Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Unread 15-01-2013, 00:15
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
pic: Independent Swerve Module
Unread 15-01-2013, 00:17
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Mugurussa675 is on a distinguished road
Re: pic: Independent Swerve Module
This looks truly amazing. Ive tried to convince my team to swerve drive but they always say no How much does a setup like that weigh? Also are you using a cim to drive it?
Unread 15-01-2013, 01:02
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
We did swerve last year (our rookie year) and it worked pretty well (I thought coming onto the team this past October & seeing it in action at Cow Town), but my team also said otherwise. I would suggest that you make this an off-season project as it requires so much time (which is what we did before our rookie build season).
From a drivers perspective, our Driver said that he could have probably utilized swerve better if he had more practice time (and we didn't have to under go a second build season). Sure swerve is pretty cool (we saw a lot of people stopping by to see our module at regionals), but it also is kinda overkill depending on what you need to do.
If you have any questions, leave them in our thread and our mentor will get back to you.
Good luck to all who try Swerve!
-David
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 15-01-2013, 02:36
varunv varunv is offline
AKA: Varun
FRC #0948 (NRG (Energy))
varunv is an unknown quantity at this point
We used swerve for the first time last year.. and I had to say that it took us 4 weeks to set up and ended up being fairly disadvangtious to us. We had alot of problems setting it up and then fine tuning it to fix the problems. We did not use a waterjet but i assume usuing that would save you so much more time than what happened to us. Swerve is truly an amazing drive system if it can be made properly. This year we are usuing a modified kitbot on steriods.
2013 Seattle Regional Winners
2013 Seattle Regional Engineering Inspiration Award
2014 Auburn District Chairman's Winner
Unread 30-03-2013, 13:36
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
I apologize for the dumb question, but we've never done swerve drive before.
What stops the orange part that holds the wheel from grinding on the stationary part of the module?
Also, where do you source such a tiny piston?
Unread 30-03-2013, 13:53
FRC #1836 (MilkenKnights)
There is a thrust bearing in between the wheel module and the gearbox. The tiny pistons are bimba pancake pistons and can be sourced from bimba or mcmaster.
Unread 04-04-2013, 10:45
Abarth15 Abarth15 is offline
FRC #0115 (MVRT 115)
Abarth15 is an unknown quantity at this point
Is the wheel carrier a single piece? I know on the revolution modules the side parts bolt on to a central body which saves a lot of machining time and cost. Otherwise brilliant design and an excellent render.
Unread 04-04-2013, 10:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You can make the wheel carrier out of purchased square tube to eliminate the need to bolt it together.
Unread 10-04-2013, 01:53
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
I only see one motor, which appears to be driving the wheel. How are you rotating the module?
Unread 10-04-2013, 01:55
Aidan S.'s Avatar
Aidan S. Aidan S. is offline
2013 World Champions!
FRC #0610 (The Coyotes)
Aidan S. is just really niceAidan S. is just really niceAidan S. is just really niceAidan S. is just really nice
There is a window motor directly above the wheel, in between the plates, that would be responsible for rotation.
2013 Galileo Division & World Champions with 1241 and 1477 #TheTheoryOfTexanCoyotes
2012 - ????: Mentor, Team 610 2009 - 2012: Student, Team 610
2013 - ????: Strategy Adviser, Team 1310
Thanks to all the great alliance partners through the years: 67, 188 x4, 191 x2, 488, 469, 578, 842, 862, 1212, 1241, 1305, 1310 x2, 1325, 1334, 1511, 1535, 1477, 1559 x2, 2122, 2168, 3161, 3360, 3396, 3476, 3609, 3756, 4124
Unread 10-04-2013, 15:28
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
that is a great looking render too bad these were never made
