Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 09-04-2013, 17:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Team Update 4-9 & VEX BAG Motor Fix
Motors & Actuators
R33
There is an issue with the VEX BAG Motors supplied in the Kit of Parts (lot numbers 2491BL, 2462BL, and 2493BL) that causes the motor to stop working. VEX has published instructions, now legal per R33, regarding the fix.
The integral mechanical and electrical system of any motor may not be modified. Motors, servos, and electric solenoids used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
B. The electrical input leads may be trimmed to length as necessary.
C. The locking pins on the window motors (P/N: 262100-3030 and 262100-3040) may be removed.
D. The connector housings on the window motors (P/N: 262100-3030 and 262100-3040) may be modified to facilitate lead connections.
E. The Integrated Encoder Module (P/N: 276-1321) may be installed on the VEX 2-wire Motor 393 (P/N 276-2177).
F. The VEX 2-wire Motor 393 (P/N: 276-2177) gears may be changed or replaced per the Supplier instructions.
G. The VEX BAG Motor (P/N: 217-3351) may be repaired per the Supplier instructions found at http://www.vexrobotics.com/217-3351.html.
Game Manual
Good Luck to all Teams competing in Week 7 Events!
Link to repair instructions: http://content.vexrobotics.com/vexpr...structions.pdf
You will have to disassemble the motor.
Unread 09-04-2013, 18:08
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Team Update 4-9 & VEX BAG Motor Fix
It's very cool that there is definite fix to the problem and that FIRST is allowing us to perform it at home!
Unread 09-04-2013, 18:30
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Is this problem only with BAG motors from the KOP? If I bought a motor from VEX right now would it have this problem?
Thanks.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 09-04-2013, 18:45
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Thanks.
The problem affects lot numbers 2491BL, 2462BL, and 2493BL. You can find your lot number as the bottom line of information printed on the motor. We are not shipping motors from these lots.
Ricky
Ricky Quinones
Director of Sales - VEX Robotics
Unread 09-04-2013, 19:07
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
I see no where in the update where it says "you can take the robot out of the bag" so no you can't perform it at home if you want to attend another event.......
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 09-04-2013, 19:10
AKA: Simon Bohn
Well, some teams may have whatever uses a BAG outside their bag (har de harr).
Unread 09-04-2013, 19:24
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
And, as a COTS part, one could have kept it out of the bag, and it wouldn't count against the withholding.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 09-04-2013, 19:36
AKA: Simon Bohn
Unless it was part of an assembled assembly, in which case it becomes a FABRICATED COMPONENT.
Unread 09-04-2013, 21:56
GaryVoshol's Avatar
Cogito ergo arbitro
But I betcha it weighs less than 30 pounds.
(since 2004)
Unread 09-04-2013, 23:33
AKA: Karlis Musa
Kind of. As part of an assembly, it would count against the 30 lb limit.
However, if it is removed from the assembly, and hadn't been modified (if it had, it is already a fabricated item, and the issue becomes moot), then it is still considered a COTS item. [ref - Q464 in the Q&A]
