Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Unread 02-04-2013, 18:34
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: Sheet Metal Chassis
Originally Posted by Gregor View Post
Not sure what you mean, but ours was done on a CNC break.
sorry I meant a manual break like this
versus a hydraulic press break(V shaped Die)
Unread 02-04-2013, 19:20
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Originally Posted by AlecMataloni View Post
I'm 99% sure that 67 uses that thickness of sheet on all of their bases...
Correct...all our drive bases since 2008 have been made out of 0.060" 5052 AL.
Other than some bashed in corners, we've had no issues with strength or flex. Well, except for when we fell off the top of the tower with our practice bot...directly onto the front of the frame. One side was 0.5" shorter than the other.
All our panels are designed with a 1" flanged on top and bottom. Then we design in a "mid-plate" somewhere (depending on packaging) in the chassis to help tie the right and left side together. We usually cut our some additional gusset plates for any corner that didn't have one designed in.
We typically tie in the other subsystems (shooter, lift, arm, etc..) of the robot into the frame with 1", 1.5", or 2" - 1/16" wall AL tubing so that it's all rigidly assembled into the frame.
-Adam
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
