Go to Post Im very proud of my kids, and my whole team, the passion and emotion here is what FIRST is all about :) - Kims Robot [more]
Unread 03-04-2013, 11:18
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Inverse Trig in Java ME
I've found myself in a bit of a pickle. I need to write a calculation that involves some inverse trig for our robot, and the embedded version of Java that the cRIO uses (Java ME) does not have the inverse trig functions of the Java SE Math library.
How have other teams moved past this limitation?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 03-04-2013, 11:20
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Inverse Trig in Java ME
You want MathUtils. It provides some of the functions that you'd usually find in Math in Java SE that aren't implemented in ME's Math class.
Unread 06-04-2013, 07:33
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Another possibility is javalution: http://javolution.org/core-java/targ...ocs/index.html I have never compared this with mathutils, but it might be worth exploring too.
Unread 06-04-2013, 08:31
Free Agent
Smile Re: Inverse Trig in Java ME
Thanks for all the help!
Unread 07-04-2013, 17:35
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Depending on how you intend to use the trig function, another option is to write a simple routine that gives an approximate but "close enough" answer.
For example, our robot uses a leadscrew to adjust the tilt angle of our climbing mast. There is an encoder attached to the end of the leadscrew so we can measure the distance it has traveled and use the cosine rule to convert this to an angle for the drivers. However to convert from leadscrew distance to angle requires using the acos() function.
Since the range of leadscrew distances are limited by the physical system, our programmers approximated the function using a piecewise linear approximation implemented as a lookup table. While the results are approximate they are close enough for visual display.
This approach is fairly common practice in embedded software, and can be used safely if you do proper error analysis.
