Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 05-04-2013, 16:19
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Stop Driving
Hello. My team I was running some simulations for my teams robot before we go to the regional competition and I found out an issue with our pneumatic gearbox. To resolve this I was thinking about making a button that when the driver presses and holds it will set our drive motors (jaguar1, jaguar2, jaguar4, & jaguar5) to off even if the driver is pushing forward on the joystick. Is there a way I can do this. I can't try anything because we can't take our robot out of the bag. Can i make this button override robot drive and make it stop driving when the button is pressed? Thanks!
Unread 05-04-2013, 17:02
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Re: Stop Driving
I'm not a programmer so I'm not entirely sure what I'm talking about, but there should be a way to program your motors to brake so that when there is no driver input the motors will actively fight forces trying to turn them instead of freely spinning. I'm not sure if that would solve the issue your having but I just thought it might help.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 05-04-2013, 17:15
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Stop Driving
Im trying to get it so that the button overrides joystick input and stops the robot and continues driving when the button is released.
Unread 05-04-2013, 17:18
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Re: Stop Driving
Set a button to that allow motors to move when not pressed, but when pressed overrides all values to zero. I dont know how java works because i only know labview. but im sure its not that different.
Unread 05-04-2013, 17:36
thecakeisalie's Avatar
thecakeisalie thecakeisalie is offline
FRC #0293
thecakeisalie is an unknown quantity at this point
Re: Stop Driving
Not sure if this is what you mean, but:
if(button.get()) {
    Drivetrain.tankDrive(0,0);
else {
    DriveTrain.tankDrive(leftJoystick.getY(), rightJoystick.getY());
Unread 05-04-2013, 18:14
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Stop Driving
How about this?
bool stopp = false;
if (!stopp)
if (button.get())
    stopp = true;
Does this help?
Last edited by ekapalka : 05-04-2013 at 18:24. Reason: ... making it look more like java...
Unread 05-04-2013, 21:06
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Stop Driving
Ok thanks ill start writing out some code for it and test it at the regionals
Unread 06-04-2013, 02:00
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Stop Driving
Originally Posted by ekapalka View Post
How about this?
bool stopp = false;
if (!stopp)
if (button.get())
    stopp = true;
Does this help?
This example will only work if you're using RobotDrive, have its safety feature enabled, and have the timeout set low enough. Otherwise, it'll just stop changing the motors' speeds instead of actually stopping them.
I code stuff.
Unread 06-04-2013, 10:20
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Re: Stop Driving
Is the safety feature enabled by default?
Unread 06-04-2013, 13:51
ekapalka's Avatar
FRC #3216
Re: Stop Driving
bool stopp = false;
if (!stopp)
if (button.get())
    stopp = true;
    DriveTrain.tankDrive(0.0, 0.0);
Sorry. I've actually been programming in C++. This year we had a function using something like this that would take control from the driver and autonomously take control using the sensors. It was flawless (we programmed it during the final three rounds of the competition :P )
