Go to Post Sir, you vastly underestimate the destructive power of a teenager. - DonRotolo [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #46   Spotlight this post!
Unread 08-04-2013, 00:04
C. De Vries C. De Vries is offline
fountain of useless information
AKA: Christina
FRC #4531 (STEMpunk)
Team Role: CAD
C. De Vries is an unknown quantity at this point
Re: Cool future games
This being my team's rookie year we all speculated as to the crazy things FIRST could come up with. I think the two that stood out the most were the idea of a completely underwater game with robots swimming around trying to accomplish something or smaller helicopter-like robots flying through the air to score points. Personally I think we should set everything up Hunger Games style with multiple terrains and an expanded the field. Then use a suspended platform above the field for driver stations to make it easier to see everything and then let robots have at each other. (not actually have at each other, we want to be able to reuse robots) Hmmm.... maybe paintball. Paintball could be fun...
  #47   Spotlight this post!
Unread 08-04-2013, 00:14
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by 1683cadder View Post
I thought this year was going to be multi terrain, because of all the rover talk they gave at champs. I would love a multi terrain game too.
You right! A mixture of carpet and slick regolith would make for a super interesting and unpredictable field surface. Maybe with bumps made out of regolith even!
*Ducks and runs*
  #48   Spotlight this post!
Unread 08-04-2013, 00:31
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Guys, I've got it! You will love this idea.
Add a purple alliance.*runs away giggling*
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
  #49   Spotlight this post!
Unread 08-04-2013, 00:44
The canonical color for the third team/alliance on the field is White, you know.
Other than that, it's a perfectly fine idea. I mean, the elimination structure gets a little complicated. *twitch* But once you stare at it for a few hours it totally makes sense. *twitch* Don't worry, the side effects aren't nearly as bad as everyone says. *giggle* ReAllY.
  #50   Spotlight this post!
Unread 08-04-2013, 01:48
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
I'm still waiting on a game with Caution Cone game pieces. Cool game piece, interesting shape to make it a little tricky to pick up, and they're readily available.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
  #51   Spotlight this post!
Unread 08-04-2013, 02:11
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
Game: Construction Zone
Game Pieces: Large and small orange construction cones
Field: Separated into 5 zones, the center free zone, a cross shape, and then the 4 corners are alliance construction zones, 2 per alliance.
Autonomous: Teams may begin to stack cones in their alliance stations, there will be comes randomly placed on the field available to pick up during autonomous mode but you must not enter your opponents alliance construction zone.
Teleoperated: Cones may be entered by human players by placing them in special pickup zones at either end of the field (not in an alliance zone, like where the center human player stations were in '09) or teams may use any of the discs in the arena, however if a cone is stacked in your opponents alliance zone it may not be taken (unstacked are fair game) by an opposing robot. Cones may also be scored on a cart locked in place at the center of the field, however the points are not given to either alliance until the end game.
End game: There are two major aspects to the end game, first the cart in the center is unlocked and if any wheel of the cart is in contact with an alliance construction zone, all points on the cart count as multipliers for that alliance. The other end game part is that larger cones (3 per alliance) are given to the teams human players and may be entered onto the field. Any stack that is created on top of one of these cones will be given bonus points according to the stack's height (In traditional FIRST style, smart teams will build robots capable of moving stacks onto the larger cones instead of needing to create new ones).
Scoring: Each cone is counted at one point per level: A stack of 2 would count for 3 points (1+2), a stack of 3 is counted at 6 points (1+2+3), and so on. If a stack is on top of a large cone it gains 50 points for every 12 inches between the top of the stack and the floor. For the cart, if it is contacting an alliance zone at the end of the match, that alliance's points are multiplied by the number of highest stacked cones on the cart.
  #52   Spotlight this post!
Unread 08-04-2013, 12:06
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
Originally Posted by dellagd View Post
They were 4th pick at Bridgewater-Raritan District event. Indecently, by team 11.
They didn't have their bumpers on? 11 insulted the team members' mothers?
  #53   Spotlight this post!
Unread 08-04-2013, 13:10
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Originally Posted by StAxis View Post
Game: Construction Zone.
[snipped]
In addition, at all Michigan events, there will be a few supplemental rules.
1. The field will have potholes scattered in the highest trafficked areas with a carpet-pothole ratio of 1:2
2. Portions of the field will be closed off intermittently (and seemingly randomly) for construction.
3. Snow, ice or rain may or may not be spread on the field at random points during gameplay with no advance warning, regardless of weather or season.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
  #54   Spotlight this post!
Unread 08-04-2013, 13:43
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
I thought (around December) this year was going to be a frisbee game similar to 2006 with 2007's endgame, because it's about time.
I then spent kickoff day shouting about how right I was. I was so right.
  #55   Spotlight this post!
Unread 08-04-2013, 14:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
How about a bowling game? Robots knock down the other team's pins, try to keep their own pins from being knocked down, and place the pins back upright if they do get knocked down.
  #56   Spotlight this post!
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
869 was able to play shutdown defense on team 11, who is 17 of FRCTop25 (Just say'n). When a team skirted around them, they literally "blew" the frisbees away.
As the driver who was almost entirely shutdown by 869 and their intense defence, I can certainly attest to defence being a viable strategy to build a robot for.
What they really exemplify though, is that no matter what game you build a robot for, it is only going to be really effective if you commit to being the best at that one strategy rather than waffling and being just OK at multiple game tasks. Karthik's golden rules.
On that note, a game where you can actually score using defence would be neat. Not just pushing, but something where you actually get points for keeping an opposing robot from a certain zone.
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
  #57   Spotlight this post!
Unread 08-04-2013, 21:54
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Micah Chetrit is on a distinguished road
I agree with the people who suggested a combo field. My dream game (Which I will never get to play) would be a section of slick material like a fake ice, a regolith if you will. The other section would be water, making the water game come true without forcing people to go into water. I think this field combo would be fun. Game pieces? who needs game pieces when you just want to drive around all day. but someone can suggest a fun one (ping pong balls maybe?)
  #58   Spotlight this post!
Unread 08-04-2013, 22:06
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
1683cadder is on a distinguished road
Tetras on mars!!!
  #59   Spotlight this post!
Unread 08-04-2013, 23:12
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
Team Role: Electrical
bbuncher12 is an unknown quantity at this point
As a follow-up to Maize Craze:
Mashed potatoes. Everywhere.
  #60   Spotlight this post!
Unread 09-04-2013, 00:50
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
I'm holding out for a baseball game next year. Here's what I have been thinking about.
Game- First baseball
Pieces- small foam nerf balls (baseballs) (ideally a lot of them on the field at a time >100) and large colored cubes (players)
Field- there would be a high wall on either end acting like a fence on either side of the court which robots will have to shoot or dump the small nerf balls behind in order to score points. The bottom of the goal behind the fence can be sloped so the balls will run off the side and be counted easily like 2010. Also, in the middle of the field, there will be 4 boxes that are something like 4-6'' (that's supposed to be inches) tall with one for each alliance and 2 neutral ones all arranged in a baseball diamond shape.
Goal of game- to score the little balls into the goal over the fence and also get points by getting your robot onto your alliance box (the bases) at the end of the game or putting the large cubes on top, or both for with increasing points for the level of difficulty.
Gameplay- since baseball does operate in turns with teams alternating playing offense and defence, there could be an element of strategy like Aim High with maybe only one scoring zone along the long width of the field where teams each can score during a 50 second period and then the final 20 seconds the score will go to both teams (co-operation points )
This is just an idea I have been thinking of and I think it would be a pretty cool game to play with. I also like the idea of lots of scoring pieces and also big scoring pieces, both of which this game would have.
EDIT: Thought of a better edition to the game. Instead of using just balls (again) for primary scoring, the scoring could somehow involve pool noodles or plastic bats which would be pretty cool. Also, instead of nerf balls, the game could just also use something likewhiffle balls which would be cool for an extremely irregular object to shoot accurately (trust me, it's hard)
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
