Go to Post Ah AndyMark and your $2 a piece pool noodles - mlantry [more]
Unread 08-04-2013, 21:55
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Xbox Controller Axis 3
Hello. My team has decided that we are using the xbox controller for our regional competition. I have it all done except one thing that i cant quite get to work right. The two trigger buttons at the top back of the xbox controller I believe is Axis 3. We are trying to get the left side to activate one solenoid and the right side to activate the other. Is this possible since its not like a normal button that is a boolean and if so how can I go about this? Thansk.
Unread 08-04-2013, 22:23
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Xbox Controller Axis 3
    solenoid.set(controller.getRawAxis(3) < -0.7)
All opinions are my own.
Unread 08-04-2013, 22:52
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
If you're not entirely sure what axis it is, go to Run and type "joy.cpl" without quotes. There should be a mapping under the Properties tab (while the controller is plugged in). The triggers together are actually one axis, with the left side being zero through negative one and the right side being zero through positive one. That way, synchronous triggers always equal 0 (both pressed, neither pressed, both half-pressed, and so on). I think you would probably be better off with the bumpers (because they're boolean, like solenoids; on or off) for your purpose. Just my thoughts
//pseudocode
if (triggeraxis > 0)//Room for error? change 0 to 0.5
    //solenoid 1
else if (triggeraxis < 0) //should be some room for error, like -0.5
    //solenoid 2
else
   //set solenoid 1 and 2 to off
Unread 08-04-2013, 23:06
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
In my XboxController class I have it setup so that the trigger axis pretends to be buttons. You can even use them with the Button class to start commands in the CommandBased Structure:
XboxController.java
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 10-04-2013, 19:11
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
nothing is working
Unread 10-04-2013, 19:47
ekapalka's Avatar
FRC #3216
joy.cpl
Is it communicating with your computer? Are the drivers installed? If joy.cpl shows it's not working, it's not the code.
Unread 10-04-2013, 21:05
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
It is communicating.
Unread 10-04-2013, 22:23
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Are you pressing both triggers at the same time? Because if so, that won't work.
What our team did to test the xbox controllers was something along the lines of this code:
for (int i = 1; i <= 6; i ++)
System.out.println("AXIS "+i +" READS "+joystick.getRawAxis(i);
If you run this in your teleop code, and monitor the NetConsole, you should see Axis 3 read a value of near 0when neither trigger is pressed, a value of near 1 when one trigger is pressed, and a value of near -1 when the other is pressed.
If you can confirm that Axis3 does behave in that manner, then joelg236's code should work with the addition of setting another solenoid when the value is > 0.7.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 10-04-2013, 22:56
gixxy's Avatar
It would help if we could see your code.
Unread 13-04-2013, 20:50
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Sorry guys. The code was right, but wasn't working because the solenoid wires got crushed and needed rewired. Thanks for your help.
Unread 14-04-2013, 17:44
gixxy's Avatar
Glad to hear your problem was resolved!
