Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
Unread 06-04-2013, 21:15
JohnFogarty's Avatar
AKA: @doctorfogarty
Use of Flashlight as Aiming Aid
I noticed several teams this season are using flashlights as aiming aids for the driver-period of the game. Using the Halo the flashlight produces to help tell if the shooter is pointed into the goal.
I'm attempting to consider some options for my team at CMP to help us in aiming faster.
I have a few questions, What kind of flashlight did you use, where did you buy it and how well did it serve your team.
John Fogarty
Unread 07-04-2013, 00:24
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: Use of Flashlight as Aiming Aid
1. A Cree LED
2. A mentor received it as a promotion. Similar LEDs can be bought from Mouser.
3. Instrumental in our success. The ability for the driver to keep his/her eyes on the robot at all times is priceless. While the light doesn't serve as a substitute for vision targeting through a camera or set points on an encoder, it provides a relative feedback system. Our drivers would use it as confirmation that the robot was in the place that we set the setpoints for. The coach can then keep tabs on the driver station to make sure everything is functioning. The idea here is like a laser sight on a gun to get a general idea of where you are pointing. The aiming through the "scope" of the gun was controlled by software.
The LED was connected to a limit switch on the robot and only turned on during aiming. The idea was to save battery and not annoy other drivers or the refs.
-edit-
We also put a reflecting tube around it to center the beam.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 07-04-2013, 01:05
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
We used a standard halogen bulb from radio shack, but the light source doesn't matter as long as it is bright enough. To further assist, we used a kaleidoscope with a unique pattern that was discernable and easy to line up. Our entire aiming system depended on this, and it was easy for the drivers to be able to see the target relative to the goal and fire.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 07-04-2013, 12:49
AKA: @doctorfogarty
So focusing the light source like a flashlight does is important.
I figured if we made our own we'd use LED's as the light source.
Currently 1772 doesn't have any form of vision feedback during driver control. I'm trying to come up with ways to fix that besides the camera setup that I used on 1102's robot. Which was similar to a chevron gun sight on COD.
Thanks for the input, if anyone else has suggestions, please don't hesitate to let me know. (:
John Fogarty
Unread 08-04-2013, 02:15
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Well, two of the world championship teams last year used a flashlight to aim at the baskets. 744 uses a camera feed to the driver station and with paint we created a .jpeg that just has a box the same shape as the vision target. Overlay this image at the "sweet spot" and you'll be golden. The decision for us happened because we wanted the option to auto aim in autonomous if we ever incorporated a floor pick-up (plus we used this last year), but either method is about as effective.
www.sharkattack744.com
Unread 08-04-2013, 02:57
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
We didn't bother narrowing anything and just strapped a car headlight to our robot cause that has a nice narrow point already.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 08-04-2013, 03:09
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
We decided against it this year because we figured it would just be faster to run into the bar than to spend time lining up and it's worked really well, so if you can do that I'd definitely recommend it. If you can't, they work very well and can help with open field lineups a ton, cite: 2012 winning alliance using 2 of them.
Unread 08-04-2013, 07:57
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Robogineer1649 will become famous soon enough
Team 1649 used two 6 volt halogen flashlights that we bought from Home Depot during the Orlando Regionals. We bought two in order to reduce the voltage from the 12 volt battery. We had half of the voltage go to one of the flashlights and the other half of the voltage to the other flashlight. Our flashlights were very important they were our only way of aiming our shooter the team knew that when the flashlight was in the botom left corner of the three point goal that we would make the shot. Our flashlights also allowed us to watch the field the entire time, we didn't have to look at the computer screen to aim.
Unread 08-04-2013, 09:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Just like with headlights, be careful not to blind folks with your flashlight/headlight/...
We had one incident at a previous event where a team with a light temporarily blinded the opposing team while hanging. I was asked to check out the drivers box at the end of the match, and you could not see through the drier station due to the glare. This caused that team to miss their hang which is covered under R08:
R08ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
Examples of items that will violate R08 include (but are not limited to):
A. Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any drivers and/or coaches and/or interfere with their ability to safely control their ROBOTB. Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction
C. Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another ROBOT, including vision systems, acoustic range finders, sonars, infrared proximity detectors, etc. (e.g. including imagery on your ROBOT that, to a reasonably astute observer, mimics the VISION TARGET)
D. Exposed lasers other than Class I.
E. Flammable gasses
F. Any device intended to produce flames or pyrotechnics
G. Hydraulic fluids or hydraulic components
Teams should provide MSD Sheets for any materials they use that might be considered questionable during ROBOT Inspection.
Emphasis was mine.
Unread 08-04-2013, 09:42
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
E. Flammable gasses
Emphasis was mine.
And that is the exact reason I would recommend putting a cross-hair on the camera image instead of using a flashlight to aim.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 08-04-2013, 09:50
AKA: @doctorfogarty
Unfortunately due to bandwidth restrictions..this could be a problem.
Camera feeds are the first thing that the FTA will shut off if the field goes nuts.
John Fogarty
Unread 08-04-2013, 10:06
Woolly's Avatar
Programming Mentor
As long as you make sure your alliance partners are running their cameras at sane resolutions and compression rates, you shouldn't run into an issue. Though, as this is the 1st year of bandwidth restrictions, your mileage may vary.
We have our camera running at 320X240 with 33% compression for a bandwidth usage of around 3mbps. The only issue we've had with bandwidth was Thursday at GKC where an alliance partner was running their Kinect camera 1920X1080 or some outrageous resolution.
Unread 08-04-2013, 12:38
AKA: noops
Just don't use a bright bulb. You don't need to have a bright light to put a unique target on the board to look at and fire at. Look at 180 and 25's aiming mechanism from last year. 1648's aiming mechanism wasn't very bright, but had a unique pattern that was visible from across the field.
Unread 08-04-2013, 16:03
AKA: @doctorfogarty
I wonder if anyone from S.P.A.M. can tell me what they used last season on their RR robot. Can't argue with success.
John Fogarty
Unread 09-04-2013, 23:50
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
This was our photon cannon of choice.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
