Go to Post I believe that your career should support your dreams. - Tytus Gerrish [more]
Unread 08-04-2013, 09:50
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
Re: Use of Flashlight as Aiming Aid
Originally Posted by Woolly View Post
And that is the exact reason I would recommend putting a cross-hair on the camera image instead of using a flashlight to aim.
Unfortunately due to bandwidth restrictions..this could be a problem.
Camera feeds are the first thing that the FTA will shut off if the field goes nuts.
John Fogarty
Unread 08-04-2013, 10:06
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
As long as you make sure your alliance partners are running their cameras at sane resolutions and compression rates, you shouldn't run into an issue. Though, as this is the 1st year of bandwidth restrictions, your mileage may vary.
We have our camera running at 320X240 with 33% compression for a bandwidth usage of around 3mbps. The only issue we've had with bandwidth was Thursday at GKC where an alliance partner was running their Kinect camera 1920X1080 or some outrageous resolution.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
