Go to Post You do need help. Don't reject offers of assistance from veterans. There are more things you don't know than you think there are. - Alan Anderson [more]
Unread 14-01-2003, 10:59
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Help - objects won't move in Max
I have a strange problem. I cannot move the last few objects added to my scene. They're automatically created in the center, rather than where I click my mouse. I can resize & rotate, but not move. I checked to make sure the object & layer weren't frozen & it wasn't locked in hierarchies.
The other objects can be moved.
Any suggestions?
Unread 14-01-2003, 13:08
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
the only suggestion i can make is to upload the file and let people see it, cause it could be a problem specific to your computer. what OS are you running?
Where has all the fun gone?
Unread 14-01-2003, 13:10
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Is it parameter wired or controlled in some way. Upload it and we'll see.
Unread 14-01-2003, 14:06
AKA: Kevin Thorp
Here's the file with the movable objects deleted (I didn't want to give away our story ).
For some reason every new object is locked in position.
Unread 14-01-2003, 15:41
Trashed20's Avatar
i think its missing something, like a file
Unread 14-01-2003, 16:04
AKA: Kevin Thorp
Yeah - I've tried twice to attach a file. I'll try again. It seems simple enough: "Attach File", "Browse" & select the file. I select my zip file (only 19k) then it's lost when I press "Submit Reply".
Unread 14-01-2003, 17:50
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
In the Motion panel, under Assign Controller, your system has assigned a Path Constraint to the object's Position without a defined path, which is an error, so they don't move. All you need to do is change the Positionath Constraint back to Position XYZ.
Unread 28-01-2003, 12:49
AKA: Kevin Thorp
That did the trick. Thanks Suneet!
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
