Go to Post I need someone to kick me out...unfortunately that would have to be me... - Mark McLeod [more]
Unread 05-04-2013, 08:42
Re: Deploying code in debug vs run as startup
Doug and I work together. We came up with these at roughly the same time. The only difference is whether you have the code open when you begin. I found it to be a bit faster to have it open, connect, then close it. The most important aspect is to connect so that the startup will be aborted then reload the Robot Main code before pressing run.
Greg McKaskle
