Go to Post it was beautifull just beautifull... then i took my earmuffs off. - Tytus Gerrish [more]
Unread 03-04-2013, 22:46
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: Turning with 4 kit wheels
This is a very common issue when most of us start building robots. The reason why 4wd is hard to work with (assuming your robot is in this configuration) is if all wheels are placed on the corners of the robot you have a problem with turning. The wheels are traveling at different speeds and distances. This is why cars have differentials, so that one side is slowed while in a turn. Check this website for more info. Our team was able to make 4wd work by placing the 2 wheels on each side almost side by side with less than 6 inch gap in between them. The short distance overcomes the issues I mentioned before. But we have not done this in years and opted to go with 6wd instead.
Unread 04-04-2013, 08:35
Racer26 Racer26 is offline
Skid steering is actually quite different from differentials in cars.
The problem has more to do with a high lateral coefficient of friction between the carpet and your wheels (meaning how hard is it to push the wheels across the carpet perpendicular to the wheels plane of rotation). A high lateral coefficient of friction, plus a wheelbase that is longer than its track width makes for a robot that doesn't turn.
Building a long orientation bot with 6wd, dropping the center set of wheels by 1/8" has the effect of creating two stable 4wd configurations with a short wheelbase.
Unread 04-04-2013, 09:55
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
This white paper covers what you want to know pretty thoroughly.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
