Go to Post We don't tell new mentors about the Mentor VIP Adults Only Lounge, you'll get your key if we approve. We have leather couches, flat screens, and free corndogs in there. - Monochron [more]
Unread 02-04-2013, 01:08
Re: Consistent Encoder RPM Issues
Originally Posted by meltbox360 View Post
Without recompiling, just setting everything up I am getting a spread of 1100 rpm at max speed. Between 5200 and 6300 rpm so the same issue as the encoder class with pretty much the same spread.
I think setting the FPGA sample ring buffer will bring that down to an acceptable level without introducing undue phase lag. If you can get a good signal you may be able to use the very simple bang-bang control.
