Go to Post Is it really only 5 axes? It looks like that thing could bend time and space. - EricVanWyk [more]
Unread 07-04-2013, 20:26
DVM on sale at Harbor Freight $3.99
They actually work!
Unread 07-04-2013, 20:27
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Re: DVM on sale at Harbor Freight $3.99
I have one of these and I can attest that they are infact decent.
https://kusha.me
Unread 07-04-2013, 20:38
Billfred's Avatar
Billfred Billfred is offline
At one point, we lopped the leads off one like these and put on an Anderson connector. I'm not saying it's remotely adequate when held up to a CBA or Battery Beak, but it's better than nothing.
Unread 07-04-2013, 20:43
Hey, pick up an old sealed-beam incandescent headlight at an auto junkyard and you got yourself a reasonable battery tester.
Hook the headlight (30 to 36 watts) up to a freshly-charged battery and leave it on for 2 hours. If the voltage across the battery after 2 hours (with the headlight still on) is less than 12 volts, you've got a weak battery.
Unread 08-04-2013, 00:18
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
They actually work!
They get the job done. There are often coupons for these DVMs where they are free with a purchase at Harbor Freight.
Unread 08-04-2013, 01:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
They do work just fine for the most part. I have several, however, I have found them woefully inaccurate when attempting to measure resistance to any degree of precision. Part of the problem is the probes oxidize over time, and the leads do not plug into the meter terribly well. For $4 (I actually got a few free), I can't complain though. They're good for class projects and to throw in a travel box or bag. But, I still keep a quality meter around when needing to measure resistance.
Unread 08-04-2013, 04:58
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Does HF sponsor any FRC team(s)? Every time I think one dozen 1/8" drill bits will be enough for my power-mad riveters, I really should reconsider and save myself a trip back there. (for instance)
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
