Go to Post FIRST is here to reach the affluent, already college-bound students with boundless resources; it is also here to reach the poverty-stricken urban and rural students who don't see a diploma as worthwhile, and everybody in between. - Taylor [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #46   Spotlight this post!
Unread 07-04-2013, 13:22
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: 2013 Pine Tree Regional
Does anyone have the match videos from eliminations?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
  #47   Spotlight this post!
Unread 07-04-2013, 13:24
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Does anyone know if the webcast was archived? I can't even find a link to where it was on the Pine Tree Regional website.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #48   Spotlight this post!
Unread 07-04-2013, 13:27
BrendanB BrendanB is offline
AKA: Brendan Browne
Based on what we were told, 2386 was not allowed to use the compressor on their cart because it was not controlled by the robot's battery (even though it was the same thing). Before finals match 2 they were asked to remove their pre-charge air and use the compressor on their robot to charge their tanks.
In the process, one of the cables to power their sidecar came unplugged and due to how much time was used to sort out the pnuematics issue they were asked to leave the field to start the match. So the reason 2386 didn't move in finals match 2 was not because of an illegal component it was due to an electrical problem we didn't have time to fix. Between finals match 2 and 3 2386 quickly fixed the problem and they were back up and running for match 3.
1058 PVC Pirates 2016 - xxxx
  #49   Spotlight this post!
Unread 07-04-2013, 13:45
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
From the Q and A:
Q574
Q. Can separate off-board compressor system be used to pre-charge our unpowered robot's pneumatic system?This off-board compressor would be a FIRST-compliant compressor system, incl. battery, compressor, relief valve, spike w/20A breaker, pressure switch, digital side car, computer and storage taank
FRC0175 on 2013-03-13 | 3 Followers
A. No, per [R80].
Q473
Q. Can we begin the match with pre-charged air resevoirs (i.e. 120 psig "stored" and 60psig "working" pressure) as long as the robot control system and battery (and in our case, the on-board air compressor) was used to pre-charge the resevoirs?
FRC3293 on 2013-02-12 | 4 Followers
A. Yes.
and from The Robot section of the Game Manual
R37
Non-electrical sources of energy used by the ROBOT, (i.e., stored at the start of a MATCH), shall come only from the following sources:
compressed air stored in the pneumatic system,
a change in the altitude of the ROBOT center of gravity, and
storage achieved by deformation of ROBOT parts.
R80
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate. Off-board compressors must be controlled and powered by the ROBOT.
BLUE BLOCK:
The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor off-board. However, using the compressor off-board of the ROBOT does NOT permit non-compliance with any other applicable rules.
The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in storage tanks on the ROBOT prior to bringing the ROBOT onto the FIELD.
It does seem that the correct interpretation of the rules (especially after noting the text in the informative block under R80) is to allow only the onboard compressor to charge tanks, if an onboard compressor is utilized.
If the call was made that the same battery must be used to pre charge the tanks as was used during the match, however, I don't see justification for that rule in the Game Manual. It may have been based off the phrasing of question Q473. Another Q and A question to clarify Q473 to see if the same battery MUST be used to precharge the compressor would be required to get a real answer. Unfortunately I don't have access to our teams Q and A account at the moment, or I'd post one myself.
  #50   Spotlight this post!
Unread 07-04-2013, 13:49
Todd's Avatar
Software Engineer
All of the above said,
This was one of the most fun regionals I've been to. The atmosphere at the event was truly kind and professional, projected by the event staff and all of the teams present.
As our team was in a well enough state of affairs to allow me a lot of extra time this weekend, and there were rumblings of slight short staffing on the number of volunteers at the event I volunteered at the spare parts table and I can say that all the volunteers I worked with were also kind and professional and treated well during the event.
Overall it was a great pleasure to attend the inaugural Maine Regional, and I'd be happy to do it all over again.
  #51   Spotlight this post!
Unread 07-04-2013, 16:42
maddog175's Avatar
maddog175 maddog175 is offline
mentor
FRC #0175 (Buzz Robotics)
maddog175 will become famous soon enoughmaddog175 will become famous soon enough
Smile Re: 2013 Pine Tree Regional
Originally Posted by kstl99 View Post
After 1 day of competition I must say this is the best regional I have attended.
Congratulations to rookie team 4793, the Gobotics from Old Orchid Beach. Maine. They have a mostly wooden robot that looks really nice, drives well, has a 1 point dumper, a 10 point climber and plays good defense. It was built by 2 students and one mentor, although they are up to 3 students now. Their entire team is on the field during their matches. I was very happy to see them win the Rookie Inspiration award.
Inspiring.
  #52   Spotlight this post!
Unread 07-04-2013, 17:00
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
The webcast was run by wsea.tv and I just heard that they will have the archived video available on their website Monday morning.
  #53   Spotlight this post!
Unread 07-04-2013, 21:15
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
Congratulations to
78 on winning the Chairman's award
2648, 3467, and 2386 on their first win (we will be seeing many more from these teams!)
Huge thanks to our partners 125 and 63 on doing everything we asked in some of the most exciting matches we have participated in.
Huge thanks to the Pine Tree Planning committee for putting on such an excellent event. We look forward to next year.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
  #54   Spotlight this post!
Unread 08-04-2013, 13:27
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Cool Re: 2013 Pine Tree Regional
One and only one may supply air. That one may be located either on-board or off-board. If they had removed the on-board compressor from the system somehow, then I think they would have been perfectly fine (provided that R86 was met). If they did not, then there exists the possibility that it could turn on during the match, thus supplying air, thus having two compressors supplying air to the same system during the same match, though at two different times, thus potentially creating a rather nasty rules debate if the team gets called on violating a robot rule (and thus not passing inspection, see T06 for the aftermath).
I believe this is the correct intent of the rule. If you pre-charge a system before a match with a different compressor and have the ability to add compressed air during a match, that's an advantage over other teams.
Originally Posted by ehfeinberg View Post
I am pretty sure this is the correct interpretation. In 2011, 449 had two identical (and both 100% legal) pneumatic systems, one on the robot and one off the robot. Before every match we would use our off-board pneumatic system to precharge the storage tanks on the robot. All the inspectors seemed fine with this, and we used this technique through 2 different competitions. The inspectors just required that they could inspect both boards to make sure that they would both be legal if they were on the robot.
However, the 2011 wording is different from the 2013 wording, and it is always up to the Inspector on whether you can or can't do this.
We never use pnumatics so I don't know all the rules, but I'm surprised they let you get away with that. What ever happened to the stored energy rule such as not having compressed springs, coils, surgical tubing? Isn't compressed air the same thing?
**Edit, just read more of the posts, apparently you can have a pre-charged air tank as long as it was filled by a compressor powered and controlled by the robot.
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
  #55   Spotlight this post!
Unread 08-04-2013, 13:45
TedG's Avatar
Talking Re: 2013 Pine Tree Regional
Yes agreed! It was a well organized, fun and professional event.
Loved how smooth the field was loaded and unloaded.
BERT 133 had a blast!
It was the committee's first time running a regional competition, although some in the committee had organized off-season events, and all members have many, many years of FIRST experiance. They worked so hard all year long planning this.
We here in Maine were glad you all came, hope to see you next year!
Hope to see some of you at Beantown Blitz!
  #56   Spotlight this post!
Unread 08-04-2013, 18:50
mylesfilkin2386 mylesfilkin2386 is offline
FRC #2386
mylesfilkin2386 is an unknown quantity at this point
Does anyone have/know of any film from the finals matches at pine tree?
2008 MWR Highest Rookie Seed
2008 GTR Highest Rookie Seed
2010 WL Judges award
Team 2386 2011 Events:
-Greater Toronto West Regional Mississauga, ON
-Virginia Regional Richmond, VA
  #57   Spotlight this post!
Unread 08-04-2013, 19:36
MikeE's Avatar
no team (Volunteer)
As I posted above, video of the competition is available at wsea.tv with the finals about 2 hours into the 3rd video.
  #58   Spotlight this post!
Unread 09-04-2013, 02:28
lanna.stars's Avatar
lanna.stars lanna.stars is offline
Secretary/Social Media Coordinator
AKA: Elana
FRC #2386 (Trojans)
lanna.stars will become famous soon enough
One thing about living in Canada... things get blocked... Day 2 Part 2 of the PTR is blocked for viewing in Canada due to copyright laws....
Proud Mentor of Team 2386
Facebook Twitter BCHS Robotics Website
2008 MidWest Regional: Highest Rookie Seed
2008 Greater Toronto Regional: Highest Rookie Seed
2010 Waterloo Regional: Judges Award
2011 Greater Toronto West Regional: Coopertition Award
2012 Smoky Mountains Regional: Regional Finalist
2013 Waterloo Regional: Imagery Award, Woodie Flowers (Chris Arnold)
2013 Pine Tree Regional: Regional Winners #3 (3467 & 2468)
2014 North Bay Regional: Imagery Award
2015 North Bay Regional: Creativity Award
  #59   Spotlight this post!
Unread 11-04-2013, 07:50
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Pine Tree Regional Extended Previews are up!! These were easily some of the most excited teams & kids I've had the opportunity to photograph! They had tears in my eyes so often I'm surprised I didn't fog up my viewfinder!
http://www.flickr.com/photos/kimsrob...7633214226943/
More to come, but I am not sure how quickly since I need to get back to my CT photos also!
As always, please feel free to use/repost these... I just ask that you provide photo credit and/or leave my copyright symbol on them.
Thanks!!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
  #60   Spotlight this post!
Unread 11-04-2013, 11:11
MikeE's Avatar
no team (Volunteer)
I think the videos were mislabeled on the WSEA.tv site and it's actually the Day 2 part 1 video which is blocked, presumably for music copyright.
Try this direct link to YouTube. Final matches start around the 2 hour mark.
