Go to Post “Chasing perfection is like trying to find a unicorn. If you go all around the world, you will not find a unicorn. However, you will find a whole freak load of stuff along the way.” - Karthik - Jacob Bendicksen [more]
Unread 05-04-2013, 21:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 2 19VDC laptop chargers in series
I'm far from an expert on these things, but isn't one of the legs referenced to ground or neutral or something? I didn't think most garden variety switchmode power supplies were isolated. So if they're not isolated, the common on supply A is going to be at a similar potential to common on B, with some sort of electrical path between them. So connecting + on A to - on B will be similar to a short. Or that's how it works in my head for non-isolated power supplies. I'll agree that you can treat an isolated power supply like a huge battery for voltage generating purposes.
I suppose you could check by checking voltage between - and ground and - and neutral on both supplies. If you get some sort of steady, not-floating value, then you'll want to be careful when you hook the two supplies together.
