Re: 2 19VDC laptop chargers in series
What I intended to convey was this: Chose either output wire (plus or minus) from Charger A, and chose either output wire (plus or minus) from Charger B. Then measure the voltage between the two chosen outputs. The voltage reading is zero regardless of choice. It's an interesting grammar question. Had I intended to convey what you said, I'd have written this: There is no measurable voltage between the outputs of Charger A or the outputs of Charger B. I don't know if that's the correct grammar or not. Anyway, the purpose of the test was to determine if there is a leakage path of some sort which might cause a problem when the outputs of the two chargers are wired in series. Quote:
For the record, I suspect two of your 3-prong output models might have been a problem, however. |
1) These chargers are designed to source current, not sink it. 2) They're probably switching technology. 3) If one's switched "on" while the other's switched "off", then the "off" one sees the "on" one trying to push current through it. That's where I think Eric's earlier comment may come into play. Wish I knew more about this kind of stuff. Quote:
While this is true for linear power supplies, it is not true for switching power supplies unless they are specifically designed for it. Because the output voltage of a switching power supply is actively controlled, any minute differences in output voltage will result in the supplies fighting each other. It will work for supplies that are well matched, but because they will use some current fighting each other, the available current will be less than combined rating and should only be done temporarily when there are no other options. Last edited by jason701802 : 07-04-2013 at 03:37. |
While this is true, a simple fix for parallel switchers is 'OR'ing diodes. This will cause the 2 supplies to droop share. Ether, Traditional switching supplies are isolated so running them in series is usually fine. Adding a steering diode should give you protection from reverse biasing the supply. I'd also suggest powering the downstream supply first (for the same reverse bias reason ... although it should not matter). |
That's essentially what I said in my earlier post, except I expressed it in terms of Supply B being in the "off" switching state, rather than not having powered up yet. Can someone explain what aspect of the supply's output circuitry does not like having a voltage applied across it... said voltage being of opposite polarity so that said voltage is attempting to push current through the supply in the forward direction (as would be the case we are discussing with the two supplies in series)? Last edited by Ether : 07-04-2013 at 10:47. Reason: typo & remove some pronouns for clarity |
#7
#8
Obtain a resistor, anything from 10 kOhm to 47 kOhm, 1/4 W or higher. Connect one end of the resistor to the positive of one of the chargers and the other end to a known Ground point (third prong on outlet). Use your meter to measure the voltage of the negative output relative to Ground. Then connect one end of the resistor to the negative of one of the chargers and the other end to a known Ground point (third prong on outlet). Measure the voltage of the positive output relative to Ground. if you get about 19 V in both cases, the output is one that floats relative to ground. If just one of them is floating, it should be Okay to connect them in series. If one of them is Ground referenced, you may have to consider the effect on the equipment that you are powering with this supply. If both are floating, then you can treat them like a battery. Quote:
True parallel systems typically have an isolating impedance (resistor or inductor) to allow each supply to put out slightly different voltages. Otherwise, they would all need to be controlled from a single controller that forces the paralleled supplies to all have the same output current. The inverters I work on at my day-job uses sharing inductors for all the higher powered models (518 to 1500 kVA). |
#9
It's not the best way to parallel supplies, but it does work when 1 supply wont source enough current. |
#10
Guys,
I would really like to get a handle on this discussion. It is OK to add power supplies in series. It is not OK to add battery chargers in series. Luckily I believe we are talking power supplies. Current flow will will be supplied by both power modules and since they are in series there is no need to add anything to smooth or share current flow. It will occur naturally. Ether, I am going to guess you did not measure low resistance from the third pin to both outputs. Likely what you measured were output protection devices like MOVs or some other device meant to keep ESD spikes to a minimum. As long as the resistance was a couple of kohms you are fine. Good practice would suggest that the three pin supply provide ground to the circuit you are powering and the two pin supply provide the higher voltage. Since the two pin supply has no continuity to primary wiring, connecting it as the higher supply should be just fine. As additional protection, a fuse in one leg of each supply might be a good idea in case something should happen with one supply, it would isolate the fault from damaging the other supply. |
#11
I'm not comfortable with those blanket statements. We really don't know what is inside those converters.
Turning on one before the other applies a reversed polarity voltage across the slacker. That could become a problem. The classic and cheap transformer rectifier linear regulator setup has two components that possibly could have a problem. The output capacitor could be an electrolytic (as jason said) or a tantalum. A majority of linear regulators can't handle reversed polarity. As for switchers, depending on the topology the commutation cell could become an unintended reverse path and pop like the linear. My comment about output filtering assumed a pair of identical supplies. Stacking switchers that operate at the same frequency isn't a good idea, as their control loops can become confused. The quick'n'dirty fix is to pi filter the accidental control connection away. |
#12
Here are the two "power supplies" (laptop chargers) in question. |
