Go to Post Building a robot to survive 2 districts, a Regional, a Region Championship, and World Championships (plus 4 - soon to be 5 - off season events) is a challenge in itself. - Jared Russell [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 04-04-2013, 22:42
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: VEXPro - After the season
We were pleasantly surprised by the offerings from Vex Pro. This was a good year for all FIRST teams by their addition.
Ball Shifter - We had several failures mostly self induced. The fitting on the solenoids are just too fragile and I would like to see them (or even the whole solenoid) changed. We also lost our chance at Boilermaker when the C-clip sheared off the end of the sifting shaft costing us two matches.
I'll be perfectly honest, with FIRST allowing so many good powerful motors to choose from, I doubt we will ever shift again unless the game screams for it. Six or even eight motor non-shifting drives may become the norm for us.
Bag Motor - This motor caused us many headaches this year. We started with four on our robot and ended with zero. I really hope the problems with this motor are solved, it's a nice package and has huge potential
VersaPlanetaries - A real game changer. Easy to use, easy to change and modify, by far the most significant new part to come to us in a long time. These little things took every thing we could throw at them. We used six on our bot from 1:1 to 1:300 with various motors. We abused them and they never let us down.
Gears - These low cost high quality gears enabled us to finally have our dream of a robot without chains. Our completely gear driven drive never gave us a second of trouble. The gears on our practice chassis still look almost brand new after many hours of use.
  #62   Spotlight this post!
Unread 04-04-2013, 22:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by nlknauss View Post
Sean, we were probably a good match there because we have similar setups
I'm eager to give it another go now that we've fattened up a bit. We weighed in at just under 97lbs at Hatboro when you shoved us. We were up to just over 110 at Lenape, but we never got in a pushing match with you guys there. Should be slightly heavier still if we reach Lehigh.
Originally Posted by T^2 View Post
VersaWheels
(Disclaimer: we didn't use these on our robot; only bought 1 with hubs for testing, so take this with a grain of salt. I also can't speak to durability over a season.)
Pros: Very cheap, easy to put together, and grips very well...
Cons: In one direction. When pushed from the side, the wheel slides without much resistance. Given that when we play defense, we often block with the side of our robot, this is an issue. Perhaps this could be helped by offsetting the W pattern like so:
Of course, this would probably make the wheel more expensive.
We found the direct opposite with 1712. The points would dig into the carpet when pushed sideways, almost working like a cleat. We'll continue to observe this as the wheels continue to wear.
  #63   Spotlight this post!
Unread 05-04-2013, 23:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Sorry I'm a bit late with this reply, been a bit busy competing...
Here's a picture showing the difference in tread profile between a well-worn versawheel and a brand new one. The wheel on the left has ~40 'official' matches on it, ~10 practice matches and some build season run time on it. It's noticeably slicker than a new wheel, almost as if the tread has glazed over.
  #64   Spotlight this post!
Unread 06-04-2013, 13:58
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: VEXPro - After the season
We went with single speed, 2 stage transmissions, and they have worked great on our competition robot as well as our practice bot. The only comments I have about Vexpro are:
The plastic transmission housings when we got them early in the season did not give good gear interface and were noisy. We immediately decided to make our own plates and spacers, and they have worked great. Nice and smooth, and no discernible wear on the gears.
The lack of sufficient inventory on the hex bore Versahubs (217-2592), which are still listed out of stock. Modified AndyMark hexhubs to our Vexpro wheels. The few we did get were great. Fit on the hex shafts though some were too tight. Used a Jewelers file and dressed the flats to get a good sliding fit. Next year we will machine the shafts to .500 d. and key to 1/8 as in the past for better concentricity. Initial shortage of hex bearings created a lot of anxiety as well.
Longer shafts on the ball shifters for wider wheels on WCD would also give more design versatility. We used an additional hex bearing in our frame on the shaft of the single speed tranny to take some of the load off the shaft bearings in the housing. Couldn't do that on the ball shifter due to the shorter shaft.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
  #65   Spotlight this post!
Unread 07-04-2013, 11:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by z_beeblebrox View Post
We used a complete Vex Pro drive system with ball shifters, drive in a day and traction wheels. Overall, everything works great (The shifters shift plenty fast), although the shifters do occasionally lose output shafts, but are easy to fix..
After the Bit Buckets' robot lost an output shaft in their last qualifying match, we made a quick crutch to try to prevent it happening in eliminations. This is the Rube Goldberg fix....good for entertainment value, maybe not the best solution to the problem, but they were still driving fine when they lost.
  #66   Spotlight this post!
Unread 07-04-2013, 12:10
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Except, after our first elimination match, we learned that the screws holding the shifting piston to the ball shifter came loose. Because the shifters had to be disassembled to tighten the screws, it would have taken more than an hour to fix. We used a clamp to hold the piston in place for the last match. However, we had to stay in low gear.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
  #67   Spotlight this post!
Unread 08-04-2013, 05:00
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Originally Posted by Donut View Post
We used the 8" VexPro Mecanum wheels this season with 1/2" round keyed VersaHubs and were pleased with them. Our robot only competed in 1 regional event but we never had to use any of our spare wheels or rollers. Our students loved not having to spend hours assembling them like last season and I loved the multi-pound weight savings we got in our drivetrain by switching.
And for reference, they just barely fit on the Andymark Nanotube output shafts for direct drive (I don't think we had to get the longer shafts, but that was a while ago).
I was thinking about purchasing a set of 8" Mecanums for my team. I was just wondering why there is such a significant disparity in price between the ones VEXpro sell and the ones AndyMark sell. Does anyone know if there is a comparable quality difference as well?
  #68   Spotlight this post!
Unread 08-04-2013, 09:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
As far as I can tell, there are two major differences:
  1. Plastic (glass-filled Nylon) vs Aluminum body
  2. Place of Manufacture
    (tradeoffs here -- reference Andy Baker's 2009 Small Business lectures for advantages of local part sourcing)
It's all about final application, particularly with respect to #1. Neither is superior to the other without context.
GitHub
  #69   Spotlight this post!
Unread 09-04-2013, 16:19
IndySam's Avatar
Just and addendum to our ball shifter woes.
After further investigation I believe that our problems were self induced and not the fault of Vex.
I don't think the c-clip was properly installed and that is what lead to it's failure not a problem with the shaft itself.
  #70   Spotlight this post!
Unread 09-04-2013, 18:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Red Oak? Nice choice. Show it to us again after it's stained and polyurethaned.
  #71   Spotlight this post!
Unread 14-04-2013, 10:12
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Some more comments on VEXPro after this weekend:
Versaplanetaries-they held up completely fine for us(except for a busted 775-nothing VEX related) except at one point, the CIM output shaft flat out broke. Now, this could just be due to considerable wear of the shaft throughout the season, but we were lucky to have it happen to us at the end of the day with no matches left in that day.
Ball Shifters-Worked great as they did before, except for one match where the mounting screws of the pancake cylinder became loose, which was a relatively difficult repair. Also we experienced another issue that another team also experienced (from losing their pneumatic system for a match)-when the cylinders lose air, it seems that they default to neutral gear-it'd be nice if it were a spring return/release cylinder that defaulted to either high or low gear.
