Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 02-04-2013, 01:35
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: VEXPro - After the season
Originally Posted by topgun View Post
The biggest issue we had with a couple of them was we stripped the hexagon socket set screw that tightened onto the motor shaft. I haven't determined if this was the students using worn hex keys, incorrect size hex keys, or what. If we tried to take the set screw off, the internal hexagon socket became damaged so that we couldn't remove the set screw. Maybe a different quality set screw would eliminate this problem.
We used several VP gearboxes this year. On some (but not all) we found that an M2.5 hex key fit better than a 3/32", which is the size indicated in Step 3 on p. 8 of the VP User Guide. Probably a higher quality set screw would help fix this variation.
Richard Wallace
since 2003
