Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 04-04-2013, 00:41
IDidAScience IDidAScience is offline
IDidAScience will become famous soon enough
[FTC]: Getting started in FTC
Hi all,
I coach an FLL team of 6th-7th graders who have learned quickly in the last couple of years, and we are thinking about trying out FTC next year with some of the kids to keep their interest and keep them advancing in their knowledge. They can bridge to an high school that has FTC and FRC in another year or two, and I'd like to give them a leg up on that as well.
I was thinking about getting a Tetrix kit for us to play with the next few months, as well as some CAD software and RobotC and/or Labview for NXT licenses. I see that:
1) There is free CAD software available to current teams, but otherwise it is pretty expensive
2) Labview -- same as #1
3) There may be FLL-to-FTC grants available around summertime that cover much of the cost, but otherwise it will be $600 or so for a Tetrix kit
4) RobotC seems to be undiscounted, but at least it is affordable ($80).
So, it sounds like if I wait to start until we register (which is when?) then we can possibly get all of these goodies for next to nothing thanks to the generosity of these fine companies, or we can try to get stuff now but it will have a very high price tag (mostly unaffordable without significant fundraising).
Is my interpretation correct? Or are there other options available?
Also, how does one get on to ftcforums, as that seems like the main place that FTC discussion occurs? I tried to register there, but apparently you must be on a registered team to join, so it isn't much use for learning about the program.
Thanks!
"I did a science!" - @MarsCuriosity
Unread 04-04-2013, 11:07
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: [FTC]: Getting started in FTC
This may help
http://www.usfirst.org/roboticsprogr...c/registration
Unread 04-04-2013, 11:59
Originally Posted by orangemoore View Post
Thanks, though that's actually where I did start. Registering for this year is not really helpful to our situation, though. Someone else PMed me some useful contact info, so I will start there, but if anyone else has some pointers on how you started a team in the FTC offseason on-the-cheap I happily take all good advice.
Unread 04-04-2013, 13:14
FTC5096 FTC5096 is offline
AKA: Kim Daugherty
FTC #5096 (Monkey Madness)
FTC5096 is an unknown quantity at this point
I recommend downloading a 30 day trial version of RobotC and reprogramming your FLL missions. Most FTC teams that I have met use RobotC, and this would be a great way to learn it. You can configure RobotC for the NXT platform or the NXT/Tetrix platform.
You might also purchase a Logitech controller from parts.ftcrobots.com to start learning remote control operations. RobotC installs some excellent programming templates.
You can view http://ftcforum.usfirst.org/forum.php without being on an FTC team.
You can register for the 2013-2014 season on May 15.
Unread 04-04-2013, 13:17
AKA: Kim Daugherty
Correction, registration for 2013-2014 season starts on May 8.
Unread 04-04-2013, 14:48
Christian Z's Avatar
Christian Z Christian Z is offline
FRC #2557 (Sota Bots)
Christian Z is an unknown quantity at this point
Also if there are any local FRC teams around. You might want to ask if they still have there FTC kit that they received for the 2011 season. I'm sure if they are not using it that they would be willing to give it to an FTC team.
Unread 04-04-2013, 15:02
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
What area is your team in? As noted above, the best option would be to borrow some stuff from a veteran team.
It definitely gets you a nice discount to wait until our team is registered.
If you did want to get started early, you could get just a Mindstorms kit. Having two of those is nice, because it lets your programmers mess with that while the brick is tied up on the robot. FYI, after next year FTC will switch over to the new EV3 brick (though NXT will presumably remain legal), so there's a disadvantage to putting resources into an extra NXT Mindstorms kit.
Unread 04-04-2013, 16:04
I appreciate the great suggestions, folks.
Yes, we have some NXTs, and even have the FLL bot still intact (the suggestion I made to take it apart was met with much resistance, LOL - they get very attached to the robot), so the RobotC suggestion is something we can do. I didn't realize that registration is just around the corner, so we can wait and see what happens with that, and if the grant funds will be available again this year that will help
I'll also check with an FRC team I know, and the local FTC partner, as suggested in a PM, so between those things perhaps we can build a drive train and at least practice some basics over the summer.
Unread 04-04-2013, 23:53
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
If you want to do a little more learning, and have the ability, maybe try not just building a drive base, but build a robot that can play last seasons game?
Your local FTC team probably still has the game elements for testing.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 08-04-2013, 21:12
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Another learning tool that is out there from RobotC is the Robot Virtual Worlds. They have the current FTC game in there for you to program a bot and play the game virtually.
http://www.robotc.net/download/rvw/
I also HIGHLY recommend reading this book from cover to cover (over and over):
http://www.amazon.com/FTC-Robotics-T...5469901&sr=1-1
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 17-04-2013, 13:23
Thanks, great tips. I hadn't seen the robot simulator.
We may to build a robot for last years game, too, if we can get the parts.
