Go to Post I always tell newbies that if you build a great team the great robots will follow. - Wayne C. [more]
Unread 05-04-2013, 15:40
Fausto Vazquez Fausto Vazquez is offline
FRC #3158 (TECBOT)
Fausto Vazquez is an unknown quantity at this point
Autonomous did not work at official field but ok at practice field
Hi All.
I wonder if you have faced a similar situation, when we played the Phoenix regional we found that the autonomous sequence was not run at the official field and after ending the 15 sec, we could control the shooter perfectly.
We tried to find any miscommunication or bug on the software , also we confirmed that robot performs the autonomous sequence perfect at the practice field but it did not work at the official field.
Due to the short time and to avoid generate more issues in the robot performance we played only with teleoperated and we did not use Autonomous, obviously this cause that our performance on the finals were not the best and we lost at the first round.
If you have any suggestion of what could happened will be highly appreciated.
Thanks.
Unread 05-04-2013, 15:49
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
Re: Autonomous did not work at official field but ok at practice field
There's not enough detail here to tell exactly what might have happened.
  • What programming language are you guys using?
  • Did this happen on every match?
  • Did an FTA(A) or field guy come over and tell you if anything was up with FMS's communications?
Unread 05-04-2013, 15:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Originally Posted by Fausto Vazquez View Post
Hi All.
Thanks.
Did you talk to the FTA and/or CSA at the event? They are the people most likely to be able to help.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-04-2013, 15:55
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Whenever there's an issue programmatically that you are unsure of, it's always a good course of action to stand in the question box and request politely to speak with an FTA/FTAA.
Unread 05-04-2013, 15:57
FRC #3158 (TECBOT)
-We use Lab View
- This happend on all the match
- we Approach him and we reviewed all the setup , also we got support from other teams and we can not found the issue.
Unread 05-04-2013, 15:58
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Just to double check:
Have you attempted to run the "practice mode" on the driver station while on the practice field?
More questions:
Do you reinitialize variables during the start of teleop?
Do you use any while loops?
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 05-04-2013, 16:00
FRC #0023 (PNTA)
Rookie Year: 1620
Instead of going through vague troubleshooting questions, it might be a good idea to post your code.
Unread 05-04-2013, 16:05
FRC #3158 (TECBOT)
More questions:
This was our first year that we have a practice bot so we played around 100-120 games or more on practice mode in our town and we tested around 10 times or more at the practice field, No issues.
- Yes, we reinitiated variables during start of teleop.
- no, we did not use while loops, we used flat sequence
Unread 05-04-2013, 16:06
FRC #3158 (TECBOT)
I will ask a copy and load it.
Unread 05-04-2013, 17:43
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
When you test your code on the practice field did you just run the autonomous feature of the drive station or did you try practice mode? I would suggest running in practice mode as it simulates the various state changes out on the real fields.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 05-04-2013, 17:44
Gregor's Avatar
He already answered that.
<Since 2011
Unread 05-04-2013, 17:46
FRC #0023 (PNTA)
Rookie Year: 1620
Field logs may also prove to be valuable in the troubleshooting process.
Unread 05-04-2013, 18:24
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
This happened to us only once on practice day at Waterloo, however I could not see clearly if we were having a jam or not.
I'd recommend looking through the Driver Station log files and check to see how the connection was looking like during the autonomous period in the matches. I've also found that the FTA is more than willing to pay special attention to your robot if you guys are having problems and check for any anomalies.
Not sure how your DriverStation is set up, but ours has SmartDashboard and it displays a Scheduler, which allows us to see if a command is running or not. You guys could try that if possible to check if the robot is actually running your specific autonomous commands.
Unread 05-04-2013, 21:02
Martin Ruiz Martin Ruiz is offline
FRC #3158
Martin Ruiz is an unknown quantity at this point
Here is the code of the autonomous VI
Thanks guys!
Unread 05-04-2013, 21:56
Timothy LaPoint Timothy LaPoint is offline
FRC #0701
Timothy LaPoint is an unknown quantity at this point
Our robot (team 701) had the same problems at the Sacramento regional.
We discovered that because we had the camera set up in autonomous,which was not needed anyway, and it was using too much band width on the field system.When we disabled it, autonomous worked perfectly.
