Go to Post Andy Baker doesn't go to IRI. IRI comes to Andy Baker. - tim_reiher [more]
View Poll Results: In 2014, I plan on or would like to use:
Victors 25 14.71%
Jaguars 20 11.76%
Talons 125 73.53%
Voters: 170. You may not vote on this poll
  #31   Spotlight this post!
Unread 10-04-2013, 20:16
Re: Talons, Jaguars and Victors - where do you stand?
Originally Posted by Wiifi View Post
...we will never be using Jaguars again, at the competition we ended up replacing all of our jags with victors as the jags kept failing.
Are these the old design Jags from Luminary and/or Texas Instruments? Or are you talking about the improved design (conformal-coated PCB) from Vex?
  #32   Spotlight this post!
Unread 10-04-2013, 21:18
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
They are all pre-2013, we have some VEX jags from the PDV but we have not used them.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #33   Spotlight this post!
Unread 10-04-2013, 22:17
It's important to make that distinction. VEX has invested a lot of time and money, and worked very hard to improve the Jag.
  #34   Spotlight this post!
Unread 10-04-2013, 22:27
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Thank you for the suggestion, we were originally going to use the new jags on the robot but we had a few problems with our PDV. They ended up arriving after we had installed the bulk of our electrical system and we never got around to replacing them.
We are currently two motor controllers short on our robot, I'll see if I can convince the kids to put the new jags on. Are the changes documented anywhere?
  #35   Spotlight this post!
Unread 10-04-2013, 22:34
I provided a link in an earlier post.
  #36   Spotlight this post!
Unread 10-04-2013, 22:41
Jared Russell's Avatar
Taking a year (mostly) off
We used 888s because we got shut out from Talons (FIRST Choice debacle then out of stock right before we ordered).
I have nothing bad to say about the 888s, other than I still hate the finicky PWM connectors.
  #37   Spotlight this post!
Unread 11-04-2013, 02:04
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The "standard" update rate of the Talon driver in WPILib is 10ms not 5.
At least it is in the 12/20/2012 version of Talon.java.
Interesting.
I assumed that since Mike Copioli said the Talon would accept a PWM to something around 3ms that it was set in the WPIlib to 5.05ms (1 DIO loop frequency)
I set ours to 1 DIO loop frequency (5.05ms) and have no issues, not even with practice bot Victors using the Talon output scaling and pulse period of 5.05ms. I'm not entirely sure why the output frequency was ever set to 2 DIO loops (10.1ms) to begin with, or why the DIO loop is 5.05ms instead of 5ms or something even faster.
Kettering Motorsports
  #38   Spotlight this post!
Unread 11-04-2013, 02:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Accidentally applied unregulated 12V to the output of a Talon, nothing happened. Eight Talons on each of two robots. We're happy with them.
  #39   Spotlight this post!
Unread 11-04-2013, 09:38
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Originally Posted by apalrd View Post
Interesting.
I am going from memory, I don't have the WPILibJ in front of me, but as I recall there were notes on the PWM class about compatability across all PWM devices (servos as well as motor controllers). The 5.05 results from a base rate in microseconds in the 6us range, times 770 or so. The particular devices get a multiplier of the 5.05ms and Victors and Talons were 2x (10.1ms) and Jags 1x. This is in the latest update of the Java libraries, but again its from memory, so check the PWM class to be sure.
In keeping with the original question: We used 8 talons and 2 jaguars. The jags were applied where we wanted HW limit switches.
We have did lose one talon during the season, the one controlling the front wheel of our shooter.
  #40   Spotlight this post!
Unread 11-04-2013, 10:21
Originally Posted by omalleyj View Post
We ...did lose one talon during the season, the one controlling the front wheel of our shooter.
What speed control algorithm were you using?
Did anyone else have a Talon failure while using it to control a shooter motor?
  #41   Spotlight this post!
Unread 11-04-2013, 10:28
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Originally Posted by Michael Blake View Post
We used the new Victor 888's _exclusively_ and are _very_ pleased with their performance.
Not so pleased with _our_ performance this season, but the Victors played no role in that.
We'll continue using Victor 888's in future seasons.
--Michael Blake
We did have to calibrate several of them though... it is hard to say though how much of an improvement that was if any at all. As far as I could tell, it just confirmed full power on the LED feedback, where before it didn't.
The other minor issue is that it seems like it requires a special skill to connect the pwm's into the victors correctly to make them stop blinking.
  #42   Spotlight this post!
Unread 11-04-2013, 10:38
AKA: Jim O'Malley
No feedback at all, we found the frisbees flight was not very speed sensitive. We used light wheels that recover quickly. The rear motor was set to 70% and the front to 100%. There was a 1.75 second delay between shots to allow recovery.
Motors are mini CIMs, banebots wheels (orange tread), about 3/4" compression.
  #43   Spotlight this post!
Unread 11-04-2013, 11:23
peirvine's Avatar
peirvine peirvine is offline
GOFIRST Director of Engineering
AKA: Peter Irvine
FRC #2175 (Fighting Calculators and Ri3D 'Snow Problem)
peirvine is an unknown quantity at this point
2175 has never really liked the Jaguars very much. They are big, and we have had sever release their magic smoke on us. In 2012 we decided to try Victors and loved them. They were smaller and simpler and worked 100% of the time. This year - 2013 - we decided to try the new Talons. We loved them even more and are planning on going with them next year. They are even smaller than the Victors and have no need for a fan. We still put fans on our drive Talons but that was because a team member touched them and overreacted... If we had to rate our order of choice for speed controllers it would be:
1) Talons
2) Victors
3) Jags
2014 Northern Lights Regional-Winners (Thanks 359 and 2502)-Industrial Safety Award-Excellence in Engineering-North Star Regional-Industrial Safety-Creativity-WFFA (my dad!)-Semifinalists (Thanks 967 and 4607 (again!))
- Division Finalists (Thanks 2169 and 3284)
2013 Northern Lights Regional - Quarterfinalists, Entrepreneurship Award - Dean's List Semi-Finalist - North Star Regional - Winners (Thanks 967 and 4607), Team Spirit Award - 2013 MSHSL State Tournament - Winners (Thanks 2052 and 4607) - IRI
2012 Lake Superior Regional - Quarterfinalists, Coopertition Award - North Star Regional - Quarterfinalists, Creativity Award
-North Star Regional - WFFA Will Preska, Semifinalists
  #44   Spotlight this post!
Unread 11-04-2013, 11:47
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Talons 100%. Our design did not call for electronics space (oops) so we had a very hard time fitting all the components. Talons saved us. We were forced to fit 9 talons in a 6"x8.5" space. None of them have failed, amazing.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
  #45   Spotlight this post!
Unread 11-04-2013, 18:16
ttallo's Avatar
ttallo ttallo is offline
FRC #0230 (Gaelhawks)
Team Role: Operator
ttallo is an unknown quantity at this point
this year 230 went with talons. We always used victors but we tried something new. We never had a problem with them overheating or anything else, without their small foot print our electrical board wouldn't have worked either.
