Go to Post FIRST involves school, parents, family etc etc....at least it does at our house! - MrForbes [more]
Unread 08-04-2013, 00:48
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: High speed Drivetrains
Elite teams do not just drive fast, they are fast at everything. Why? Because there is only 2:15 in the match to score points. Elite teams put in the design work to get the most out of every motor and mechanism they put on their robot. Most of us are content to get the motor to drive the mechanism at all, but elite teams do the math to figure out what designs and gear/pulley ratios will actually squeeze the most performance out of the motors they have.
The idea that a slow robot has more pushing power than a fast robot is not fully correct. If you have six motors on your drive and wheels with normal-ish friction, you can build a single-speed traction-limited drivetrain that still goes really fast. You should always build things to be as fast as possible (but no faster).
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 08-04-2013, 00:58
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Team 1781 went with Super Shifters this year. This is why we had some good offensive and defensive capabilities this year. I know that Team 111 had Super Shifters as well but instead of two speeds, they had three! They customly designed a third gear shift that was at a really low gear making them faster than us. As for squeezing the most out of every motor, we didn't take that into account. Then again we're not an elite team quite yet.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 09-04-2013, 16:06
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
We actually used 2 speed VexPro Shifters with a 3rd stage provided by WCP which matched our desired speeds for 6in wheels. Sorry if you were misinformed.
Unread 08-04-2013, 00:59
Dragonslayerend Dragonslayerend is offline
DuncanDynamics lead programmer
AKA: Tom Xiong
FRC #3970 (DuncanDynamics)
Dragonslayerend will become famous soon enoughDragonslayerend will become famous soon enough
Oh The year I'm talking about is 2013. I noticed that many teams were using mini toughbox with 10:1 gear ratio but extremely slower(like 6 fps) than our 8:1 geared robot(which runs at 12fps). I was wondering how such issues happen. Or whether it was actually planned to be a defensive robot. Actual design goals of teams are what I'm looking for. What was the intent your team had for a drive train and what was the result?
Unread 08-04-2013, 01:59
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
However with six CIMs you have to take into account the current they are drawing. If you end up stalling all six at once, and each is drawing 40 amps (or more) through its breaker on the PD board, there are 240 amps being drawn through the main breaker, which is rated to 120 amps. At least one team at SVR ran into this problem.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 08-04-2013, 02:09
FRC #1836 (MilkenKnights)
You can't stall a traction limited drive
Unread 08-04-2013, 02:26
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Another issue to consider is acceleration. Andrew Palardy [apalrd] and others have a number of great posts on this already, but gearing for more torque, in addition to greater pushing ability, also allows you to accelerate faster. Especially given the restricted field (you have to drive around the pyramids) and the level of defense this year, it does no good to have a high theoretical top speed if you'll never be able to reach it. There's always a few rookie teams each year that try to gear their drive trains for 24 ft/s and learn this lesson the hard way when their robot won't move.
FRC 766, 2015-, Mentor
Unread 08-04-2013, 02:30
The other way of accelerating faster is adding more motors(something many teams have done this year). The field is actually pretty open for robots that are less than 30" tall.
Unread 08-04-2013, 03:00
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Most years teams limit themselves to 12 fps or less because 12 fps is a sweet spot when it comes to acceleration in drive trains.
You can design a drive train that will go 40 fps; it'll never reach that speed on an FRC field. A better way to design a fast drive train is to figure out the maximum straight line travel your robot will ever have to go (be it 10, 20, or 40 feet), and then design the gearing around that.
I'll have to look into it (and do a search), but if I recall correctly there was a model that showed that a single speed 4 cim drive geared to a maximum 12fps went from dead stop to 20 feet in about the same amount of time as a drive geared to a maximum 14fps, and faster than a drive geared to 16fps. The 12fps drive had the advantage of more pushing power than the 14fps drive.
EDIT:
Was this thread I was thinking of.
http://www.chiefdelphi.com/forums/sh...l+simu lation
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 08-04-2013, 03:23
AKA: Tom Xiong
EDIT:
We will do a drag race with multiple neighboring teams that runs at 6 fps to 14 fps to see which actually is a faster robot for accel and distance travel. N post it up.
Unread 08-04-2013, 03:32
foote stepped in
AKA: E. Foote
FRC #0868
Unfortunately there will be factors that are difficult to control with different robots, for instance the amount of wiring the robot uses, the size and weight of the wheels and gearboxes, as well as the weights of the robots.
Regardless, the results will still be interesting. I'm sure we all would appreciate as much information as you can post!
Unread 08-04-2013, 07:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We started with a shifting drive this year but after problems we switched to single speed. We have a 4 cim drive geared to 17.3ft/s and 14.01 adjusted speed (acording to the JVN DesignCalc.) We were also light at 85lb's.
We were the fastest robot at both regionals we attended both in top speed and acceleration.
A few key points to going fast:
Keep the weight down, This kind of speed is much more difficult to achieve at 120lbs. If you want to go fast you have to watch every ounce from day one of your design.
Unless the game screams for it, we will never shift again. If the rules are the same next year, we will use a six motor drive.
You must have a practice robot. A real fast robot is difficult to drive. Our driver Nick made it look easy because he has many hours of practice driving a fast robot.
Pushing match, what pushing match? If they can't catch you they can't push you around. It's difficult to play effective defense against a real fast robot. Most robots would line up to block us but by the time they were ready we were already gone.
Unread 09-04-2013, 10:03
RyanCahoon's Avatar
Did you do any "drills" that you found particularly effective, especially in teaching your driver to avoid and react well to defense, or did you just run practice matches?
Unread 09-04-2013, 12:54
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Our team used our logomotion robot with our practice bot to practice playing and avoiding defense.
Unread 09-04-2013, 17:24
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
We don't really focus on defensive drills. But our driver knows the robot and I simply tell him whats going on with other robots. Then in his crafty mind, he'll decided where to go. But to tell you the truth, he'll sike me out a lot....
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
