Go to Post An amazing manipulator system is worthless without being able to drive reliably. - RoboChair [more]
Unread 05-01-2002, 19:48
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
BIG! Speed Controller/PWM problems....
While chatting around today....EJ from 254 told me that the PWM cables that were provided in his teams kit do not fit into the connection slots on the Speed Controller....He said that there is a tab on the connection point (on the Speed Controller) that gets in the way....
Anyone else experience this problem or know what the problem is so EJ can figure it out????
I've also just found out from David Kelly that he has the same problems with his speed controllers.
Purdue Alumni
Cummins, Inc.
Unread 05-01-2002, 21:16
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
here's what we mean. i don't know if anyone else has looked at it yet but it has that little tall lip thing and it won't let the connector thing go in
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 05-01-2002, 21:29
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Oh boy, that's not good...
Awww, they go and change the Vics and now we have 660 immovable bots. What a sneaky trick...
(I'm gonna carve the PWM connector a notch with a Dremel if I need to - we don't have time for downtime in this game.)
Unread 05-01-2002, 23:47
TF8 TF8 is offline
AKA: Tyler Forbes
#0190 (Gompei and the Herd)
TF8 is on a distinguished road
Send a message via AIM to TF8
883's
if necessary can we use older victors from seasons past in stead of buying the newer ones?
tyler forbes
Unread 05-01-2002, 23:57
A Legacy of Impact
we still use some from '99
2010 Championships
Unread 07-01-2002, 21:57
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
We opened up our Victors this afternoon. The PWM slot had a rectangular nub on the lower left hand corner and a semi-circular tab on the central right hand side.
We initially had problems inserting the PWM cable. After lining up the plug again carefully, the PWM cable inserted snugly into the slot.
Unread 07-01-2002, 22:10
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
The newer 'tabs'on the PWM cables were mentioned in the Innovation FIRST presentation Friday at the Kick Off in NH. Their reasoning behind the little nibs and a tighter fit was a more positive retention to prevent the PWM cable from popping loose from the speed controller during the heat of competition.
Unread 07-01-2002, 22:33
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Yea, we initially had problems but after about... 10 minutes... we finally got them in!
- Katie
Unread 08-01-2002, 00:14
Dan 550's Avatar
AKA: Dan Richards
#0550 (BattleTech)
Removable 'Sleeve'
Is the 'Sleeve' on the PWM-in on the new VICs removable, or is it part of the real casing? I really don't want to accidently pull the wires off and have a connerctor in a sleeve on a Vic. That would be a cranky day...
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
