Go to Post I wake up at noon on Christmas Eve, and find tweets announcing a game hint. Looks like I won't be seeing much of my family today... - Karibou [more]
  #31   Spotlight this post!
Unread 03-04-2013, 14:04
Chris is me's Avatar
AKA: Pinecone
Re: Shooter Help for 2nd Year Team
Side loads were not a problem for us this year direct driving off of CIMs and mini-CIMs with a very similar shooter. As long as your compression isn't insane (10.5 inches from tip of wheel to side wall is what we used) there shouldn't be any problems.
One tip I would give you guys to get a more accurate shot that curves less. It looks like your shots hook right, away from your wheels. We found this curve was a result of the frisbee being compressed but not constrained properly. The edge of the frisbee closest to the wheels was allowed to rise up, and thus discs left the shooter in a crooked manner. If you have some kind of physical guard (e.g. a piece of low friction plastic) mounted right above the shooter wheels to prevent this "popping", you may get a more consistent shot.
  #32   Spotlight this post!
Unread 03-04-2013, 14:22
team4384 team4384 is offline
FRC #4384
team4384 is on a distinguished road
The channel opposite to the wheels doesn't seem to have any friction, the frisbee will slip, loose energy and not fly far enough. Consider taping friction tape or at least soft sided velcro to the inside of the channel opposite to the wheels. This grip the frisbee and the fast spinning wheels will generate spin and push the frisbee out.
You can get 3M friction tape (cloth electrical tape) at home depot for about $4 or so.
  #33   Spotlight this post!
Unread 03-04-2013, 15:29
They already did that. Ya gotta read the whole thread:
Originally Posted by Thorne View Post
We also increased our compression and added some foam insulation tape for friction, which helped a lot.
  #34   Spotlight this post!
Unread 03-04-2013, 21:28
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Here's some photos of the final shooter, it was getting dark so the lighting's not great...
last one's a little blurry, but you get the idea
If you need the frisbees to go higher, add more foam tape (friction) and test, followed by speeding up the wheels if needed.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
  #35   Spotlight this post!
Unread 03-04-2013, 21:50
The motors are already maxed out. The wheels may even be too fast as is.
They've already got tape on the fence. Where do you want them to put more tape?
  #36   Spotlight this post!
Unread 03-04-2013, 22:06
slickvic2252's Avatar
slickvic2252 slickvic2252 is offline
mentor
AKA: Theren Vickery
FRC #2252 (Mavericks)
slickvic2252 is an unknown quantity at this point
Our team had a simlar problem. We found that the surface between wheels acted as a brake. To fix this we moved our wheels as close together as possible and removed the wall between them.
We are running a com 1:1 first wheel 550 3:1 second wheel and 550 1:1 80% power third wheel
https://www.youtube.com/watch?v=qgMb...e_gdata_player
  #37   Spotlight this post!
Unread 03-04-2013, 22:13
mentor
AKA: Theren Vickery
Our team had this problem. We found that the wall between the wheels acted as a break slowing the frisbee down and it went through the shooter. We fixed it by moving the wheels as close together as possible and removing the wall.
We are running a cim 1:1 first wheel 550 3:1 second wheel and 550 1:1 80% third wheel
  #38   Spotlight this post!
Unread 04-04-2013, 01:01
savagecreature savagecreature is offline
AKA: Clint and/or Maria
FRC #4186 (Alameda Aztechs)
savagecreature is an unknown quantity at this point
Originally Posted by cmrnpizzo14 View Post
Good luck at SVR, if there is a webcast I will watch you guys!
Try not to get too discouraged, being a 2nd year team is often world's better than a rookie but there is still a lot to learn. Know what your strengths are and what you can do to help the alliance. While you are at SVR, there will be a ton of great teams there. Try and make time to go talk to 254, 233, 118, 148, 846, or 973 (sorry if I forgot anyone, put yourself down if you want to be on the list!) they will definitely be able to help you guys develop as a program.
Good luck!
Thanks so much! I will pass this along to the team.
