Go to Post Of course, someone who can score on all rack levels while hovering autononmously 12 inches off the floor in his own home zone could probably have posted on CD while winning a regional.;) - Richard Wallace [more]
Unread 09-04-2013, 16:38
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Fried Digital Side Car
We've had a few Digital Side Cars burnout this season... wondering what may be causing them to fail (based on the picture below) and if they are repairable. Click image for larger version
Unread 09-04-2013, 16:47
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Fried Digital Side Car
Starting down at post 49 of that thread might help some diagnostic. Chip Q1 is a FET that protects reverse polarity powering of the sidecar. Check and make sure that your Wago connector is in fact wired properly.
Academic Student (Forever)
Unread 09-04-2013, 17:19
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Did I read that schematic right? A 10 A breaker? Don't the FRC rules say to attach the DSC to use a 20 A breaker?
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 09-04-2013, 17:30
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
If you can find a replacement chip, any competent solderer should be able to fix the sidecar.
Unread 09-04-2013, 17:32
cgmv123's Avatar
AKA: Max Vrany
You read it right. I'm not sure why FIRST differs. That's a question for EricVanWyk.
Unread 09-04-2013, 17:40
FRC #6357
Well. the datasheet for the FET says it's good to 33A. But, that doesn't mean there isn't a lot of heat building up anyway.
Also, is that schematic for Rev 7 or Rev 8 of the DSC? Q1 has decidedly different packages on those two revs.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 09-04-2013, 17:59
That schematic image is from Rev 7 or earlier. I think CB1 was removed before we went to actual production.
The updated FET part number is FDS8817NZ. There is also an added 10k gate resistor.
That part can blow in a few situations:
1) The DSC ground was used to return something else's current. This can happen if a wire shorts to a ground pin on the DSC. This is one of several reasons we do chassis isolation tests during inspection.
2) An ESD event hit the gate of the FET, and subsequently a large but nominally acceptable current was passed through the part (which is now probably a bad diode).
3) An ESD event hit, and then the DSC was plugged in with reversed polarity.
4) Aliens.
5) A short across the power inputs just down stream of this protection. This is rare: The switchers have very well behaved protection against short circuits at their loads, and the Big Flashy Light port has a breaker.
You can swap the part out with a decently hot iron and try again, but I would check to find where the bonus current is coming from. I'd turn it on attached to a current limited bench supply the first time after the repair.
I'd be happier with a 10 Amp breaker, but 20 is enough like 10 to be just fine. In the end, it wasn't worth the supply chain changes. There are vanishingly few cases where the difference between 10A and 20A breakers would matter to a team - At this point the first line defenses are already down and the board would need to be repaired or replaced.
Unread 09-04-2013, 18:05
Thanks for the info. I'm thinking the issue may have been a PWM ground that momentarily touched a +12v spike input. Would that do it?
Unread 09-04-2013, 18:07
Definitely.
Unread 09-04-2013, 21:42
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
If you just want to use it on a test bot, cut the FET off. Solder a jumper across the source and the drain. Don't connect the one pin that is the gate. Don't reverse the polarity or you will fry a previously fried sidecar.
Unread 10-04-2013, 08:07
With the latest run of boards, the conformal coatings are not consistent. The damage looks like a piece of conductive material made it's way onto the board. With the kind of damage I see, replacement is the better choice. If it was one of kind, repair would be your only option but it may not fix the problems.
Unread 18-04-2013, 19:16
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
We had the exact same thing happen to ours last week. I just bought the replacement. I was not around when it happened but I took it apart and it is identical to yours.
Unread 18-04-2013, 23:24
Our new protocol is to power down before touching ANY wiring. We always did this with the 12V wiring but got lazy hot-swapping PWM cables... not anymore.
Unread 18-04-2013, 23:52
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
I have no idea what caused that, but a flipped PWM in the wrong (or right, depending on how you look at it) could probably do that. How'd it smell?
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 19-04-2013, 02:36
Quix's Avatar
Quix Quix is offline
AKA: Jeremy
FRC #0604 (Quixilver)
Team Role: Student
Quix will become famous soon enoughQuix will become famous soon enough
We have had his problem before - fried 3 DSCs and the same chip was fried.
It turns out that one of the victors was shorting on a a screw to the bellypan and this caused the chip to blow. I would check for any shorts, that is most likely your problem.
