Go to Post If we supply the part that adds the awesome to their robot, that makes us look good too. - DonRotolo [more]
Unread 05-04-2013, 18:35
2 19VDC laptop chargers in series
Need some help from EEs or serious electrical/electronic hobbyists.
A friend needs 36VDC @ ~1.3 amps for a project he's working on.
I have a couple of 19VDC 2.6 amp laptop chargers.
Can I wire the outputs of the laptop chargers in series to provide the desired voltage, without destroying the chargers? Or is there likely to be something in the charger output circuitry that would not be at all pleased if I did that?
Unread 05-04-2013, 19:22
Re: 2 19VDC laptop chargers in series
No way of knowing with out trying, but you may find that you need something to "slow down" the load. Either a capacitor or PI filter on each one at the end further from the switcher might help. I'd do it with two separate filters, rather than one that spans both.
Unread 05-04-2013, 19:51
DonRotolo's Avatar
Back to humble
FRC #0832
Shouldn't be a problem, assuming you keep the polarity straight.
Unread 05-04-2013, 20:10
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
I agree with Don. If the polarity is correct, it should work fine.
Adding 2 of the same power supplies together in series will double the voltage.
Adding them in parallel will double the amperage.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 05-04-2013, 21:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm far from an expert on these things, but isn't one of the legs referenced to ground or neutral or something? I didn't think most garden variety switchmode power supplies were isolated. So if they're not isolated, the common on supply A is going to be at a similar potential to common on B, with some sort of electrical path between them. So connecting + on A to - on B will be similar to a short. Or that's how it works in my head for non-isolated power supplies. I'll agree that you can treat an isolated power supply like a huge battery for voltage generating purposes.
I suppose you could check by checking voltage between - and ground and - and neutral on both supplies. If you get some sort of steady, not-floating value, then you'll want to be careful when you hook the two supplies together.
Unread 05-04-2013, 21:20
DonRotolo's Avatar
Back to humble
FRC #0832
Ether, it can't hurt to ohm out the output wires to the input wires. Anything other than several kOhms or more means 'come back and let us know so we can figure this out for you'.
I assume these are switching supplies, and these run at several dozens of kHz, thus using a tiny high-frequency transformer, which provides isolation. I suppose one could build one with a shunting configuration, but there are common mode issues (noise) that often nixes that idea.
Unread 06-04-2013, 19:38
OK here are the results:
1) The 2-prong wall plug (hot & neutral) of Charger A has no connectivity between either output and either input.
2) The 3-prong wall plug (hot, neutral, ground) of Charger B has no connectivity between either output and the hot or neutral inputs, but it does have connectivity between either output and the ground input.
3) With both chargers plugged in, there is no measurable voltage between either output of Charger A and either output of Charger B.
Unread 06-04-2013, 21:08
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Do you mean you didn't measure output voltage of any kind from either charger, or they both output the same measured voltage?
I ask because some supplies may not engage their output until they've been connected to a device, through the use of a sense pin that identifies the device and charger to each other. This is the reason some laptops cannot (easily) use off the shelf third party chargers. Could you elaborate on what brand of chargers they are?
Also, I am not what your friend's budget (if any) is, but perhaps I could recommend something like this?
http://www.digikey.com/product-detai...P5P-ND/2920448
Matt
Matt Krass
Unread 06-04-2013, 21:39
Neither.
What I intended to convey was this:
Chose either output wire (plus or minus) from Charger A, and chose either output wire (plus or minus) from Charger B. Then measure the voltage between the two chosen outputs. The voltage reading is zero regardless of choice.
It's an interesting grammar question. Had I intended to convey what you said, I'd have written this:
There is no measurable voltage between the outputs of Charger A or the outputs of Charger B.
I don't know if that's the correct grammar or not.
Anyway, the purpose of the test was to determine if there is a leakage path of some sort which might cause a problem when the outputs of the two chargers are wired in series.
Thanks for the link. I'm pretty sure his budget is "whatever I have laying around".
Unread 06-04-2013, 21:43
Sounds like the outputs are floating/isolated relative to each other, so you should be fine connecting them in series to get your 38VDC that you're looking for.
For the record, I suspect two of your 3-prong output models might have been a problem, however.
Unread 06-04-2013, 21:53
Yeah.
Even though they're isolated (so there's no leakage path), I still wonder:
1) These chargers are designed to source current, not sink it.
2) They're probably switching technology.
3) If one's switched "on" while the other's switched "off", then the "off" one sees the "on" one trying to push current through it. That's where I think Eric's earlier comment may come into play. Wish I knew more about this kind of stuff.
Hmm. I bet I've got another 3-prong one hiding somewhere. I'll see if I can find it and try it.
Unread 07-04-2013, 03:28
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Isolated switching power supplies (which A/C supplied switching power supplies usually are) can easily be and are regularly hooked in series. The supply will never be sinking current, current will always be going out the (+) terminal and in the (-) terminal. To be safe, reverse biased diodes should be connected to each output so that if one power supply comes on more quickly, it will not apply reverse voltage to the other. See here: http://www.acopian.com/acopianPowerS...y.aspx?nsId=17
While this is true for linear power supplies, it is not true for switching power supplies unless they are specifically designed for it. Because the output voltage of a switching power supply is actively controlled, any minute differences in output voltage will result in the supplies fighting each other. It will work for supplies that are well matched, but because they will use some current fighting each other, the available current will be less than combined rating and should only be done temporarily when there are no other options.
Jason
Unread 07-04-2013, 08:57
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Jason,
While this is true, a simple fix for parallel switchers is 'OR'ing diodes. This will cause the 2 supplies to droop share.
Ether,
Traditional switching supplies are isolated so running them in series is usually fine. Adding a steering diode should give you protection from reverse biasing the supply. I'd also suggest powering the downstream supply first (for the same reverse bias reason ... although it should not matter).
___________________
- Tennyson, Ulysses
Unread 07-04-2013, 09:12
In other words, the diodes are there to prevent Supply A from trying to push forward current through Supply B (via the load), when Supply B is not ready.
That's essentially what I said in my earlier post, except I expressed it in terms of Supply B being in the "off" switching state, rather than not having powered up yet.
Can someone explain what aspect of the supply's output circuitry does not like having a voltage applied across it... said voltage being of opposite polarity so that said voltage is attempting to push current through the supply in the forward direction (as would be the case we are discussing with the two supplies in series)?
Last edited by Ether : 07-04-2013 at 10:47. Reason: typo & remove some pronouns for clarity
Unread 07-04-2013, 13:26
philso philso is offline
FRC #2587
Am I correct in thinking you checked for connectivity with a meter set to measure Ohms? If so, what was the resistance measured? If the resistance is lower than say 100 Ohms, it is Ground referenced.
It is possible that the three-pronged charger may be referenced to ground. If the charger contains a regular 60 Hz transformer, it may be a type that provides no input-to-output isolation. If it contains a switched mode power supply, it is much more likely to provide isolation from the input ground.
Obtain a resistor, anything from 10 kOhm to 47 kOhm, 1/4 W or higher. Connect one end of the resistor to the positive of one of the chargers and the other end to a known Ground point (third prong on outlet). Use your meter to measure the voltage of the negative output relative to Ground. Then connect one end of the resistor to the negative of one of the chargers and the other end to a known Ground point (third prong on outlet). Measure the voltage of the positive output relative to Ground. if you get about 19 V in both cases, the output is one that floats relative to ground.
If just one of them is floating, it should be Okay to connect them in series. If one of them is Ground referenced, you may have to consider the effect on the equipment that you are powering with this supply. If both are floating, then you can treat them like a battery.
Originally Posted by Daniel_LaFleur View Post
Jason,
Paralleling diodes only prevent one supply with lower output voltage from dragging down the other. The supply with the lower output voltage will not be able to push out much output current since it's paralleling diode will not be forward-biased as much or may be reverse-biased in the extreme.
True parallel systems typically have an isolating impedance (resistor or inductor) to allow each supply to put out slightly different voltages. Otherwise, they would all need to be controlled from a single controller that forces the paralleled supplies to all have the same output current. The inverters I work on at my day-job uses sharing inductors for all the higher powered models (518 to 1500 kVA).
