Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 28-03-2013, 19:38
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Turning with 4 kit wheels
So our team is using 4 kit wheels on our robot competing at GTR West
But the problem we are experiencing is that the robot starts to jump every time we start to turn.
Specs:
- 4 cim motors, 2 on each side connecting to the Toughbox gearboxes
- 4 kit wheels
- And all four wheels are geared
What can we do to smooth out the turning of the robot
thanks, btw we want something that is a easy fix
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 28-03-2013, 19:47
Re: Turning with 4 kit wheels
....Are you in long configuration?
Specs:
- 4 kit wheels
Replace the front (or rear) wheels with omni wheels.
By the way, do you have 4 Toughboxes (one for each wheel) so that all 4 wheels are independently driven, or do you have one Toughbox on each side driving a front and rear wheel via chain?
Unread 28-03-2013, 19:49
Reduce traction for one set of wheels. Now that I've given the solution, here are some possible ways to implement it:
--Add a middle wheel to each side, dropped slightly from the rest.
--Swap 2 of the 4 wheels for omni wheels (not easy if you don't have said omnis, but that's something to think about for later seasons)
--Swap one end's wheels for lower-traction wheels (or possibly higher-traction wheels... but that's not something I'd try)
--Grab a roll of duct tape and wrap it around the tread on one end of the robot. Replace every couple matches or so.
--Grab a couple containers of zip ties and put zip ties around the treads.
And, at the end of the event, grab a roll of field carpet if you can (talk to the FTA and arrange a transport vehicle); this will allow you to test your drivetrain under competition field conditions in future years.
Unread 28-03-2013, 19:55
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
If you can't get omni wheels, the 2009 Lunacy wheels work really nice to help turn. We did this back in 2011 and it helped performance a bunch.
Corry Robotics Team 306 1999-2015
Unread 28-03-2013, 20:10
Racer26 Racer26 is offline
Frustrating that a 7th year team is still having this problem.
But yes, the problem is too much traction on too long of a wheelbase.
Either shorten the wheelbase (move the wheels closer together), which might cause tipping problems or reduce traction on one set of wheels (front or back) by swapping for lower traction wheels (2009 rover wheels, or omni wheels are likely best choices) or by adding tape or zipties to the wheels you have.
Unread 28-03-2013, 22:05
2185Bilal's Avatar
AKA: Bilal Majeed
Though we are a 7th year team, because of the Ontario Strike Problems, many of our metors were not able to come back and help us out and since the team roster is all rookie....its tuff
RAMAZOIDZ
Unread 28-03-2013, 22:10
2185Bilal's Avatar
AKA: Bilal Majeed
Yeah we have two CIM on one Toughbox on each side, and yes we are driving via chain
RAMAZOIDZ
Unread 03-04-2013, 22:34
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
We added 2 lunacy wheels to the front of our KOP robot. After that are drivers said it was one of the best driving robots we have.
Unread 03-04-2013, 22:46
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
This is a very common issue when most of us start building robots. The reason why 4wd is hard to work with (assuming your robot is in this configuration) is if all wheels are placed on the corners of the robot you have a problem with turning. The wheels are traveling at different speeds and distances. This is why cars have differentials, so that one side is slowed while in a turn. Check this website for more info. Our team was able to make 4wd work by placing the 2 wheels on each side almost side by side with less than 6 inch gap in between them. The short distance overcomes the issues I mentioned before. But we have not done this in years and opted to go with 6wd instead.
Unread 04-04-2013, 08:35
Skid steering is actually quite different from differentials in cars.
The problem has more to do with a high lateral coefficient of friction between the carpet and your wheels (meaning how hard is it to push the wheels across the carpet perpendicular to the wheels plane of rotation). A high lateral coefficient of friction, plus a wheelbase that is longer than its track width makes for a robot that doesn't turn.
Building a long orientation bot with 6wd, dropping the center set of wheels by 1/8" has the effect of creating two stable 4wd configurations with a short wheelbase.
Unread 04-04-2013, 09:55
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
This white paper covers what you want to know pretty thoroughly.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
