Go to Post We might just dip the entire bot in a Locktite bath before bagging. - Kevin Ray [more]
Unread 09-04-2013, 17:59
Re: Fried Digital Side Car
That schematic image is from Rev 7 or earlier. I think CB1 was removed before we went to actual production.
The updated FET part number is FDS8817NZ. There is also an added 10k gate resistor.
That part can blow in a few situations:
1) The DSC ground was used to return something else's current. This can happen if a wire shorts to a ground pin on the DSC. This is one of several reasons we do chassis isolation tests during inspection.
2) An ESD event hit the gate of the FET, and subsequently a large but nominally acceptable current was passed through the part (which is now probably a bad diode).
3) An ESD event hit, and then the DSC was plugged in with reversed polarity.
4) Aliens.
5) A short across the power inputs just down stream of this protection. This is rare: The switchers have very well behaved protection against short circuits at their loads, and the Big Flashy Light port has a breaker.
You can swap the part out with a decently hot iron and try again, but I would check to find where the bonus current is coming from. I'd turn it on attached to a current limited bench supply the first time after the repair.
Originally Posted by jee7s View Post
Did I read that schematic right? A 10 A breaker? Don't the FRC rules say to attach the DSC to use a 20 A breaker?
I'd be happier with a 10 Amp breaker, but 20 is enough like 10 to be just fine. In the end, it wasn't worth the supply chain changes. There are vanishingly few cases where the difference between 10A and 20A breakers would matter to a team - At this point the first line defenses are already down and the board would need to be repaired or replaced.
