Go to Post The strength of an alliance is not defined strictly by the sum of its parts. - Jared Russell [more]
Unread 06-04-2013, 19:37
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Our 2013 driver station
This is the driver station we used at the Las Vegas regional
Front coming soon....
Unread 07-04-2013, 22:23
AKA: Mark Omo
FRC #1703 (RATS)
Re: Our 2013 driver station
Front
Unread 08-04-2013, 14:17
nekojess nekojess is offline
Controls Surgeon and Diagnostician
AKA: Jessica C
nekojess is an unknown quantity at this point
Lovely. Ours is boring; it's just a laptop and a joystick ._.
Only have two gripes. Charge/power should probably be on an on-off-on rocker switch, and the labels are an OCD nightmare :p
What's the charge/power for, anyway? And how are you interfacing the LEDs with the laptop inside?
(also, *brohoof*)
Unread 08-04-2013, 15:23
AKA: Mark Omo
FRC #1703 (RATS)
Internally there is a standard 17Ah battery (makes the thing very heavy, the only downside) connected to a charger, and an inverter the charge switch connects the battery to the charger and the power switch connects the battery to the inverter. We were planning on using somthing like this for the power and charge swiches, but due to time constraints we used 2 30A double pole switches
Also the power led, and the power button are soldered directly to the motherboard of a small laptop later i can post a picture of the (less than flattering) internals
Unread 08-04-2013, 17:46
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
The [digital] guts is always the best part.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 08-04-2013, 21:37
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
ILikePizza555 is an unknown quantity at this point
I've always wondered how buttons were connected to the driver station.
PONIES ARE STOOPID MAGIK -Heavy
Unread 08-04-2013, 22:32
AKA: Mark Omo
FRC #1703 (RATS)
I don't quite understand what you mean...
Unread 08-05-2013, 15:19
bumblebee3339's Avatar
bumblebee3339 bumblebee3339 is offline
Team's main account
FRC #3339 (BumbleBee)
bumblebee3339 is an unknown quantity at this point
I know what he means, and I want to know it too.
We want to know how do you connect all of the buttons on the physical driver station to the computer itself.
Unread 08-05-2013, 15:26
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
You use a cypress module. Its a very convenient board with a bunch of analog and digital input pins. It connects conveniently through usb and can be reprogrammed to your liking in the IO tab of the driver station. just click configure and pin configurations are available.
After that you would use the cypress module class/VIs to get the actual info on your robot.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
