Go to Post And now I'll just take a moment and say that you've all gone completely insane. That is all. - galewind [more]
Unread 07-01-2013, 01:07
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Any other teams considering an ODROID U board for on-robot image processing?
I came across this board yesterday, and am wondering if it will be viable for image processing. It has a quad core ARM CPU, and is very much like a Raspi or Cubieboard in usage.
http://www.hardkernel.com/renewal_20...=G135341359084
Unread 07-01-2013, 01:30
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
Re: Any other teams considering an ODROID U board for on-robot image processing?
We have been looking at one of those. We are ordering one tomorrow and will post updates on what we end up doing. If you would like we can possibly collaborate on this problem.
* Team 3574 Alumni
* 2011 - Highest Seeded Rookie
* 2011 - Rookie All-Star
* 2012 - Engineering Inspiration
* 2012 - Olympic Deans List Winner
* 2013 - Engineering Inspiration
* 2013 - Judges Award (For unique circular robot and the way the team works together.)
Unread 07-01-2013, 10:20
FRC #1899
Great! I'll suggest this board to my team.
Unread 10-01-2013, 19:43
jjenkins jjenkins is offline
FRC #2577
jjenkins is an unknown quantity at this point
We've gotten one and are experimenting with it. Right now our Odroid-U2 is configured with a 32GB Class 10 uSD, Ubuntu Linux, OpenCV, and a Logitech C615 webcam. We're going to experiment with that camera and the axis camera.
It is sort of fun that the only monitor which we have that has an HDMI port is the CAD workstation's 27" beast.
Unread 19-01-2013, 18:50
FRC #2577
Here is an image that my vision programming team generated from using OpenCV under Ubuntu on an Odroid-U2. Programming language is C++ (g++ compiler).
This is actually a screenshot of the Odroid picking out the letters on a student t-shirt in real time from a video stream. Obviously not precisely what we need...but definitely showing the power of the Odroid and OpenCV. It was very impressive to watch this happen live on the screen.
Name:	Screenshot from 2013-01-19 17​∶​53​∶​04.png
Unread 31-01-2013, 23:55
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
10M bytes per sec with the ethernet vs 30M per sec with the USB2 (on the ODROID-u2). Are you seeing good FPS with the Logitech C615 webcam?
Unread 01-02-2013, 08:12
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
How much faster would this be than using image processing on the driver station? Ours has a 1s lag for some reason. I saw a video on youtube of someone's frisbee tracking program that had almost 0 lag, it was crazy!
And what are some of the pros to this compared to the driver staton? Will the latency times be lower and will it be faster or what?
Unread 01-02-2013, 17:40
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Are you using the classmate laptop?
Unread 03-02-2013, 10:24
The reason is usually pretty simple. Not everyone has seen the I Love Lucy where they work on the chocolate candy production line, but that is how it happens. If stuff comes in faster than it goes out, you have to deal with it. If you aware of it, you skip some images and try to process the latest one available. If you are not aware of it, you process the old stuff and you get lag.
If you have no idea how long it takes to process an image, I'd encourage you to measure it and then ask the camera for about that many frames. That eliminates the problem since there is little need to skip and you can leave enough headroom to catch up if you do fall behind. You an also combine the two, skip and avoid asking for more images than you need in a given time period.
Greg McKaskle
Unread 03-02-2013, 12:47
Dial back the frame rate. At 30 fps, there's more than a half second of delay on our Dashboard image. At 10 fps, we get no noticeable lag.
Unread 03-04-2013, 03:00
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
A little late, but...
my team has on. We 3d printed a case for it that has a heat sync in the case. It runs my program at a surprising 25 fps (granted, I have been optimizing my program for the past 3 weeks now). It runs ubuntu 12.10 and I use the microsoft kinect.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 03-04-2013, 20:20
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
How did you install OpenCV? The website's installation instructions references things which are pretty vague. Also (you don't have to answer this), how do you actually get the C-RIO to communicate with the board (i.e recieve commands/values and tell the robot to do something)?
Unread 12-04-2013, 00:52
faust1706's Avatar
I was not in charge of the setting up of the xboard, I do apologize. A mentor and a fellow classmate did that. I got the program to talk with the cRIo by a udp message and an ethernet cable hooked up to the router. I dont send the driver station on image. I send the cRIO 2 numbers, distance, and x rotation.
Unread 29-04-2013, 17:51
yalunwu yalunwu is offline
FRC #4464 (Team Illusion)
yalunwu is an unknown quantity at this point
How to install OpenCV
https://help.ubuntu.com/community/OpenCV
