Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Unread 08-04-2013, 10:06
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: Use of Flashlight as Aiming Aid
Originally Posted by John_1102 View Post
Unfortunately due to bandwidth restrictions..this could be a problem.
Camera feeds are the first thing that the FTA will shut off if the field goes nuts.
As long as you make sure your alliance partners are running their cameras at sane resolutions and compression rates, you shouldn't run into an issue. Though, as this is the 1st year of bandwidth restrictions, your mileage may vary.
We have our camera running at 320X240 with 33% compression for a bandwidth usage of around 3mbps. The only issue we've had with bandwidth was Thursday at GKC where an alliance partner was running their Kinect camera 1920X1080 or some outrageous resolution.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
