math done regarding gearing. There are resources a-plenty for learning to do this.
At 159, we had such incredible success with our traction drive last year, that it's unlikely we will ever use a drive without traction wheels.
As per lining up...
I build bots with a philosophy that if you can't line it up with a tank drive and a few minutes of practice then your mechanism is broken and not your drive train.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 02-04-2013, 00:37
FRC #3734
Sorry about the "H" I though that I had fixed all of them.
What was wrong with the mecanum super shifter combo? or what was wrong with just the mecanum wheels?
if one were to make a swerve drive, what ratio would be best for the speed/power combo (as I saw a lot of options on andymark)? I feel like part of our shoving problems came from our omni wheels (so that takes care of its self). I am tempted to try and make one as a summer project.
could you please go into team 254's drive-train, or at least just something to use as a search query.
thanks so much! -3734
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Don't underestimate the power of the kitbot. 2013's new and improved kitbot performs better than many, if not most, custom drivetrains and, possibly most importantly, is quick and cheap, so you have more time to spend on developing other systems for the robot.
Additionally, with simple modifications, such as building 1114's kitbot on steroids, adding higher traction wheels or perhaps shifting transmissions.
Personally, I haven't played enough with Mecanums enough to give a verdict on their performance, but from what I've seen, a decently constructed, well driven tank drive can often outperform all but the best Mecanum drives in everything but going sideways. When considering Mecanum, you have to decide if going sideways is worth being slower and having less traction.
Post #254! Go Poofs!
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 02-04-2013, 00:42
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Solid philosophy.
In the past few years we have used both AWD robots with traction wheels and robots with mecanum drives. The team has tended to favor mecanum for its alleged maneuverability strengths. I think this is a bit of a fallacy, as we haven't been able to drive or align the mecanum robot any better than the AWD versions.
Building a mecanum robot is a great learning experience from a build and a programming standpoint but don't expect a huge boost in driver performance. It isn't as maneuverable as it looks on paper.
Unread 02-04-2013, 00:44
AKA: noops
I personally have something against mecanum wheels (insert dead horse to be beaten), but what I'm really trying to get at is to start simple and learn from your mistakes. It's easy to jump around ideas and only implement them halfway, but you learn more about engineering and gain more experience when you iterate your design to the best possible iteration. Do the changes I mentioned with your kit drive before exploring swerve and mecanum. If a team can't master the kit base and the standard 6 wheel drive base, they certainly don't have the resources or time to master an omnidirectional mecanum or swerve drive. If you want to learn more, A simple search in the whitepapers for a drivetrain design can help.
Unread 02-04-2013, 00:49
Well we got rid of the "h". Now if only we could get rid of that extra "c" :-)
Unread 02-04-2013, 01:02
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Mecanum is good for when you need an omnidirectional drive system but don't have the time/resources/money/programming team to devote to swerve or butterfly drive. For example, we didn't make the decision to go mecanum until just before the start of week 2 during the build season, after realizing that an omnidirectional drive could be very advantageous.
I'd take a mecanum kitbot with basic WPI code over a hacked together and poorly programmed swerve drive any day.
If you really, and truly need an omnidirectional drive train, I'd start with mecanum and plan to go to swerve or butterfly later.
If you don't, look at some of the tank drives with traction (and sometimes omni) wheels around FRC, such as Team Titanium's Tremendous Turning Twinspeed Tank Transportation in use on this year's robot.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
