Go to Post 3 weeks vacation here...every single day devoted to volunteering for FIRST. Am I crazy? Yes...I am most definately crazy...but crazy has never been this much fun. - Andy Grady [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #31   Spotlight this post!
Unread 06-04-2013, 18:03
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: 2013 Pine Tree Regional
Originally Posted by ehfeinberg View Post
But aren't you allowed to do that? (R80, R81)
R80 Blue box
The assumption is that if their on-board compressor is not working, they used a different compressor to fill the tanks, which is not allowed.
  #32   Spotlight this post!
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
R80 Blue box
Not if they also have an on-board compressor. The rules specify one compressor.
R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #33   Spotlight this post!
Unread 06-04-2013, 18:04
Originally Posted by PVCpirate View Post
I heard that they had pre charged their pneumatic system because their on board compressor wasn't working, so they had to let out the air.
It's a rather strict reading of the R80, but the rule does say "Compressed air on the ROBOT must be provided by one and only one compressor." (And, if the off-board compressor used was not a legal compressor, that's potentially two violations of one rule.)
The R80 violation would then trigger multiple tournament rules that would remove the robot from the match and/or disqualify the alliance.
  #34   Spotlight this post!
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
I think it has to be powered by the robot, and it wasn't. This is a secondhand account I heard from someone on the winning alliance, so I'm not really sure.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
  #35   Spotlight this post!
Unread 06-04-2013, 18:54
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Maybe I'm "lawyering" this rule a bit too much, but IMO it doesn't say that they can only have one compressor, just that only one compressor may supply air.
Does anyone else remember when TBA signatures actually worked?
  #36   Spotlight this post!
Unread 06-04-2013, 19:20
One and only one may supply air. That one may be located either on-board or off-board. If they had removed the on-board compressor from the system somehow, then I think they would have been perfectly fine (provided that R86 was met). If they did not, then there exists the possibility that it could turn on during the match, thus supplying air, thus having two compressors supplying air to the same system during the same match, though at two different times, thus potentially creating a rather nasty rules debate if the team gets called on violating a robot rule (and thus not passing inspection, see T06 for the aftermath).
  #37   Spotlight this post!
Unread 06-04-2013, 19:26
Gregor's Avatar
Now that I read the rule again, I'm not convinced. R80 prevents compressed air from being provided from multiple compressors, it does not prevent the potential for air to be provided from multiple compressors. I know this is essentially impossible to enforce, but as the rule is written, you could have an offboard and an onboard compressoras long as only one was used, assuming all other rules are met (which is sounds like they weren't, in this case).
Footnote: If this isn't lawyering the rules, I don't know what is.
<Since 2011
  #38   Spotlight this post!
Unread 06-04-2013, 19:57
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
I am pretty sure this is the correct interpretation. In 2011, 449 had two identical (and both 100% legal) pneumatic systems, one on the robot and one off the robot. Before every match we would use our off-board pneumatic system to precharge the storage tanks on the robot. All the inspectors seemed fine with this, and we used this technique through 2 different competitions. The inspectors just required that they could inspect both boards to make sure that they would both be legal if they were on the robot.
However, the 2011 wording is different from the 2013 wording, and it is always up to the Inspector on whether you can or can't do this.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
  #39   Spotlight this post!
Unread 06-04-2013, 20:04
Gregor's Avatar
If you then used the on board compressor during the match, it would be illegal. R80 only permits air from one source.
<Since 2011
  #40   Spotlight this post!
Unread 07-04-2013, 06:02
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
2386 was told they where not allowed to use their (illegal) offboard compressor. and this was unrelated to why they sat dead in match F2. Their digital sidecar power cable had come loose and they where not allowed time to fix it.
They got it fixed between F2 and F3, charged their air tanks with their onboard compressor, then went to swap their battery. The lead robot inspector came over and told them that if they changed their battery they would have to drain then refill their air tanks. With no time left to do that and no time to argue the ruling they (2386) decided to run on the same battery as they had not moved in the last match.
Also between match F1 and F2 a bearing exploded in their shifters. It was quickly replaced with wraps of electrical tape.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
  #41   Spotlight this post!
Unread 07-04-2013, 10:09
Gregor's Avatar
What? That's a common practice, and not prohibited in the rules. Since when is that a rule?
<Since 2011
  #42   Spotlight this post!
Unread 07-04-2013, 12:08
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
I only have good things to say about this new regional. It is easily one of the best events I have been to in my time with FIRST. The volunteers and refs were nice and did their jobs well. The judges were awesome as usual, especially the ones listening for chairmans presentations. Then of course the competition. There were great robots in every match, and the finals were the best ones I've seen all year. On a personal note, a HUGE congratulations to my good friends from 3467, the Windham Windup, for winning their first regional. I know you guys went through a lot this year, and you definitely deserved a win. As Angry Eric said, "I'm just gonna say this now, but these guys have the fastest climber on the east coast." Also, if anyone from the Pine Tree planning committee is reading this, you did a perfect job, thank you. I'm very hopeful to attend this regional in the future.
There was also something that happened during the award ceremonies that I will never forget. When the rookie highest seed came up, it was originally given to team 4564, although it was supposed to go to team 4473. This was later fixed, and 4564 was told they could keep that trophy as well as they did not want to take it away from them. However, as 4473 came up for the real rookie highest seed award, members from 4564 came down and gave the trophies they received to members from 4473. It was truly amazing to see two rookie teams handling themselves so professionally. Also note that 4564 would go on to win Rookie All Star later on.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
  #43   Spotlight this post!
Unread 07-04-2013, 12:36
Bochek's Avatar
AKA: Adam Bochek
I later asked for clarification on that rule on behalf of 2386. After searching through the rule book, and not finding anything indicating that rule I was told to post the question to the Q&A if I wanted an answer.
- Bochek
  #44   Spotlight this post!
Unread 07-04-2013, 13:03
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
- Bochek
You probably should post it then, just to make FIRST aware that this happened at Pine Tree.
  #45   Spotlight this post!
Unread 07-04-2013, 13:18
Gregor's Avatar
I'm being a bit pedantic now, but does the LRI have authority in THE ARENA to prohibit this?
At each event, the Lead ROBOT Inspector (LRI) has final authority on the legality of any COMPONENT, MECHANISM, or ROBOT. Inspectors may re-Inspect ROBOTS to ensure compliance with the rules.
The Head Referee has the ultimate authority in the ARENA during the event, but may receive input from additional sources, e.g. Game Designers, FIRST personnel, and technical staff. The Head Referee rulings are final. The Head Referee will not review recorded replays under any circumstances.
Sounds like the head referee's call to make.
<Since 2011
