Go to Post I personally think that everybody on the team is important. No matter what, every single student, mentor, teacher put their effort all year long to get the team going. So in my opinion, Credit goes to everyone. - Arefin Bari [more]
Unread 29-01-2003, 12:35
nragod's Avatar
nragod nragod is offline
AKA: Ed Jordan
None #0376 (Newark Robotics Assoc.)
nragod is an unknown quantity at this point
Send a message via ICQ to nragod Send a message via AIM to nragod Send a message via MSN to nragod Send a message via Yahoo to nragod
Question oil for for Pneumatics
does any body know what oil i can use to re oil the Pneumatics cylinders?
Unread 29-01-2003, 12:49
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You shouldn't ever need to re-oil them
Unread 03-02-2003, 19:07
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Bad boy, Gadget470, lyin to nrademigod like that. Pneumatic oil is pertinent for optimal performance of all pneumatic components. Grab some at an auto parts or hardware store. Use it every day.
Unread 03-02-2003, 20:42
_-GoMeZ-_ _-GoMeZ-_ is offline
_-GoMeZ-_ is an unknown quantity at this point
No oil needed
Gadget470 is right, the cylinders are pre-lubed when assembled and don't need any further "oil" . Check the manufacturers website out for confirmation.
Unread 03-02-2003, 20:48
Dan 550's Avatar
AKA: Dan Richards
#0550 (BattleTech)
I understand that they're pre-lubed. That's not the point. The pre-lube is a grease, not an oil. The oil will help your cylinder perform better than one without it. That's all.
Unread 03-02-2003, 20:58
hi_im_sean hi_im_sean is offline
hi_im_sean is an unknown quantity at this point
i would use some oil made for air tools. you can find it at any auto or hardware store.
Unread 03-02-2003, 21:10
Sorry
Actually we did a study on how oil affects high speed pneumatic applications and found oil ( both synthetic and non ) to be detrimental to the speed and operational life of the three types of cylinders we were using. It gathers in cylinders and tubing, reduces cross section of ports , plugs up exhaust filters , and is non compressable by nature and reduces working volumes. The lubrication properties it has ( and therefore speed and "performance" gains ) are lost on the fact that all cylinders are speed limited by the reduced size of the ports. They build in a flow control to keep peeps like us from blowin the things apart by crankin 'em too fast. I think the standard SMC max speed is something like 10"/sec. Take a look inside that 1/8 npt fitting and you'll probably see a tiny orrifice no bigger than .070. I promise you, check with the manufacturers sites on this one, no oil.
Hope this helps
Mez
Unread 03-02-2003, 21:16
Dan 550's Avatar
AKA: Dan Richards
#0550 (BattleTech)
Okay, I'm still gonna continue to use oil to lubricate the pump and pistons. It's good for the pump, I swear.
Unread 03-02-2003, 22:30
Gadget470's Avatar
A Fire Outside
Dave Johnson (Director of sales at SMC [i think, not sure his exact title]) said that to me during a seminar I took with him.
What's The Coolest Thing A Team Can Give Out? Joe Matt General Forum 496 03-04-2008 10:22
